Captain Semper Posted May 14, 2012 Share Posted May 14, 2012 E TENEBRAE LUX THE DARK ANGELS PAINTING CHALLENGE http://fortressofunforgiven.homestead.com/DA_Challenge_vs_SW.jpg THE CHALLENGE Here we are again... The Lion and the Wolf!Our paths have crossed countless times in the past, each time a challenge. Will you honor the tradition this time, Sons of Russ? Will you stand where the ones before you did? Or will you cower away pretending it’s not your fight? Will you dare face the full might of the First Legion? We are here. We are ready. The Unforgiven will not turn away. Will you?+++FOR THE FINAL BATTLE. FOR THE WOLFTIME+++Welcome to E TENEBRAE LUX, the Dark Angels Painting Challenge. This Challenge aims to cultivate faction loyalty and tighten the relations of members of the various forums while getting miniatures painted at the same time. E TENEBRAE LUX is structured quite differently compared to the LPC that many of you might be familiar with. It is designed to play down the inherent disadvantage of low vow-count (that some forums seem to suffer from), evening out as much as possible the chance of victory for all. It also allows for the development of strategies such as to who’s going to paint what, under the coordination of moderators or other active members of your sub-forum. Even a last minute hero might tip the balance!!!THE RULES 1. ELIGIBLE FORUMS: This challenge involves all the sub-forums that are associated with a Codex officially released by GW. See eligible forums in the “Important Stuff” section below.2. VOWS: Each participant MUST declare the sub-forum (and hence the Codex to be used) in his/her vow. That’s how his/her allegiance will be defined. You cannot pledge for the Blood Angels sub-forum for example and use Codex: Space Wolves units as your vow. One has to make a choice. This is different from the LPC where people can paint whatever they like and pledge it for whichever forum they like. Here it’s about faction loyalty! So make your choice and support your preferred faction to the bitter end! 3. LEGAL ENTRIES: Each vow should be a legal unit from the chosen Codex. It can be upgraded with any legal upgrades but WYSIWYG is required. An exception is made for dedicated transports that can be entered individually as if they were standalone entries in any Codex. Furthermore Special Characters that are used as squad upgrades can also be entered individually and are worth the “upgrade” points. If in doubt of whether your vow is legal or not, feel free to raise the question (publicly or through PMs) and you will receive the ruling of the Inner Circle before you commit. 4. THE TWIST: EXPANDING THE VOWS: Here is the twist: once the vow is complete, a new vow with additional units can be added but they should also be legal entries from chosen Codex as described above. This new vow must be clearly made according to the same format of the original vow. It should be stressed that the participant is liable for all the vows he makes. Failing one is failing all. So think carefully before stepping-up your commitment, if you fail on the second or subsequent vows all is lost! 5. THE WINNER: The sub-forum with the most points (as per relevant Codex) in the end of the event wins. As simple as that. Those that complete their vows successfully will get an amazing banner declaring their success in the Dark Angels Challenge while those that vowed for the winning forum will get the “Dark Angels Challenge Champions” banner that can wear with pride until the end of their days! Those that fail will be branded with the banner of shame until the year-end!IMPORTANT STUFF Timing of the event: E TENEBRAE LUX opening: May 15th Vow submission period: May 15th until June 15th at 22:00 GMTE TENEBRAE LUX ending: August 15 at 22:00 GMT. The format of the vow should be:“I [insert name here] answer the challenge of the Unforgiven and vow to complete [insert unit name here] from Codex: [insert Codex name here] of total value [insert point value here] on or before August 15. Success will bring eternal glory to [insert Chapter/Legion/Warband] and failure will doom me to bear the sign of damnation until the year-end” Eligible Forums:• Black Templars – Codex: Black Templars• Blood Angels – Codex: Blood Angels• Dark Angels – Codex: Dark Angels• Index Astartes – Codex: Space Marines• Liber Astartes – Codex: Space Marines• Space Wolves – Codex: Space Wolves• Ultramarines – Codex: Space Marines• ALL Chaos sub-forums – Codex: Chaos Space Marines OR Codex: Chaos Daemons• Ordos Inquisition – Codex: Grey Knights OR SoBs PDF.• Adeptus Mechanichus – IMPERIAL TITANS ONLY! (more on that in the Forgeworld section below)Forgeworld: Forgeworld entries are legal provided it is clearly stated that the unit can be used in the chosen Codex in the 40k context. They worth the points as depicted in the relevant Forgeworld publication. The only exception here is Imperial Titans. For people that want to have a go with Imperial Titans they can legitimately do so if the vow is pledged for Adeptus Mechanicus. That’s the only non-Codex entries that are legal in this Challenge and the only vows that can be pledged on behalf of the Adeptus Mechanicus.Only two pictures are required – one in the beginning (minis unpainted or primed or in very early stages of painting) and one for the finished vow. You are of course welcome to post as many pictures as you like in your WIP thread – but just two (one at the start and one at the finish) will suffice! This thread is the “Chapter House” for this event. All vows of this sub-forum should be posted in this very thread in order to be valid. This is also the place to declare vow completions and/or vow renewals. Finally posting your WIP thread links in your vow post will be tremendously helpful! This is a big event guys, so making life easier for me, will help avoid confusion and backs ‘n forths…You can also use this thread to gauge the progress of your forum (I’ll update often) and compare it with other forums in their respective threads. It will also be a good place to talk to each other as how to go about it, and organize your forum effort. I am Captain Semper and the Inner Circle has given me command of this event. I’ll be glad to answer any questions as we go along and I will keep track of all forums’ efforts. So I’m the person you need to talk to for anything regarding the procedures of this competition but Moderators still have full control of the Meltas, Flamers and Blades of Reason. And they will gladly use all of them given half a chance...May the best forum win! Dark Angels Painting Challenge/Space Wolves sub-forum First Vows Arez Bjorn count as ,Wolf Guard (6,2 bolters,2plasma pistols,2 power swords,storms shield,thunderhammer,2 wolf claws,Heavy flamer),Wolf Lord(Plasma Pistol,Wolf Claw,Wolf Tooth necklace,Wolf Tail Talisman,Runic Armor),Iron Priest(4Servitors*,WTT,WTN),Ragnar count as with 2 fen wolves,Ulrik c/a,LF pack(with leader and 1 each of heavy weapons),drop pod,LRC c/a with extra armor 1,698 COMPLETE Bjorn Stormfang Wolf Lord will have a frost weapon, storm shield, runic armor, thunderwolf and 2 fen wolves. 3 TWC all with storm shields, one with a thunder hammer and one with melta bombs 500 COMPLETE Brother Rylanor 10 man Grey Hunter Pack (2 x Melta guns (2nd free), 1 x Power Weapon, Wolf Standard, Mark of the Wulfen, Wolf Guard Battle Leader, Combi Melta, Power Fist) 315 COMPLETE CainTheHunter (f) a 10 Grey Hunter pack (Wolf Standard, Power Weapon, 2xmeltaguns and one model with the Mark of Wulfen (the old metal model)) with Wolf Guard battle leader (power fist and combi-melta) 300 COMPLETE Chapter Master Ignis Domus Njal Stormcaller (Runic Terminator Armour), Rune Priest (Power Armour, Runic Weapon), Wolf Lord (Runic Armour, Storm Shield, Thunder Hammer, Thunderwolf Mount, Wolf Tail Talisman, Wolftooth Necklace), Wolf Lord (Frost Blade, Runic Armour, Space Marine Bike, Storm Shield, Wolf Tail Talisman, Wolftooth Necklace), Wolf Lord (Belt of Russ, Bolt Pistol, Frost Blade, Runic Armour, Thunderwolf Mount, Wolf Tail Talisman, Wolftooth Necklace), Wolf Lord (Frost Blade, Runic Armour, Storm Shield, Thunderwolf Mount, Wolf Tail Talisman, Wolftooth Necklace), Wolf Priest (Crozius Arcanum, Fang of Morkai, Runic Armour, Space Marine Bike, Wolf Amulet, Wolf Tail Talisman) 1,460 Incomplete chezzie Ragnar Blackmane 240 COMPLETE commander alexander a Wolf Lord 225 Incomplete Dragan Stormwolf 5-man wolf scout squad with meltagun 85 COMPLETE Ethzor(f) Logan Grimnar, The Great Wolf 275 COMPLETE Forté Wolf Priest with Runic Armour, Wolf Tail Talisman, Wolf Tooth Necklace 135 Incomplete Gizur 1 Contemptor Cybot with 2 CCW and Cyclone and 10 Grey Hunters with 2 Plasmaguns, 1 Plasma Pistol,Wolf Standard and 1 Mark of the Wulfen 420 COMPLETE hendrik (f) grey hunter pack I: 5 grey hunters, plasma gun, wolf standard, grey hunter pack: 6 grey hunters, plasma gun,PF,wolf standard, grey hunter pack: 8 grey hunters; melta gun,PF,wolf standard, wolf guard battle leader: PF,stormbolter, wolf guard battle leader: PF, combimelta, wolf guard battle leader: PF, stormbolter, wolf tail talisman, wolf guard battle leader, TH, stormbolter, wolf tail talisman, wolf guard battle leaders; combimelta, powerfist, wolf tooth necklace, wolf guard pack: (PF,stormbolter), PW, PW 1,014 Incomplete Iacton Qruze Wolf Lord Bran Solfang 260 COMPLETE Kassill 1 Grey Hunter Squad (9x man with Wolf Standard, Melta Gun, Mark of the Wulfen) and 1 Wolf Guard Battle Leader (Power Fist and Combi Melta) 270 COMPLETE Keith Wolf Guard Battle Leader with Frost Axe, Runic Armour and a Wolf Tooth Necklace and a 5 man squad of Grey Hunters with a Power Fist, Plasma Gun and Mark of the Wulfen 250 Incomplete Keith Wolf Guard Battle Leader with Frost Axe, Runic Armour and a Wolf Tooth Necklace and a 5 man squad of Grey Hunters with a Power Fist, Plasma Gun and Mark of the Wulfen 250 Incomplete Loken86 1 squad of Long Fangs(5x Heavy Bolters, squad leader with bolt pistol and chainsword), 1 Fenrisian Wolf pack(x5) and 1 Wolf gaurd battle leader(Terminator armour,frost axe, stormbolter) 275 Incomplete Mactire a nine man grey hunter pack (1 wolf standard,1 plasma pistol,1 power fist), a six man longfang pack (1 pack leader w/powerfist, 1 x h/b,1 x plasma cannon, 1 x lascannon, 2 x m/l) and a wolf priest(combi-flamer) 480 COMPLETE Matt D a land raider, a land raider redeemer w/melta, a whirlwind missile launcher, a predator w/Heavy bolter sponsons and storm bolter, a predator w/TL las canon, las canon sponsons, and storm bolter 860 Incomplete Murcielago (f) 9 Hunters, 1 meltagun, 1 Wolf standard, and 1 Mark of Wulfen...Led by a Wolf Guard Battle Leader with Powerfist and Combi-Melta 260 Incomplete Norskman 15 blood claws with two melta guns, a plasma pistol and a power weapon, as well as a wolfpriest with a storm bolter and wolftail talisman and a dreadnought with assault cannon and a heavy flamer 483 Incomplete Pig of Sparta Lone Wolf in Tactical Dreadnought Armour and a pack of 5 Fenrisian Wolves 100 COMPLETE Rayray (f) x5 WG- TDA WC/WC x1 w/AC/PF, x8 WG- TDA TH/SS x1 w/AC/WC, x1 LW- TDA CF/SS, x1 LRR, x6 LF, 5 ML, Squad Leader w/PF, x6 Lf, 5 LC, x6 LF, 5 ML, x1 RB w/HB, SB, x10 Swiftclaw bikers, 1 w/PF, Contemptor w/extra CCW, CML, Njial Stormcaller-TDA, Wolf Priest, Rune Priest-WTN, Iron Priest- WTN, x2 Thrall servitors 3,085 COMPLETE RipherChost three Wolf Guard 54 COMPLETE Rune_Priest_Rhapsody a Wolf Priest in Power Armor with Bolt Pistol and Crozius 100 Incomplete Russ Brother 92 7 TDAWG w/ 3x TH/SS, 3x WC/WC & 1x AC/PF, 10 WG w/ 1x TDA HF/PF, 9x Jump Pack w/ 1x PF, 2x PP & 4x Melta Bombs, WL w/ TDA & Twin Wolf Claws and WGBL w/ Power Fist & Bolt Pistol, Dreadnought w/ Assault Cannon, DCCW and Heavy Flamer 1,271 Incomplete Rybnick 1x Rune Priest w/ Chooser of the Slain, 2x Wolf Guard each w/ Combi-Melta and Powerfist, 2x Wolf Guard each w/ Combi-Plasma and Wolfclaw, 8 man Grey Hunter Squad w/ Meltagun, wolf standard and Rhino, 9 man Grey hunter Squad w/ Metlagun, wolf standard and Rhino, 2x 5 man Grey Hunter Squad w/ Lascannon/TL PLasma Gun Razorback, Longfang squad w/ squad leader, 2x missile launcher and 2x heavy bolter, Longfang squad w/ squad leader, 2x missile launcher and 2x lascannon, 10x Fenrisian Wolves 1,277 Incomplete stinkenheim Land Raider Redeemer 250 Incomplete StormDragon 1 Wolf Guard Terminator pack (1 TH SS, 1 dual WC, 1 PF SB, 1 FA SB and 1 PW SB) 230 COMPLETE TheDevourer 1 Grey Hunter Pack (9x man with Wolf Standard, Melta Gun, Mark of the Wulfen), 1 Grey Hunter Pack (5x man with melter), 1 Wolf Scout Pack (5x man with Melter, Mark of the Wulfen), 1 Runepriest (1x man with Chooser of Slain), Lord on Thunderwolf with TH SS, 2 Rhinos and 2 Wolf Guard Battle Leaders (Power Fist and Combi Melta), 5 Longfangs with 4 Missile Launchers 1,010 COMPLETE TheLastHuzzah Ragnar Blackmane (count-as), 10 Grey Hunters, 2 Fenrisian Wolves (Svangir & Ulfgir) and a Land Raider Crusader 740 COMPLETE Theodrick Logan Grimnar, 2 Long Fang Squad Leaders, 5 Long Fangs with Rocket Launchers, 3 Long Fangs with Heavy Bolters, 1 Long Fang with Plasma Cannon, and 1 Long Fang with Laz Cannon 565 Incomplete True Son Of Russ one 10 man pack of Grey Hunters + 1 Logan Grimnar + Land Raider Crusader W/ Storm Bolter 685 COMPLETE Wolf Lord Kejl 6 Wolfguard in Power Armor (2X Combi-Flamer / Power Weapon, Storm Bolter / Frost Axe, Pair of Wolf Claws, Thunder Hammer and Storm Shield, Bolter / Power Weapon)\ and their Razorback transport (Hunter Killer Missile, Twin Linked Lascannon, Dozer blade) 316 Incomplete Wolf Lord Kieran (f) Njal Stormcaller in TDA, Ragnar Blackmane, 2 packs of 10 Grey Hunters with double plasma guns, MotW, Wolf Standard and Power Fist, a Wolf Scout pack of 5 with 1 plasma pistol, 1 power weapon and melta gun, a Land Raider Redeemer, a Land Raider Godhammer, 2 Venerable Dreadnoughts, 1 with Assault Cannon, 1 with Lascannon, Rune Priest in runic armor, plasma pistol, wolf tooth necklace, melta bombs, Chooser of the Slain, wolf tails talisman, Wolf Lord on TWM in runic armor, frost axe, storm shield, melta bombs, wolf tail talisman, wolf tooth necklace, 5 Wolf Scouts, 2 plasma pistols, plasma gun, melta bombs, MotW, 2 Thunderwolf Calvary, both with storm shields, 1 with a thunder hammer, Wolf Guard Pack (7) in tda, Arjac, 2 Chainfist/Stormbolter, 1 Power fist/Assault Cannon, 3 Wolf Claw/Storm Shield, Wolf Guard pack (6) in pa, 2 with power fist, 1 with wolf clawsx2, 2 with storm shields, 1 with MotW, Lone Wolf in pa with Power fist and storm shield, Long Pack Pack, 2 Lascannons, 3 Plasma Cannons, Long Fang Pack, 2 Lascannons, 3 Plasma Cannons 3,999 COMPLETE Wulfebane a Rune Priest in TDA with a retinue of 3 Wolf Guard (including Arjac Rockfist) 452 COMPLETE Dark Angels Painting Challenge/Space Wolves sub-forum Second Vows Arez Njal Stormcaller(RTDA),Wolf Lord(TDA,Thunder sword(Hammer),WTT,WTN,BoR),RP(TDA,WTN,MoR,CotS),10 WG(10x TDA,7x PF,1x CF,2x WC,Arjac,1x Assault Cannon,1x Heavy Flamer 1,295 COMPLETE Bjorn Stormfang one Wolf Priest in terminator armor and two Iron Priests on Thunderwolves 310 COMPLETE Ethzor(f) a Wolf Lord with Runic Armour, Wolf Tail Talisman, Belt of Russ and a Frost Blade and a Wolf Priest with Runic Armour and a Wolf Tail Talisman 300 COMPLETE Gizur 1 Wolfpriest in TDA,1 Wolfguardbattleleader in PA with Powerfist,9 Greyhunters with Plasmaweapon and Mark of the Wulfen, 3 Thunderwolf Kav. with Powerweapon and Stormshield and a Landspeeder with MultiMelta and Heavy Flamer 640 COMPLETE Iacton Qruze Wolf Lord on Thunderwolf, Runic Armor, Power Fist, Storm Shield, Wolf Tooth Necklace, Wolf Tail Talisman, 5 Grey Hunters, 1 Plasma Gun, 1 Wolf Banner, 1 MotW, 1 Power Axe 360 COMPLETE Kassill 2 Rune Priests (1 with Wolf Tail Talisman and Runic Armor and the other with Wolf Tooth Necklace, Wolf Tail Talisman and Runic Armor), 1 Grey Hunter Pack (9x man with Melta Guns, Wolf Standard and Mark of the Wulfen) and 1 Vindicator (with Siege Shield 565 Incomplete Mactire 2 x lone wolfs [both in TDA, 1 x TH & stormshield, 1 x TH & chainfist] 170 COMPLETE Rayray Ragnar Blackmane, Logan Grimnar, x2 Wolf Guard TDA w/ TH and SS, x2 Wolf Guard TDA w/FW and SS, Arjac Rockfist, x2 Wolf Guard w/twin LC, x2 Wolf Guard w/ PF and bolter, x1 Wolf Guard w/ PF and bolt pistol, x1 Wolf Guard Battle Leader w/ SS, FW and wolf tooth necklace, x1 Wolf priest w/wolf tooth necklace 1,435 COMPLETE StormDragon 8 Grey Hunters (with mark of the Wulfen and power weapon) and a Wolf Guard Battle Leader (with wolf claw and combi-flamer) 250 COMPLETE TheLastHuzzah 1 Logan Grimnar 275 COMPLETE True Son Of Russ a Long Fang pack of 5 w/squad leader it will contain 2 lascannons, 2 heavy bolters, and one plasma cannon the squad leader will have a PF and bolt pistol and melta bombs. 200 COMPLETE Wolf Lord Kieran (f) Logan Grimnar counts as, Bran Redmaw counts as, Njal Stormcaller in power armor, Lone Wolf in TDA with chainfist and storm bolter, a 5 strong Long Fang pack with 4 missile launchers and a Vindicator Tank with a siege sheild and extra armor 1,045 COMPLETE Wulfebane Wolf Lord (TDA, Combi-plasma, Powerfist, Wolftooth necklace, Belt of Russ) 190 COMPLETE Dark Angels Painting Challenge/Space Wolves sub-forum Third Vows Arez a Wolf Lord (BoR,RA,PF), WGBL(TH,RA,SotH,bolter), WGBL(FW,bolter,SotH), 5 scouts(5 bolters,MB,2 PP), 10 WG (9 bolters,1 TDA,1 AC,1 CML), 5 Scouts(5 snipers), Lone Wolf(SS,PF),Ven Dread(EA,MM,ML), 6 LF(2 ML,3 HB) 1,295 COMPLETE Ethzor (f) 10 Wolf Guards (Dual Plasma Pistols, Twin Wolf Claws, Power Fist & Storm Bolter, Frost Axe & Bolt Pistol, Storm Shield & Storm Bolter, Plasma Pistol & Frost Blade, Frost Blade & Bolt Pistol, Terminater Armour, Combi-Melta & Power Fist, Terminator Armour & Cyclone Launcher, Terminator Armour, Cyclone Launcher & Chain Fist) 486 COMPLETE Rayray WL (SS, PF, RA), WL (TLC, WTN, BOR, RA), WP (Bike, WTN), WP (TDA, Combi-plasma), (WP- Jump pack, PP), Lukas the trickster 925 COMPLETE True Son Of Russ 3 Lone Wolves two with Chain Fists and Storm Shields in TDA and one with x2 Wolf Claws in TDA 235 COMPLETE Wolf Lord Kieran (f) Wolf Lord on TWM with wolf claws x 2, runic armor, Belt of Russ, melta bombs, wolf tooth necklace, wolf tail talisman, Iron Priest with wolf tail talisman, wolf tooth necklace, Thunderwolf Cav x1, storm shield, Wolf Guard in PAx8, 2 with wolf claws, 2 with frost weapons, 2 with power fists and 2 with dual plasma pistols, Contemptor Dreadnought with carapace missile launcher, wolf tooth necklace, wolf tail talisman, heavy flamer, extra armor, search light 995 COMPLETE Dark Angels Painting Challenge/Space Wolves sub-forum Fourth Vows Arez 10 wolf Guard(7 power weapons,2 wolf claws,1 Thunder hammer,1 Storm shield,4 storm bolters,1 plasma pistol,3 bolters,10 Jump packs) and a Wolf Priest(jump pack,Plasma pistol) 732 COMPLETE True Son Of Russ 1 Lone Wolf in TDA with Thunder Hammer and Storm shield 85 COMPLETE Dark Angels Painting Challenge/Space Wolves sub-forum Fifth Vows Arez Logan c/a*,14 BC(1 plasma gun and 1 melta), and a RP(RA) 620 COMPLETE True Son Of Russ 1 Wolf Lord in TDA with a Belt of Russ, Wolf Tail Talisman, Wolf-tooth Necklace, Frost Blade, and Storm Bolter 190 COMPLETE Dark Angels Painting Challenge/Space Wolves sub-forum Sixth Vows Arez a Predator with TLLC and LC side sponsons with EA,SB,Dozer blade 195 COMPLETE True Son Of Russ 1 Wolf Lord in TDA with a Belt of Russ, Wolf Tail Talisman, Wolf-tooth Necklace, Thunder Hammer, and Storm Shield 220 COMPLETE Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/ Share on other sites More sharing options...
Brother Mjollner Posted May 14, 2012 Share Posted May 14, 2012 Wont this drive people to painting characters over units?? If I paint Logan, he's what 270? (no codex on hand). Thats well over a unit of Grey hunters.. hummm paint one mini or 10+ for the same points? I think the challenge is great in itself... but I think the scoring of the challenge is a little lopsided... maybe break it down power armored mini 5 pts. termi armored mini 10 pts rino based 35pts (razorback/vindi/pred) landraider 50pts something like that I would think. Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061247 Share on other sites More sharing options...
The Shadow Guard Posted May 15, 2012 Share Posted May 15, 2012 Wont this drive people to painting characters over units?? If I paint Logan, he's what 270? (no codex on hand). Thats well over a unit of Grey hunters.. hummm paint one mini or 10+ for the same points? I think the challenge is great in itself... but I think the scoring of the challenge is a little lopsided...maybe break it down power armored mini 5 pts. termi armored mini 10 pts rino based 35pts (razorback/vindi/pred) landraider 50pts something like that I would think. Well, we think it's a lot less lopsided than the standard LPC where a single miniature or an entire army counts as a sigle vow. The LPC that the B+C runs is essentially a motivator for hobbyists to do some painting. We've taken it a little further as an inter-forum challenge... and you are certainly right in that there may be a profusion of characters being painted but every forum can do that so it should even out across the boards... .... besides, none of us will complain about seeing a large number of character models being painted... :P SG Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061359 Share on other sites More sharing options...
Toasterfree Posted May 15, 2012 Share Posted May 15, 2012 do we PM vows? Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061389 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 Wont this drive people to painting characters over units?? If I paint Logan, he's what 270? (no codex on hand). Thats well over a unit of Grey hunters.. Well, think of it this way: In the LPC SWs, the most active forum, only came up with 20-odd vows. Now against a forum with double the amount of committed people it would by almost impossible to win. So this way, forums with low vow counts can choose to paint point-rich models to make it up. By all means paint Logan. do we PM vows? No. Vows should be there for all to see. You have to post them in this thread (if you vowing for the wolves that is ). However if you have questions regarding the rules or the legality of ther vow you send me a PM or indeed ask here again - no prob. Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061402 Share on other sites More sharing options...
Toasterfree Posted May 15, 2012 Share Posted May 15, 2012 sadly i will not be vowing wolves Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061408 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 Fine by me! You have to go to the similar thread in the forum you'll be vowing for and make the vow there... Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061413 Share on other sites More sharing options...
Forté Posted May 15, 2012 Share Posted May 15, 2012 I take it the Mods have agreed to this? Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061422 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 Yes. Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061434 Share on other sites More sharing options...
Khine Posted May 15, 2012 Share Posted May 15, 2012 If i did a vow for Codex: Space wolves and then My own chapter. Would that negatively impact the space wolves? Do i have to complete the paint job in space wolves colours in order for the space wolves to get the credit? Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061464 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 Your own chapter, does it use SW Codex? If so, paint them anyway you like. As long as you choose a unit from SWs codex and it's reasonably WYSIWYG you can vow for SW, no problem. Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061497 Share on other sites More sharing options...
Matt D Posted May 15, 2012 Share Posted May 15, 2012 if i do this it will probably be my terminators. there arms are magnetized though. do i get the points for the extra arms? Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061686 Share on other sites More sharing options...
Kassill Posted May 15, 2012 Share Posted May 15, 2012 “I Kassill answer the challenge of the Unforgiven and vow to complete 1 Grey Hunter Squad (9x man with Wolf Standard, Melta Gun, Mark of the Wulfen) and 1 Wolf Guard Battle Leader (Power Fist and Combi Melta) from Codex: Space Wolves of total value of 270pts on or before August 15. Success will bring eternal glory to the Vlka Fenryka and failure will doom me to bear the sign of damnation until the year-end” I'll start small for now, and depending on how quickly and efficiently I get them down will determine any more vows. Come Son's of Russ! Let's show these lads how we do it! -_- Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061716 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 Well, Kassil seems to be brave enough to take on the Challenge - with 208 points no less!!! Is he a Lone Wolf though? :) Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061805 Share on other sites More sharing options...
DanPesci Posted May 15, 2012 Share Posted May 15, 2012 Damn, ive literally just finished painting up about 3000 points worth of space wolves over the last 2-3 months. All I have left is some fenrisian wolves (which are old goblin rider models without goblins) and an old ragnar model. Have my eye on a couple things though so might take a vow next week :P Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061828 Share on other sites More sharing options...
Ezeriel Posted May 15, 2012 Share Posted May 15, 2012 “I Bjorn Stormfang answer the challenge of the Unforgiven and vow to complete a Wolf Lord on Thunderwolf and a 3 man pack of Thunderwolf Cavalry from Codex: Space Wolves of total value of 500 points on or before August 15. Success will bring eternal glory to Vlka Fenryka and failure will doom me to bear the sign of damnation until the year-end” Wolf Lord will have a frost weapon, storm shield, runic armor, thunderwolf and 2 fen wolves. Saga and WTN not included since they aren't shown on model. TWC is 3 guys all with storm shields, one with a thunder hammer and one with melta bombs. Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3061833 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted May 15, 2012 Share Posted May 15, 2012 Can one signup for more than one vow?? As in I already vowed over in the choas forums (yes, my decent has been rapid, or rabid. You decide...) and I want to also support my brothers here as well!! Can this be done oh mighty dress wearing organizers?? ;) End of Line Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062006 Share on other sites More sharing options...
Captain Semper Posted May 15, 2012 Author Share Posted May 15, 2012 Can one signup for more than one vow?? As in I already vowed over in the choas forums (yes, my decent has been rapid, or rabid. You decide...) and I want to also support my brothers here as well!! Can this be done oh mighty dress wearing organizers?? :P End of Line I'm afraid not... You have to stick to one faction - this is about faction loyalty! :( So paint Chaos till you drop - I'm sure the Wolves will wake up and catch up! ;) Off course you can withdraw the your vow from Chaos if you want and commit with the Wolves... But I'd avoid dark alleys at night if I were you! Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062016 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted May 15, 2012 Share Posted May 15, 2012 I've got over 2K worth of painted wolves. My World Eaters are the new project and need some serious love, er, blood. Sorry brothers but this ones going to chaos. Thanks for the clarification Captain Semper!! ...besides, they promised me bunnies for the bunny god!! End of Line Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062049 Share on other sites More sharing options...
Russ Brother 92 Posted May 15, 2012 Share Posted May 15, 2012 I shall have a wee nosey at my collection and put up a vow - it shall be as follows (likely so not actual vow) 5-10 scouts (2 HB's) totalling 160pts and 10-20 GHs (2 Plasmas + 2 Standards) totalling 340pts - overall around 500pts. also - where project shown is concerned, is it okay if the models are already in 1 colour? - it's not their final colour, just base coat equivi. and do we need to put up pictures through the whole process akin to the LPC doodah? either way, thanks chaps. Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062173 Share on other sites More sharing options...
Loki-LaughingDeath Posted May 16, 2012 Share Posted May 16, 2012 “I Loki Laughing Death answer the challenge of the Unforgiven and vow to complete The Near Thralls (10 Sky Claws with a Plasma Pistol Power Weapon and Mark of the Wulfen) Cormac Red Wind (Wolf Priest with Jump Pack and Wolf Tooth Necklace) and Canis Wolf Born from Codex:Space Wolves of total value 545 points on or before August 15. Success will bring eternal glory to The Space Wolves and failure will doom me to bear the sign of damnation until the year-end” Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062288 Share on other sites More sharing options...
Arez Posted May 16, 2012 Share Posted May 16, 2012 I Arez answer the challenge of the Unforgiven and vow to complete my Bjorn count as ,Wolf Guard (6,2 bolters,2plasma pistols,2 power swords,storms shield,thunderhammer,2 wolf claws,Heavy flamer),Wolf Lord(Plasma Pistol,Wolf Claw,Wolf Tooth necklace,Wolf Tail Talisman,Runic Armor),Iron Priest(4Servitors*,WTT,WTN),Ragnar count as with 2 fen wolves,Ulrik c/a,LF pack(with leader and 1 each of heavy weapons),drop pod,LRC c/a with extra armor from Codex: Space Wolves of total value 1698 on or before August 15. Success will bring eternal glory to the 6th Legion of the Adeptus Astartes and failure will doom me to bear the sign of damnation until the year-end. *I know Iron Priests are only allowed 3 but i have the 2 servitor metal blister and one has a heavy bolter but i wont be using it all the time so i need one to fill in every so often . Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062323 Share on other sites More sharing options...
Captain Semper Posted May 16, 2012 Author Share Posted May 16, 2012 I shall have a wee nosey at my collection and put up a vow - it shall be as follows (likely so not actual vow) 5-10 scouts (2 HB's) totalling 160pts and 10-20 GHs (2 Plasmas + 2 Standards) totalling 340pts - overall around 500pts. also - where project shown is concerned, is it okay if the models are already in 1 colour? - it's not their final colour, just base coat equivi. and do we need to put up pictures through the whole process akin to the LPC doodah? either way, thanks chaps. Yes, if they are in early stages of painting it's fine! Re:photos as it is mentioned above, we only require two - one in the beginning and one in the end!!! Look fwd for your vow! ALSO now there is now a table in the bottom of the first post that includes all the vows of the brothers of the furry kind! :P Check them out - let me know if there is a prob. There are similar such tables in all sub-forums that participate - so you can check out your progress relative to the others. Names are in alphabetical order. I intend to update regularly (initial intention is daily). Am I good or what? :) Keep your vows coming guys, although you have some serious points already, weight of numbers also has a part to play. Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062344 Share on other sites More sharing options...
Russ Brother 92 Posted May 16, 2012 Share Posted May 16, 2012 Brill and Thanks Capt. Semper “I Russ Brother 92 answer the challenge of the Unforgiven and vow to complete The Gravespite Heroes (7 TDAWG w/ 3x TH/SS, 3x WC/WC & 1x AC/PF), Sky Reavers (10 WG w/ 1x TDA HF/PF, 9x Jump Pack w/ 1x PF, 2x PP & 4x Melta Bombs), "Halvar One-Eye" (WL w/ TDA & Twin Wolf Claws) and Battle Leader Harald Skarssenson (WGBL w/ Power Fist & Bolt Pistol) born unto the Fire and Ice of Mother Fenris (C:SW) to the total of 1156 Points on or before August 15th 2012, success will bring eternal glory to the Vlka Fenryka, VI Legion and Space Wolves Chapter. Failure will carry nought but doom and despair to all who know me... If I fail I must bear penitence and carry the sign of damnation until the years-end” HE...HE...HE big enough for ya dress-wearer? :P Okay - as of 20th May 2012 I'm adding in a "Old Kurgan" (Dreadnought w/ Assault Cannon, DCCW and Heavy Flamer = 115pts thus my total becomes - 1271 Points Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062490 Share on other sites More sharing options...
Kassill Posted May 16, 2012 Share Posted May 16, 2012 Link to my thread with progress so far. ;) Link to comment https://bolterandchainsword.com/topic/252373-e-tenebrae-lux/#findComment-3062704 Share on other sites More sharing options...
