adeptuscustodus Posted August 19, 2011 Share Posted August 19, 2011 Thought I might share the backpacks I created for MK2 andMK3 as I did not really like the massive hump sticking out above the head. 1) Cutting the pieces Take a plastic backpack and cut the vents of the sides and then the lower portion of the backpack. Then take the Forgeworld MK2/3 backpack and carefully cut the vents of, then by using a saw cut from the front of the backpack (part that connects to marine)untill you reach the hoses. Then taking a sharp scalpel and seperate the hoses from the topside and then cut the back of backpack further in half untill you have what shown in the foto. http://i71.photobucket.com/albums/i154/Mekboy/DSC00098.jpg 2) Glue together untill looks like the foto and add some rivets to and two discs to the vents http://i71.photobucket.com/albums/i154/Mekboy/DSC00101.jpg 3) Finished and on marine http://i71.photobucket.com/albums/i154/Mekboy/DSC00188.jpg Hope you like and find it usefull Link to comment https://bolterandchainsword.com/topic/236609-alternative-mk2-and-mk3-backpacks/ Share on other sites More sharing options...
Grotsmasha Posted October 4, 2011 Share Posted October 4, 2011 Sweet, I really like it. Jono Link to comment https://bolterandchainsword.com/topic/236609-alternative-mk2-and-mk3-backpacks/#findComment-2892486 Share on other sites More sharing options...
Foxmarine Posted October 8, 2011 Share Posted October 8, 2011 I like. Maybe when i have enough money, (never) i will use this :) Link to comment https://bolterandchainsword.com/topic/236609-alternative-mk2-and-mk3-backpacks/#findComment-2895515 Share on other sites More sharing options...
Lucian_Victus Posted November 16, 2011 Share Posted November 16, 2011 resurrecting this a bit but i need to add that you can also use some of the older chaos backpacks as well if you do not want to cut up your forge world packs....will do one and take pics when i have more time....maybe later today Link to comment https://bolterandchainsword.com/topic/236609-alternative-mk2-and-mk3-backpacks/#findComment-2925170 Share on other sites More sharing options...
Dark Scipio Posted December 22, 2011 Share Posted December 22, 2011 resurrecting this a bit but i need to add that you can also use some of the older chaos backpacks as well if you do not want to cut up your forge world packs....will do one and take pics when i have more time....maybe later today Pics would be great. Link to comment https://bolterandchainsword.com/topic/236609-alternative-mk2-and-mk3-backpacks/#findComment-2949223 Share on other sites More sharing options...
