Drudge Dreadnought Posted April 8, 2011 Share Posted April 8, 2011 Hey everyone, I've got a can of the GW white spray 'primer'. Every time I've used it, it's come out a bit gritty. I've heard that this is normal, but I've also heard something about using warm water to avoid this. Can anyone explain how this is done, or other methods to get it smooth? Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/ Share on other sites More sharing options...
Solid Zaku Posted April 8, 2011 Share Posted April 8, 2011 I'm going to be honest, the best thing to do with GW primer is to sell it and hopefully for more than what you payed for it. It's a pretty well-confirmed phenomena that GW's white paint practically comes out like they mix it with salt. Try other (vastly less expensive) brands like Army Painter, Krylon, or the like. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2716820 Share on other sites More sharing options...
Tanhausen Posted April 8, 2011 Share Posted April 8, 2011 Army painter white primer works well. So does Vallejo primer, which you can brush or airbrush. As for the "hot can" techinque: fill up a bucket or similar with HOT water (as hot as the tap goes), submerge the can for 30 secs-1 min, shake hard for 10 secs, repeat a couple times. That way, the paint will not stay at the bottom and the propellet will mix decently. When (not if) you can goes cold from use, you can also do this operation to get it working properly again. Hope it helps! Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2716857 Share on other sites More sharing options...
Spacefrisian Posted April 8, 2011 Share Posted April 8, 2011 Just hot streaming water does the same, no need to fill a bucket. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2716959 Share on other sites More sharing options...
Tanhausen Posted April 8, 2011 Share Posted April 8, 2011 A bucket will fit some 5-10 liters, and you can use it several times. If you leave the tap running, you'll waste far more than that...just like when you shave! If you don't take care of your enviroment, the Emperor will make your fangs fall off :P Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2716968 Share on other sites More sharing options...
CarbonBased Posted April 8, 2011 Share Posted April 8, 2011 I prime white with http://www.rustoleum.com/CBGProduct.asp?pid=402 It's not failed me yet. I've used a lot of different stuff, and so long as the weather is not horrible for painting, this is my favorite. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2717207 Share on other sites More sharing options...
Brother Valerius Posted April 8, 2011 Share Posted April 8, 2011 I'm going to be honest, the best thing to do with GW primer is to sell it and hopefully for more than what you payed for it. It's a pretty well-confirmed phenomena that GW's white paint practically comes out like they mix it with salt. Try other (vastly less expensive) brands like Army Painter, Krylon, or the like. Sure, I find this out after I buy a can of GW white... :( Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2717334 Share on other sites More sharing options...
Master of fact Posted April 8, 2011 Share Posted April 8, 2011 GW spray is over priced, very gritty and.................... just get army painter. Some great colours and great coverage. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2717445 Share on other sites More sharing options...
EmbattledSoul Posted April 9, 2011 Share Posted April 9, 2011 mehh ive only used the black but i thought it was supposed to be a little rough, kind of like sanding/bead blasting a surface, gives something for additional layers to adhere to. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2718297 Share on other sites More sharing options...
Redfinger Posted April 9, 2011 Share Posted April 9, 2011 What is the distance that you are spraying from? The gritty-ness can be a result of spraying to far away from your subject, as the paint mist travels through the air it starts to dry before it comes in contact w/ the subject. Try the hot water method, and try spraying a bit closer as well. Ashton Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2718308 Share on other sites More sharing options...
EmbattledSoul Posted April 9, 2011 Share Posted April 9, 2011 the recommended 8 inches give or take, mine doesnt seem gritty just a roughish surface. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2718321 Share on other sites More sharing options...
CarbonBased Posted April 9, 2011 Share Posted April 9, 2011 It shouldn't really be rough. So long as you have a matte, or even satin, finish on your primer coat, you have enough tooth for the top coats to adhere. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2718524 Share on other sites More sharing options...
Psy-Crow Posted April 10, 2011 Share Posted April 10, 2011 the recommended 8 inches give or take. Thats what she said. sry, been listening to the office while I paint. I think its worth mentioning that some people have boilers producing scalding water and its never a good idea to put a pressurized container in very hot water. I had the same issues myself until i learned the hot water trick, just make sure water isn't too hot and not to soak it too long, also you need to shake the can like your life depends on it. Oh, and as soon as the can is empty never ever replace it, and get army painter primer. way better Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2719330 Share on other sites More sharing options...
ObsidianIchor Posted April 13, 2011 Share Posted April 13, 2011 I'm going to be honest, the best thing to do with GW primer is to sell it and hopefully for more than what you payed for it. It's a pretty well-confirmed phenomena that GW's white paint practically comes out like they mix it with salt. Try other (vastly less expensive) brands like Army Painter, Krylon, or the like. With Krylon (or other brands I suppose), do you recommend just a flat paint or a primer? Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2722148 Share on other sites More sharing options...
DV8 Posted April 13, 2011 Share Posted April 13, 2011 If you need to spray to actually act as a primer, you need to get Primer, not Flat Paint. That's why they call it a Primer (it has a natural "tooth" that allows paint to more readily adhere to it). DV8 Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2722714 Share on other sites More sharing options...
Jakael Posted April 13, 2011 Share Posted April 13, 2011 Krylon ultra flat. you can usually find it with their camouflage system. This is the best spraypaint for priming you can get and it costs less than 4$ a can. It has the "tooth" that DV8 mentioned and is very forgiving if you use a bit too much. Link to comment https://bolterandchainsword.com/topic/226816-white-primer-grit/#findComment-2723384 Share on other sites More sharing options...
