Iron Warrior w/ Servo Arm Posted December 14, 2012 Share Posted December 14, 2012 Hi all, so I am trying to paint my Iron Warriors again after hating my old paint jobs. But I ran into the same problem again. My models look oily and I thinned down my paints a lot, applying multiple coats. For those of you who managed to get the really crisp looking effects. How do you do it? This is what I did: 1. Black primer 2. Drybrush Boltgun metal, thinned down 3. Nuln oil wash 4. Drybrush Natural Steel (vallejo) to make model brighter 5. Apply thin coat of Warplock Bronze to trims 6. Drybrush Hashut Copper on trims 7. Drybrush Gold (Vallejo) on trims The results are as following.... So, any help will be greatly appreciated. Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/ Share on other sites More sharing options...
Chaeron Posted December 16, 2012 Share Posted December 16, 2012 Doesn't look oily really to me! But, coats of Nuln Oil and Agrax Earthshade should take that right down if you're concerned. They're the two I use to make my models look acceptable. Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3262463 Share on other sites More sharing options...
HellChyld Posted December 17, 2012 Share Posted December 17, 2012 do you mean oily by shine or tint? I think the model looks fine some slight highlights might change the look your after but alittle more description might help Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3262927 Share on other sites More sharing options...
The Sound of Machines Posted December 17, 2012 Share Posted December 17, 2012 Yeah, I can't see the problem mate - they look awesome. Perhaps use some matt medium in with your painting mix? Perhaps not use the Vallejo and change the colour to another silver - if that's the last layer you're applying, perhaps the problem lays with that? It is funny though, using Nuln Oil and worrying about oiliness. I know that's not what's causing it, but still :D Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3262980 Share on other sites More sharing options...
Iron Warrior w/ Servo Arm Posted December 17, 2012 Author Share Posted December 17, 2012 I meant the oily texture due to the shine. I originally thought it was the first coat of drybrush of boltgun metal. So I tried to use a coat of Boltgun without drybrushing. It's still kind of there. I like the matt medium suggestion. Maybe mix that with Chaos Black? This is what a model looks like after the Nuln Oil wash. Do you guys have any suggestion on what type of final drybrush to use instead of Vallejo? Thanks for all the replies! Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3263426 Share on other sites More sharing options...
Lorenzen Posted December 17, 2012 Share Posted December 17, 2012 If you want a flatter finish spray them with satin varnish. Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3263468 Share on other sites More sharing options...
Iron Warrior w/ Servo Arm Posted December 18, 2012 Author Share Posted December 18, 2012 If you want a flatter finish spray them with satin varnish. Any brands you would recommend? I did a quick google search and I think it might work! Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3263655 Share on other sites More sharing options...
Chaeron Posted December 18, 2012 Share Posted December 18, 2012 If you want a flatter finish spray them with satin varnish. Any brands you would recommend? I did a quick google search and I think it might work! I'd just recommend any Satin or Matte - both are equally likely to take it down, although the latter would be my preference. Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3263665 Share on other sites More sharing options...
Bartali Posted December 18, 2012 Share Posted December 18, 2012 Matt varnish does kill metallics making them more grey looking - which is fine if that's the effect you're after. Satin keeps the metallic look. I recommend Vallejo Varnishes either through an airbrush or their spraycans. Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3263996 Share on other sites More sharing options...
Brother Nihm Posted December 18, 2012 Share Posted December 18, 2012 If you want a flatter finish spray them with satin varnish. Any brands you would recommend? I did a quick google search and I think it might work! I'd just recommend any Satin or Matte - both are equally likely to take it down, although the latter would be my preference. +1 Hit them with matte varnish and watch that sheen go bye bye. Also remember to shake the can for at least 5 minutes straight before spraying (not kidding!), dont spray too close, several ultra thin layers are preferable to one thick/gunky one, dont spray in humid or cold weather. Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3264028 Share on other sites More sharing options...
Lorenzen Posted December 18, 2012 Share Posted December 18, 2012 i use winsor and newtons satin varnish through an airbrush.. so not a viable recommendation unless you're willing to start down the airbrush route. Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3264037 Share on other sites More sharing options...
Chaeron Posted December 18, 2012 Share Posted December 18, 2012 If you want a flatter finish spray them with satin varnish. Any brands you would recommend? I did a quick google search and I think it might work! I'd just recommend any Satin or Matte - both are equally likely to take it down, although the latter would be my preference. +1 Hit them with matte varnish and watch that sheen go bye bye. Also remember to shake the can for at least 5 minutes straight before spraying (not kidding!), dont spray too close, several ultra thin layers are preferable to one thick/gunky one, dont spray in humid or cold weather. This man speaks the truth! I've only used GW's Purity Seal extensively in past, and that provides a "semi-matt or satin finish" - which may be the ideal compromise! Link to comment https://bolterandchainsword.com/topic/267776-trying-to-get-models-to-be-less-oily-looking/#findComment-3264081 Share on other sites More sharing options...
