Hyaenidae Posted February 19, 2012 Share Posted February 19, 2012 My last Matte Varnish I used (Armory Spray) was complete junk....it left a chalky white dust across my mini's, which I ended up having to strip down. So, the question is, what do you guys and gals generally use and approve of to protect your mini's? EDIT: Ug. Just noticed the very same topic not even a few below mine. Never mind.... Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/ Share on other sites More sharing options...
Razblood Posted February 22, 2012 Share Posted February 22, 2012 Just bought a bottle of Vallejo brush on, haven't had chance to try it yet though. Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/#findComment-2998143 Share on other sites More sharing options...
striker8 Posted February 22, 2012 Share Posted February 22, 2012 I use Armory matte clear all the time. The only time I get clouding or chalky finish is when I forget to take the temp and humidity into account and have had it happen with Krylon, and automotive grade clear coats as well. You have to adjust for this by adjusting the spray distance and how heavy the coat is and/or waiting for more forgivable conditions. There is a cure for chalky and clouding though. IT's not 100% effective all the time but will ussually bring things back and is easier than stripping. Wait for the cloudy/chalky finish to dry thoughly then spray with a lite wet coat of Dull cote. THis has saved me all sorts of frustration on the rare occasions I've had this issue Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/#findComment-2998227 Share on other sites More sharing options...
CainTheHunter Posted February 23, 2012 Share Posted February 23, 2012 I use Army Painter. When I sprayed for the first time I had the same result with chalky white dust on the minis, so was figuring out :). Guys here on forum explained that most often this happens because You have not shaken the can enough or spraying in wrong temperature. Since then I am usually warming the can up a bit and then giving it a vigorous shake (3-4 minutes) - and never had this problem again. Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/#findComment-2999330 Share on other sites More sharing options...
Brother Nihm Posted February 23, 2012 Share Posted February 23, 2012 Citadel Matte Varnish for me. Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/#findComment-2999362 Share on other sites More sharing options...
Redfinger Posted February 23, 2012 Share Posted February 23, 2012 Testor's Dullcoat....nuff said Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/#findComment-2999596 Share on other sites More sharing options...
Noctus Cornix Posted February 25, 2012 Share Posted February 25, 2012 I would have to agree with brother Nihm on this one. Citadel Varnish actually does a pretty good job at protecting the paint job. Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/#findComment-3000821 Share on other sites More sharing options...
vtec407 Posted February 29, 2012 Share Posted February 29, 2012 I too have the vallejo brush on matte varnish. Still have yet to open it. Link to comment https://bolterandchainsword.com/topic/247455-matte-varnish/#findComment-3004590 Share on other sites More sharing options...
