Help with a grey knight dip
So I want a quick way to paint 60 odd grey knight terminators quickly.
I'm planning to spray them with army painter plate mail.
I saw the army painter dips and I was wanting to do a similar principle but with a blue dip
Would it work if I just filled a jar with a pot of as rumen blue wash and water or would I need another chemical to dilute or what?
If I could make this my plan would be spray with plate mail, dip with blue, dry brush with chain mail silver then highlight with mithril silver.
Do you think that this will work out well?
Will the blue shade the model or just tint it. If not how should I shade a metallic like that that I want to keep bright? I use gryphons sepia a lot but I often use it to turn silver to gold so I don't want to use it with the grey knights
https://bolterandchainsword.com/topic/225158-help-with-a-grey-knight-dip/
Dips, like the one Army Builder sells, is actually REALLY thick stuff. The only reason why you hear dips made from wood stains are "diluted" is simply because those are even thicker. The consistency, thickness and coverage of a dip is far higher than a normal wash. I doubt thinning Asurman Blue will work, especially if you dilute it with water.
try this recipe:
1 6 or 8 oz cup/jar, bottle of Pledge with Future Shine Arcylic floor finish (blue label bottle), whatever shade of blue paint or ink
mix one part Pledge floor polish with water and add drops of paint or ink to taste. grab an old brush and test on a old figure. a little trial and error and you can get the tint or shade your looking for. and a lot cheaper to do as well. plus the floor polish dip dries in about 10-15 minutes; less if you have a fan nearby. :P
