Devolver Posted December 5, 2012 Share Posted December 5, 2012 Just curious on how you paint a marine with a split scheme. eg like the Omega Marines Would getting thin masking tape be the easiest or is their another way, i dont really have an overly steady hand, well not enough to paint a perfectly strait line. Link to comment https://bolterandchainsword.com/topic/267137-a-painting-question/ Share on other sites More sharing options...
The Sound of Machines Posted December 5, 2012 Share Posted December 5, 2012 Tape would be a little hard to use over those rough and round surfaces mate. You could use a piece of card as a mask to spray the second colour, but you'll need to go in by hand to tidy up the line I reckon. Just do section by section and I reckon you'll be fine. Oe more thing, paint black over white, not the other way round! Link to comment https://bolterandchainsword.com/topic/267137-a-painting-question/#findComment-3253746 Share on other sites More sharing options...
Devolver Posted December 5, 2012 Author Share Posted December 5, 2012 Cheers Mate! thought tape would be a little hard :D With luck ill figure it out and have a decent looking army! thanks :) Link to comment https://bolterandchainsword.com/topic/267137-a-painting-question/#findComment-3253884 Share on other sites More sharing options...
AnthonyVG Posted December 5, 2012 Share Posted December 5, 2012 http://www.amazon.com/Stick-Reusable-Adhes...k/dp/B004RHR9WY I use this when test-assemble and sometimes when I spray paint to prevent color from adhering to particular areas. It's cheap and the spray paint doesn't damage it, meaning you can re-use it multiple times. Just be aware, I had some off-brand version of this that melted the object it was holding together, no clue what happened there. Link to comment https://bolterandchainsword.com/topic/267137-a-painting-question/#findComment-3254090 Share on other sites More sharing options...
latch66 Posted December 5, 2012 Share Posted December 5, 2012 Using "Silly Putty" to mask it might work. I wouldn't count out freehand yet. It might be the best method. Link to comment https://bolterandchainsword.com/topic/267137-a-painting-question/#findComment-3254156 Share on other sites More sharing options...
