Glitch85 Posted March 9, 2011 Share Posted March 9, 2011 Hey all, just wondering what order you go about painting your models, which bits you do first? Link to comment https://bolterandchainsword.com/topic/224375-painting-order/ Share on other sites More sharing options...
mrtn Posted March 9, 2011 Share Posted March 9, 2011 If any parts will be drybrushed I do them first, especially if it's metal, as you don't want shiny flakes glittering on other parts of the model. Otherwise it goes inside to out, and big things to small. Then washes and details. I often refine my painting after a few batches, when you figure out shortcuts you can take. Link to comment https://bolterandchainsword.com/topic/224375-painting-order/#findComment-2683119 Share on other sites More sharing options...
Gavin Posted March 10, 2011 Share Posted March 10, 2011 I basecoat the largest areas then paint the metals and finally small details. After that I touch up the original areas and then I go to washes and then drybrushing. Give it a final inspection and touch it up as needed. Finally base it with PVA glue and the sand from GW. edit - needed to make coherent sentences Link to comment https://bolterandchainsword.com/topic/224375-painting-order/#findComment-2683729 Share on other sites More sharing options...
Muzza Posted March 10, 2011 Share Posted March 10, 2011 Assuming it's a SM model (based on what this forum is), I start with the armour. I get the base colour down and then a wash. I then usually do the base coat of any details, then highlight the armour, then highlight the details. Finally I do any other layers or additional highlight layers. Link to comment https://bolterandchainsword.com/topic/224375-painting-order/#findComment-2684167 Share on other sites More sharing options...
WingsOfTheFalcon Posted March 10, 2011 Share Posted March 10, 2011 Inside out... Start with the deepest layers and work up to top layers, less likely to mess up previous work! :lol: Link to comment https://bolterandchainsword.com/topic/224375-painting-order/#findComment-2684255 Share on other sites More sharing options...
Tranc Posted March 10, 2011 Share Posted March 10, 2011 I paint in parts, before assembling. So first the legs (so he can stand), then the torso, and then usually the head. The shoulder pads come next because I find them interesting, and then the bolter and arms. I find the arms boring, but need them to hold up the shoulder pads & bolter. Last is the backpack (just marginally less boring than the arms), and the base. It's all here. For each bit, I follow the process of 1) Prime 2) Undercoat 3) Basecoat 4) Layered Highlights 5) Darkline 6) Line Highlight except for metallics, where I'll also add a wash, and a little of extreme highlighting after the wash. Link to comment https://bolterandchainsword.com/topic/224375-painting-order/#findComment-2684679 Share on other sites More sharing options...
