Vindicatus Posted January 30, 2011 Share Posted January 30, 2011 So, after having moved (twice) since my Thunderhawk packaging has been opened, I realized a rather horrifying thought this morning when I went to work on the beast. I can only find ONE of my Hellstrike missiles, and none of the rails. B&C, I beseech you...do you know if anyplace to get bits for them? Or better, do you know of any missile-like bits out there from other kits that I might be able to find more readily available in order to outfit my TH more appropriately? Links, pics, pointers, or what-have-you welcome. ;) Link to comment https://bolterandchainsword.com/topic/221029-substitute-missiles/ Share on other sites More sharing options...
KhorneHunter57x Posted January 30, 2011 Share Posted January 30, 2011 Do you have any local IG players that use Valkyries or Vendettas? If so, then I would ask if they have any spare Hellstrike missiles from the Valk kit, as almost no one (that I know of) uses them, and I believe that they are pretty similar to the Thunderhawk's missiles (they are a bit different, though), and you can build the launch rails out of plasticard. You can also order Hellstrikes from Forge World here, though if you want the 'proper' loadout for a Thunderhawk you should look at these instead. ;) (I have found that bombs are more effective than missiles on a Thunderhawk) Link to comment https://bolterandchainsword.com/topic/221029-substitute-missiles/#findComment-2639665 Share on other sites More sharing options...
Calgar 2.0 Posted January 30, 2011 Share Posted January 30, 2011 If anythings missing, you can just call up ForgeWorld and tell them that. Link to comment https://bolterandchainsword.com/topic/221029-substitute-missiles/#findComment-2639700 Share on other sites More sharing options...
Vindicatus Posted January 30, 2011 Author Share Posted January 30, 2011 Thanks for the replies. I definitely appreciate the links to FW and the ideas about the IG kits. I tried digging through a few bits sites, and then the FW site, but as usual, their idea of uniformity when listing an order to their products is a little weird. :) I keep having issues finding Chaos termie-crap when clicking around. Link to comment https://bolterandchainsword.com/topic/221029-substitute-missiles/#findComment-2639768 Share on other sites More sharing options...
