Freakshow668 Posted June 17, 2020 Share Posted June 17, 2020 I am loving this project, really excited to see how it turns out. Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5543458 Share on other sites More sharing options...
hushrong Posted June 17, 2020 Share Posted June 17, 2020 Looking good Kierdale! Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5543508 Share on other sites More sharing options...
Kierdale Posted June 18, 2020 Author Share Posted June 18, 2020 Thanks, everyone :) I got another wall section done today...well, the edging like on the last section. Hopefully I can get the 3rd and 4th done tomorrow, then start decorating the walls and floors, then glue the floors in. Then paint it all, decal it, weather it... :D Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5544177 Share on other sites More sharing options...
Kierdale Posted June 19, 2020 Author Share Posted June 19, 2020 I got the trim added to the wall sections. This is how the box will look when it’s all folded up: And when it’s unfolded. The two half thickness sections -the ends of the box - go back to back as you can see in the top right. They have magnets in the corners to hold them and it should also help to pull the floor sections flat. I’m now adding detail to the interior walls. Freakshow668 and hushrong 2 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5544906 Share on other sites More sharing options...
Graceless Posted June 19, 2020 Share Posted June 19, 2020 Wow, this whole thread is excellent! So many cool ideas I want to try out. Kierdale, you're an inspiration machine! Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5544934 Share on other sites More sharing options...
Kierdale Posted June 23, 2020 Author Share Posted June 23, 2020 Thanks, Graceless! The thread is certainly full of all kinds of stuff...a lot of it half finished, but I hope some of it inspires :) I got the walls of the pop-up building made, decorated (but for the outside surface) and joined at the spine. Next up is the folding floors. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5547335 Share on other sites More sharing options...
Kierdale Posted June 26, 2020 Author Share Posted June 26, 2020 I got this big metal cog from the hundred yen store. No plan for it but just had to buy it. Paint pot for scale ;) Any suggestions? Terrain? AdMech something? Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5548800 Share on other sites More sharing options...
Kierdale Posted June 27, 2020 Author Share Posted June 27, 2020 All the ground-floors are in (and fold properly if a little tightly). And one first-floor is in. One thing I noticed is that I should have had the floors taper inward ever so slightly...a millimetre would be fine....so they don’t scrape the walls when the floors fold up. I’ll sandpaper them a bit. Ladder to be added between these floors. The blue circles you can see here are the magnets. I’ll make some small boxes to cover these. The featureless floor here will be done as hazard stripes (a good way to hide the diagonal seam ;) ). Once it’s painted I’ll add some rubble, stains, etc. I’ll probably paint it to match the Mars/industrial basing of my Mentor Legion and Genestealer Cult. Mithrilforge and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5549261 Share on other sites More sharing options...
Dr_Ruminahui Posted June 29, 2020 Share Posted June 29, 2020 (edited) They are looking really good. Just curious on the difference between the ground and first floor - any reason why with the first floor having the corner "cut out"? I lived in Japan for a bit at the beginning of 3rd edition, which is when I painted the first models of what would be my first army (sisters of battle). Back then only the odd hobby store had any 40K stuff, but at least Tamiya paints were easily found. As for the huge cog... weird thing to find in the 100 yen store. And yeah, my only thought for it is to use in a terrain feature at some point. Edited June 30, 2020 by Dr_Ruminahui Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5550706 Share on other sites More sharing options...
Kierdale Posted June 30, 2020 Author Share Posted June 30, 2020 Each floor is 10cm x 10cm. In my first prototype (paper) I did have the two bottom floor fold up and be sandwiched a bit by the folded top floor but thought that using thicker material for the real one would probably cause trouble so I’ve spaced the floors 11cm apart to keep it simpler. Only one of the upper floors has a corner cut out and that was so I could add a ladder (as you’ll see below). Firstly as I wanted a visual ‘way up’ and secondly to play with more pop-up book mechanics a little bit. And painting begins! One thing I learned - in case I do a project like this again - is to make the floors not perfectly square; to have them a little shorter maybe 2 mm at the furthest point. I had to do a fair bit of sanding and cutting as they stuck out when the box was folded. Also when folded out the two end sections didn’t quite come back to back even with magnets there, so I’ve made an extra plate which clips on and hold them together. This also helps to pull all of the floors flat, which was a major worry. I’ve done the hazard stripe bitz. I’ll mask them now and spray the whole thing black then shades of grey. Some metallics. Lots of decals. Weathering and Mars dust stains. If I do another, I’d like to try one in foam, with a fantasy theme, and have it look like a book when it’s folded up. I might do away with the floor is folding as triangles as that is quite a pain. Just have square floors hinged into one wall, folding down to rest upon a lip on the other wall... But even as I type this, my head is saying “where’s the fun in that?!” We’ve got ten Warhammer Stores in Japan now, thankfully, and a fair few hobby shops stock it. I like Yodobashi as they have a point card (a 10% discount, essentially). Freakshow668, Dr_Ruminahui, Bjorn Firewalker and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5550723 Share on other sites More sharing options...
pawl Posted June 30, 2020 Share Posted June 30, 2020 (edited) I've been checking in here for a little while to see how you're getting on, and I think this is absolutely fantastic! The idea of space-saving terrain is brilliant for those that don't have a great deal of space to work with, and you've made it look good, too! Might I suggest an idea for a second version? You've mentioned drop-down flooring instead of folding. As it is the floors (when folded) need to sit flush with the inner walls, which means that you have to keep them both relatively flat, and any internal 'features' have to be painted/decals. If you were to use drop down flooring, you could magnetise the inner walls (or floors too), and use the extra room to store magnetised panels/features with physical details that would be placed over the inner surfaces. This would let you detail the inner sections when set up, but still allow you to store flat. Does that make sense? Looking forward to seeing this when it's finished though, great work so far! Edited June 30, 2020 by pawl Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5550728 Share on other sites More sharing options...
Bjorn Firewalker Posted June 30, 2020 Share Posted June 30, 2020 I rarely give Likes to incomplete work, but your efforts are obvious, even in-progress. I like all the details you added to make the pop-up terrain look lived-in. Excellent work. Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5550734 Share on other sites More sharing options...
Freakshow668 Posted June 30, 2020 Share Posted June 30, 2020 Excellent progress on this amazing project. Can't wait to see the finished article. Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5550932 Share on other sites More sharing options...
War Angel Posted July 1, 2020 Share Posted July 1, 2020 Man this is really getting awesome Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5551396 Share on other sites More sharing options...
Graceless Posted July 1, 2020 Share Posted July 1, 2020 Fantastic stuff, really enjoying watching this develop! Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5551672 Share on other sites More sharing options...
Kierdale Posted August 1, 2020 Author Share Posted August 1, 2020 Thanks for the comments and support! The rainy season has finally finished so I’ve been able to do some spraying! The rest is going to be brush work. A lot of it. Bjorn Firewalker, Graceless, Bryan Blaire and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5575927 Share on other sites More sharing options...
Bjorn Firewalker Posted August 2, 2020 Share Posted August 2, 2020 Genius design! Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5576351 Share on other sites More sharing options...
Graceless Posted August 2, 2020 Share Posted August 2, 2020 Looking really good, can't wait to see the finished version Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5576423 Share on other sites More sharing options...
Kierdale Posted September 7, 2020 Author Share Posted September 7, 2020 Need to get in and paint the doors of the folding building, but I’ve been busy with other projects. Such as this one which I made in a day: To paraphrase Dave Bowman... “My God! It’s full of... ...SKULLS!” Well, one’s missing. I imagine something decidedly unsavoury happens if it’s completed. My Skull Obelisk, for 40K and AoS. One part Skull Tower, one part Tzompantli and one part Space Odyssey. 49 parts Khorne. If I’d made them orthogonal I could’ve called it Khornate Konnect Four. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5597647 Share on other sites More sharing options...
Bjorn Firewalker Posted September 8, 2020 Share Posted September 8, 2020 My Skull Obelisk, for 40K and AoS. One part Skull Tower, one part Tzompantli and one part Space Odyssey. Good job.49 parts Khorne.The square root of 49 is seven, NURGLE'S holy number. If the Skull Tower is meant to honor the Blood God, it should be 64 parts Khorne. Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5597703 Share on other sites More sharing options...
Kierdale Posted September 8, 2020 Author Share Posted September 8, 2020 49 skulls was a pain in the rear! I’m not painting 64 of ‘em! :D Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5597722 Share on other sites More sharing options...
Mithrilforge Posted September 8, 2020 Share Posted September 8, 2020 Fantastic stuff here Kierdale Skulls for the Paint Throne eh !??... your sacrifice will probably be well rewarded Mithril Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5597726 Share on other sites More sharing options...
Kierdale Posted January 27, 2021 Author Share Posted January 27, 2021 A couple of weeks ago, I think it was on Instagram, I found the company `Battle Kiwi`, that makes pre-primed laser cut terrain (some with cool acrylic inserts/bits) plus tokens, templates and stuff. Here's their website: https://battlekiwi.com I recommend checking their site. It was the `Immortal Dynasty` series (#cough#Necrons#cough#) that grabbed my attention as I'm modeling my Orks fighting on a Tomb World. I got myself a `Nexus Sentinel` for NZ $25 (pretty good, I think) which is 6 1/4" tall and 3 1/8" wide. It arrived in the post today and the MDF was nice and smoothly primed black. The clear acrylic sheets are covered in a protective film on both sides to protect them, which is a nice touch. The MDF pieces came out of the sheets easily and it was easy to put together as a dry-fit. I'm going to spray the MDF bits metallic before I actually glue it together though. Oh, another nice thing is that you can put a light inside (just don't glue it to the base board, so you can get to the light when you need to....or cut a whole in the baseboard. CORRECTION: there is a hole in the baseboard). I might do that. Or stick some glow sticks in there... Anyway, I thought I'd draw attention to the company as I'm well impressed with it so far. I'll post a pic when I've finished painting it. Mithrilforge and Brother Dallo 2 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5660088 Share on other sites More sharing options...
Kierdale Posted January 28, 2021 Author Share Posted January 28, 2021 Here’s mine after I hit it with the airbrush (black first to do the edges and the crevices, then MIG-192 Polished Metal): Next I’ll be weathering it Mars-ish before putting it together. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5660408 Share on other sites More sharing options...
Kierdale Posted February 2, 2021 Author Share Posted February 2, 2021 Weathered up, it’s done! I painted very thinned down Iron Oxide paint into (some, not all) crevices, and gave it a drybrushing as only the former would have looked like water staining. The drybrush helps to make it look dustier, but only doing a drybrush would have put red dust on edges and not in crevices, which is the opposite of what we want. Dirt’s going to build up in deep parts, not on edges. After gluing it together I hit it with some ‘Mars powder’ (ground up artist’s pastel, which I’ll need to seal when the weather permits). I’m well happy with it. :tu: It was very reasonable and turned out great. I might add an Ork banner, attached with blu-tac so it’s removable, defacing it. ;) Evil Eye and Grotsmasha 2 Back to top Link to comment https://bolterandchainsword.com/topic/250400-terrain-and-objectives-necron-building-kit/page/5/#findComment-5663142 Share on other sites More sharing options...
