Typical Cricket Posted February 21, 2011 Share Posted February 21, 2011 I'm wondering if anyone has been able to hook up their Citadel Spray Gun to a compressor before? I have a Mastercraft 7.6 litre compressor that I use for odd jobs, like air stapling and such. It came with a recoil hose with a 1/4" NPT male fitting, but I have no idea what the fitting would be on the li'l hose that the Spray Gun comes with. Any ideas? Also, for anyone that's pulled this off, about what PSI do you use it at? Link to comment https://bolterandchainsword.com/topic/223069-citadel-spray-gun-question/ Share on other sites More sharing options...
Tanhausen Posted February 22, 2011 Share Posted February 22, 2011 I use an adaptor that I stick at the spray gun so I can go and screw the compressor onto the gun. I think it goes from the 1/4 to the 1/8 (male and female respectively) and its quite easy to find (hardware stores, arts shops that carry AB...) Also, the spraygun's hose is quite bad... so I use the compressors hose. Remember to use a moisture trap in order to prevent water splattering out from your spraygun. Hope it helps! Link to comment https://bolterandchainsword.com/topic/223069-citadel-spray-gun-question/#findComment-2667479 Share on other sites More sharing options...
