tips for playing tyranids?
like the lion
im gonna be playing the tyranids in a few days. i have never played them before so i dont know what to expect. i may go all deathwing of just regular DA. the plan so far is to light them up. lots of krak missiles and snipers.
what tips can you give me? i know my oponent likes to use gaunts and monstrous creatures.
https://bolterandchainsword.com/topic/227350-tips-for-playing-tyranids/
He will have 2X or maybe even 3X more minis if he is running hoard. If he is running MC I can't remember I don't think those Krak Missles will be doing any Insta Killing and seem wasted on gaunts.
My son beat me as him DA and me Tyranids. He beat me a few times, but finally my DoM fianlly did something on the 4th game and killed like 8 guys so there went his army.
It all depends on what he fields. If MC and gaunts and no Warriors you will not be Insta Killing anything. Deathwing may last a bit longer with FNP but if he is using say 30 Devilgaunts that is 90 shots. 90 shots, 45 hit, 22 wound, 10 failed saves, so you can see you can get lots of dead units. Then again this is not scientific but seems to work for me agaisnt 3+ saves, would be different with 2+ saves but still. Once you loose your bodeis and if it is a sceanrio game, you will not have many squads to claim and or deny those objectives.
Tyranids are a pain to beat--I should know, they're the army I play (and loose to) the most.
You can't overwhelm them with shooting, so you have to pick your targets carefully. If you can take out synapse creatures, then his army will loose cohesion, but most players tend to compensate for this by using warrior squads, which will hold the line and keep synapse intact pretty well. As a rule of thumb, the bigger and meaner looking a model is, the more you want to kill it. The only problem is you still have to prioritize amongst the MCs.
Tervigons are just plain nasty. They're damn near impossible to kill, and they just keep spawning gaunts. Of all of the various MCs, these are probably the ones I hate the most.
Also, the train of though "If I can't beat them at shooting then I should assault them" is just plain wrong. If being careful when picking shooting targets is important, being careful with assaults is paramount to success, so there are a couple of rules:
#1. Don't let them get the drop on you. It doesn't matter if you're using the best assault unit in the DA codex, if a 'Nid unit dedicated to kicking ass and taking names in close combat gets the charge, you're dead. Even when you're doing the charging, expect losses.
#2. Always ask, "Is it worth it?" That gaunt squad may be annoying, but if it's going to take three turns to kill in HTH, then you're probably better off finding another option. You never want your units tied up in combat unless it's the only way to stop the flood of bugs, because they're firepower/assault skills will be needed elsewhere.
Finally, while kill all of you enemy's units is always a win condition, don't expect it to happen. I've been facing 'nids for 2 and 1/2 years, and maybe once in all that time have I won completely (not that I have that many wins to compare it too...). Expect the battle to be either distinctly one sided (I've had vastly superior forces left over on occasion) or a grueling, high casualty affair (this is by far more common).
Good luck,
--BoR
Don't be afraid to walk backwards most of the game, to maximize your shooting before he gets to assault you.
Personally, given a choice, I would *usually* rather be in cover when the tyranids get the charge, than get the charge myself. Very, very few nids get assault grenades, and many of them are I5 or higher. So, if you have (say) TH/SS termies or powerfist termies, a decent-sized genestealer unit can potentially kill you all before you get to strike back, even if you charged them; if you make them charge you, though, and you're in cover, you get 10 attacks on them, which should be 4-5 dead stealers. Not a great bargain, but better than nothing, particularly if you have another termie squad or two in range to finish 'em off in shooting next turn.
Tyranids work by overloading your ability to shoot them in time before they hit you in close combat. So, proper target priority is key. You probably want to prioritize the fast-moving or infiltrating stuff (genestealers, again, probably, but maybe gargoyles, and definitely raveners if he's running them), but there are times (notably if a lot of the shooting in your army is from vehicles) when you may need to hit the hive guard first, because the hive guard are what is shooting back at your vehicles, killing or suppressing them every turn.
This cannot be stressed enough as it is one of many codex flaws that the 'Nids suffer from.
This. If you're going to get charged, get charged in cover, as it means your squad will still get to swing. I've only played against nids once and this is the main thing I took away from it, but I can also recommend deploying nowhere near the sides of the board, as outflanking 'stealers are horrible (especially as they're fleet, right?). Missile spam took out the MCs fairly easily (didn't seem like particularly good or bad rolling on my or their part, but is this the norm?), and don't underestimate the little beasties either, they'll grind you down through sheer numbers. The next time I play them I'll keep my squads fairly close together (or run them about in pairs; 1 shooty + 1CC ) so they are aways supported.
Unfortunatley I'm not at all experienced at playing against them, so my advice is quite superficial I'm afraid! I unerstand quite an effective tactic is hitting a depleted mini-beast squad and an MC in a multiassault; you put most/all your attacks on the little ones, win combat, and force the MC to take a bunch of fearless wounds (more than you might cause otherwise). Might be quite difficult to orchestrate though!!
Its really hard to give ideas without knowing either army...
But you've been given nice advice... here goes my quick thoughts:
- Know what armour saves each bug packs. It sounds stupid and obvious, but the're isn't anything better than using the proper tool for the best effect.
For example, Hive tyrants and mawglocs and the similar... they are TOUGH ( T6, 6W most of the times)... but have a measly 3+ save. Guess what, most S8+ weapons have AP3 or better...so 3+,2+, you have 55% chances of scoring a wound he won't be able to save (MC get cover just like vehicles...).
Bolters and flamers have AP5...so small bugs (anything that isnt MC, warriors or zooans) will fall easy to them.
- Templates are your friend.
Most nid builds have 2-6 MC, 4-12 middle bugs and around 100 small ones. Try to avoid using quality shots on cheap units.
- Beware of counter-charges.
Wow, those zooans sitting just out of cover seem quite juicy... why does he do that? Because 3-4 warrior with bone swords will make short work of anything, even hammenators.
- Don't take the beating.
I'd say only IG can "hold the line" and withstand a nid assault... and that is because they have the best gunline along with heavy support that will massacre any swarm.
So stay on the move, get in cover to benefit from initiatives like Ian suggested.
Let us know how it goes!
Edit, hiting/wounding MC is 3+ 2+...corrected.
Another thing to consider, if he does have infiltrating genestealers (scarier for me than outflanking ones, but YMMV), is to have one unit quite a bit forward of your others, to push back the infiltraters a bit. If it's a fast unit, better still, so it doesn't even need to be a sacrifice, but even a Deathwing squad can work OK. You will get at least one turn of SB fire at them, you can hopefully sit in cover so as to at least get to swing, and he won't be able to multi-assault as he might if all your units were close to each other.
That is exactly what I did in my last game vs Nids... spear head, my melta bikers and speeders covering as far as possible in my area.
However, I think the best genes are the Ymargl ones...you chose a scenary element and when you go in by reserves, they come in from there, move and assault normally. They are a great bases tarpiting unit.
Agreed. The backpedaling tactics of shooty Deathwing (especially pre-FAQ) come to mind. Full TH/SS are all the rage now, but a hoard is simply going to overwhelm them.
A pair of whirlwinds would be useful.
Yea, I believe most of the MC's are str 6. But at least they are wounding on 2s and I don't feel they are totally useless against the little bugs, at least not the CML kraks, a couple blast markers on a squad that has the a potential to get more bunched up.
Brodher have faithe in the Emperor and bring S++++ loads of gunns.
The more led you can trow in to them the better.
Well it workt for me when i meet them.
Have faite in the emperor bicase your brodhers have faithe in you!
Best of luck and let us know how it whent.
Yeah, Ymgarl genestealers are amazing (I play Nids and use them in most games... they took out a Defiler on the first turn I ever used them, and by the end of that game they were trying to get hits in on his Land Raider because they and Doom had killed pretty much everything else in his army). They're definitely less common at present than regular stealers though.
Ymgarls are all about second-guessing which bit of area terrain he put them in -- but there's not usually a whole lot you can do even if you guessed right, other than stay away from that area to mitigate the damage. In theory you can occupy the suspect bit of terrain yourself, to stop them coming on at all, but against a good player, that bit of terrain is exactly where you don't want to be, if you don't want to be steamrollered by the rest of his force.
My main opponent plays Nids. I just recently started with DA. So far my DW with Cyclones have fared well against him. Krak missiles are wonderous vs Warriors. Especially if he doesn't field a Prime with them. As mentioned before Cover kills nids. Maximize fire power for sure and concentrate it on one thing. Do not spread your fire out or you will not do enough damage to matter before he gets to you.
I try to prioritize targets:
Tervigon
Trygon
Warriors
Most effective way I have dealt with the Tervigon is dual charge him and the broods around him if possible. Watch him topple to amount of fearless saves he has to take.
hope it helps
ok i have come up with this list so far.
HQ
belial with banner
sammy in speeder
TROOPS
2x5 terminators- all hammers, cyclone
ELITES
2x10 scouts- 8 snipers
dreadnought- twin las, venerable status
FAST
3x typhoon landspeeders with multi meltas
HEAVY
3x preadators- Heavy bolters
this list leaves me with 125 points left. i have been thinking of swapping sammy for a librarian since i know he might use zoanthropes, i want the pshychic hood. the plan with this list is for sammy to ride out with the speeders and try to destroy as many big bugs as possible with the scouts infiltrating and picking at them also. belial and the dread will stay behind with the predators providing long range fire and waiting for them to come closer.
i dont plan on assaulting the bugs with sammy. im gonna field him in his speeder and lay down fire.
im not gonna be playing any scenarios.
ill probably cut the las off the dreadnought and maybe a sniper or two from the scouts. im probably gonna add another termie squad with the remaining points.
HQ
belial with banner
you need apothecary, fnp best to +1a for me.
sammy in speeder
sammy? and motos? best LRC..
TROOPS
best 1/2LC and 3/4 THSS... tyr not have granades...
ELITES
add PF and plasma pistol to sarge
add flamer
FAST
ok, anain tyr also HBolter is goodHEAVY
ok
2 troops are really little
my 2 cents
1850 points i played in Tourn and killed the nids army 50% in end of 2nd turn
4 tac squads with Las Cannons and one with plasma cannon
plasma guns and a melta support guns
couple sarges had power weapons
dread with Plasma cannon and hvy falmer and fist
azreal with vets with plasma pistols and rhino
predator with ac and hb
Whirl wind
4 rockets in a dev team
use ya 5 man squads and rhinos to block charges - slow them down -
also use overlapping fields of fire
keep a team of melta - and plasma guns close incase of deep striking stuff - two squads reserve
dread can assit in a reserve role as well
no need to charge az foward he can stay back - let them come to u
My build was very effective - i won most my games
CSM list is cheaper and more effective but you dont get az
Az gives ya vets 4+ inv which is quite good
ok heres the new list.
HQ
belia- banner, apothecary
sammy-speeder
TROOPS
3X5 terminators-cyclone
ELITES
3X dreadnoughts- assault cannon, h.flamer
FAST
3X landspeeders- h.bolter, typhoon
HEAVY
3X predators- h.bolters., 1 w/ storm bolter
I honestly think you should drop sammy from the list, for those points you could get 2 whirlwinds, which will do a hell of alot more damage. Speaking of which, you should really consider at least 1, they can do brutal things to large nid swarms. For dealing with MCs try a couple of units of Ravenwing with 2 plasmaguns and a plasma pistol, keep them together and gang them up on a single MC, 10 plasma shots should bring down most beastys he has. Speeders with heavy flamers are brilliant at tackling large squads of smaller beastys, especially if you can pick on the little guys without getting into range of anything that can damage vehicles. Personaly I avoid taking Deathwing against nids, they just don't excel at what you need them to do as well as other choices you can take instead. One last thing, take extra stormbolters on all your vehicles cause for those 5 points you're gonna be able to throw that little bit more fire out most turns.
Hope that helps
Lithior
