Dremen Posted April 8, 2011 Share Posted April 8, 2011 So I want to Create a "Force" bubble. By this I mean the impact of a thunder hammer and the force of a Rozarius or Crux deflecting blows. I'm thinking along the lines of clear plastic that I can mould or shape but thats clear enough to show that its a field or energy source doing it. I've done a search but nothing along these lines has come up (Search-Fu is weak). Just wondering if anyone else has tried this sort of thing before and how you went about it. Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/ Share on other sites More sharing options...
chromedog Posted April 9, 2011 Share Posted April 9, 2011 What size 'domes' are you after? I've done some vacforming of clear acetate domes over the years (needs a vacformer though, so beyond most gamers). Otherwise, there are a variety of clear plastic domes/spheres available around christmas (for xmas decorations). Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2717834 Share on other sites More sharing options...
Dremen Posted April 9, 2011 Author Share Posted April 9, 2011 1.5 inch Diameter half-spheres would be ideal for the project I'm currently working on. No Vacformer here though so that rules out that option. Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2717864 Share on other sites More sharing options...
THE GHOMA Posted April 9, 2011 Share Posted April 9, 2011 You can always try the clear top of those things that trinkets come in Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2717874 Share on other sites More sharing options...
chromedog Posted April 9, 2011 Share Posted April 9, 2011 40mm hemispheres should be relatively common. I'm sure I've seen their like in craft-shops. Gamers should at least make an attempt to think outside the (GW) box every now and then. Craft-shops are playgrounds. Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2718005 Share on other sites More sharing options...
kizzap88 Posted April 9, 2011 Share Posted April 9, 2011 Depending on how patient you feel on being, you could possibly use a clear resin to get the effect that you were after. What you would need to do is to find something with the required surface shape on the inside of the object, cover the surface with an oil like substance really thin (something like petroleum jelly) then mix up some clear casting resin-not too much, just enough to give off a surface of the shape. then you need to be constantly be spinning around the piece so that the resin liquid spreads out over the surface leaving a thinnish film over the rounded surface. To attach you would have to make a clear cast of something long(or short) enough to attach it to a point on the model, and glue it to outer piece with PVA glue, because as we all know PVA dries clear. The coolest part with this idea is that if you get really detailed into it, you can add food colouring or something to it to give some colour yet still leave it clear. -kizzap Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2718026 Share on other sites More sharing options...
Stroganoff Posted April 10, 2011 Share Posted April 10, 2011 I've very recently started looking at molding & casting and saw some stuff at the local supply store about making resin jewellery. Make a one or two part mold of what you want, then use a clear resin with pigment very loosely mixed in to create a marbling effect. http://www.youtube.com/BarnesProducts#p/a/u/1/6o9v6gamFXM Good luck, it sounds like an interesting challenge with lots of potential! Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2719122 Share on other sites More sharing options...
Master Of Malfeasance X Posted April 10, 2011 Share Posted April 10, 2011 You could always go the other way and use wires coming from your hammer to suggest a wireframe of an explosion of a force bubble, just paint them like lightning and you're golden. Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2719141 Share on other sites More sharing options...
curnow Posted April 10, 2011 Share Posted April 10, 2011 ive done this before to pepresent a force field on a diarama . get some thin clear plastic cut into a circle and find a metle/stone/wood ball and u can use a heat gun/strong hair dryer {mind ur fingers with the heat gun !} and work it over the ball as it softens . you could get the same effect useing a ovens grill aswell. Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2719350 Share on other sites More sharing options...
Dremen Posted April 11, 2011 Author Share Posted April 11, 2011 Thanks for the suggestion guys. Now to put some of it into practice and try to keep my hands whole and unscared... ok getting the FA kit out first. Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2719760 Share on other sites More sharing options...
Brother_Ovis Posted April 12, 2011 Share Posted April 12, 2011 Every time I dilute PVA glue in my palette I remove small transparent bubbles of it when it dries, so maybe that's the way to go. Just find yourself a bowl of right shape and cover the inside with it. If it's smooth enough, the dried glue should come off with no effort. The bottom surface will be as smooth as the bowl itself and transparent. Link to comment https://bolterandchainsword.com/topic/226905-force-bubbles/#findComment-2721457 Share on other sites More sharing options...
