Marik Posted April 13, 2011 Share Posted April 13, 2011 So got some minis that happen to have already been covered in black primer. I prefer white and was wondering if it would be alright to just put a coat of white primer on top of the black and get similar results had it just been white primed. Or is my attempt to be lazy and not strip it down to the plastic going to bite me in the ass when I go to paint? Link to comment https://bolterandchainsword.com/topic/227327-primer-question/ Share on other sites More sharing options...
Brother Valerius Posted April 13, 2011 Share Posted April 13, 2011 I imagine you're going to hurt yourself by not stripping. Another coat of primer on top of what you already have, plus whatever color you paint with, is going to start filling in small details like the panel lines in the armor. Link to comment https://bolterandchainsword.com/topic/227327-primer-question/#findComment-2723161 Share on other sites More sharing options...
Tanhausen Posted April 13, 2011 Share Posted April 13, 2011 Agreed: double primer will cover the details...dont be lazy, youll regret it later! Link to comment https://bolterandchainsword.com/topic/227327-primer-question/#findComment-2723214 Share on other sites More sharing options...
CarbonCopy Posted April 16, 2011 Share Posted April 16, 2011 Try a couple quick, light dustings of white primer from the top. Not full-coverage, just a quick snow. You want some black showing from the bottom. This is often used as a method to establish zenithal highlighting. http://www.mainlymedieval.com/ozpainters/v...?f=9&t=2200 and http://thepaintingcorps.blogspot.com/2010/...airbrushed.html (Does not need to be done with an airbrush, but it helps to keep the highlight finer.) Link to comment https://bolterandchainsword.com/topic/227327-primer-question/#findComment-2726568 Share on other sites More sharing options...
AJB2K3 Posted April 16, 2011 Share Posted April 16, 2011 If its just black primer you have two options 1, Dump into Dettol(UK), pinesol/simple green (USA) to strip, 2, give a light dusting from the side (ie face on ) of gray primer then top down with white prime (PP calls this under painting) the using thin layers paint the colours over the top. Link to comment https://bolterandchainsword.com/topic/227327-primer-question/#findComment-2726693 Share on other sites More sharing options...
