Rhino to razor conversion
DominicJ
There are a few kits floating around in the interwebs if you need a turret. I created a thread quite a while ago and there are quite a lot of options, you should search for it.
Personally, I use stormraven landing pads to make a turret and glue them on a regular 25mm base, then magnetize SR lascannon/plasmacannon to make a LC/TLPL turret^^
Just buy thins:
http://www.games-workshop.com/gws/catalog/...dId=prod1280042
It'll work out cheaper in terms of time and money, and will look better than most other conversions.
You also get pred sponsons, so you can convert your rhino to a pred also.
What size is the turret ring on a razor? The size of a 25mm base? If so, grab some spare heavy bolters, chop off the muzzle, and glue on some assault cannons and stick the whole thing on a base. Not the best looking conversion, but fast and easy.
It's GW, have a guess.. its smaller than a 40mm base but larger than 25mm, lest you could make easy conversions :huh: I still use small bases though and magnetize them to a bar set to the lower side of the roof, the gap is not very big so it looks good.
Bolter back?
Basicaly a gunner with two heavy bolters on the pintel mount.
Would everyone be cool calling that a bolterback?
Ok, the specific tank is a vindie, but if it were Rhino?
Shouldnt be a problem for me to knock up half a dozen of those ;)
