DW Knights or DW command squad?
Tiger9gamer
so, We know most of the things for both squads thanks to leaks, and with the codex coming out tomorrow It's a perfect time to try and make up my mind over this. Both squads would be in a land raider crusader
So, the Command squad I'm thinking of will be x3 TH/SS, x1 champion w/ halberd of Caliban, and either a plasma cannon, Apothecary or maybe the DW banner. with the leaked point cost it would be
-255 for plasma cannon squad
-270 for apothecary
-285 for banner
Or the DW knights which are 235pts.
I like the idea of the "str 8 AP2 all the time" command squad, and would be perfect for a captain in terminator armor to ride with.
which do you guys think would be better?
https://bolterandchainsword.com/topic/269303-dw-knights-or-dw-command-squad/
From looking at the leaked images, you trade the PF for a narthecium on the Apothecary.
It's an odd predicament as being an Apothecary, he is also listed as a character, yet he winds up with no melee weapon. You pretty much have to take the Champion too to accept challenges. Of course your HQ will probably be with this squad anyway to do that.
I suppose you can just say you bought the TH/SS first, lol - so then when you upgrade to an Apothecary he has to drop his PF (per the rule) that he doesn't have anyway for a narthecium.
Why only one of then, i think test a army with booth of then. The knights are really great as C&C unit to kill some hard units, they have the wall of shields and their redeption maces. The comand squad is better the old one and it worked great in all armys based in the DW.
I'm gonna wait to see the Codex before I make this sort of decision. Both units have their merits, and I guess DW Knights will suit one kind of player's play style more than another's, and vice versa.
To be honest it's a nice problem for the DW to have - after the sterility and lack of units in the 4th Ed book - isn't it ? :D.
Cheers
I
I'll be rather upset if the Apothecary really can't keep his CC weapon. The one I converted for my November Oath had the squad's Chain Fist as well. Hopefully I'll be able to fenagle a Chain Fist on the Apothecary as an upgrade still...
(Give termie a chain fist, then upgrade it to Apothecary, no power fist to lose?)
The Apoth loses PF to get Narthecium. Upgrade him this way though and he still has a SB. Upgrade with 30 pts LC/LC or TH/SS is impossible, because that's for Deathwing Terminators, he isn't one anymore. But "any model can replace his power fist with a chainfist for 5 pts", so the CF + Narthecium for 35 pts seems legit :P
I'm personally probably going to run both. Mainly because I have a nice command squad already done smile.gif
But if I had to pick, without looking at the codex and only knowing about internet "confirmations." I would have to do the Knights. The look of cool and the S10 AP2 once per game rule is the one that would push me over the top.
Though in all honesty, Isiah is right. It's only a little less than a day away till release, we should all probably sit tight and wait.
I've seen the new dex and sadly the entry states "One Deathwing Terminator may be upgraded to a Deathwing Apothecary, replacing their power fist with a narthecium". If you have no power fist to replace this wording would imply you don't get the narthecium. It just seems to me that the intention is to lose the CC weapon unsure.png .
I'm not sold on the DW Command squad. They are good, especially the Champ with the Halberd, but paying 255 points for the squad with apothecary and Champion seems a lot when you lose a Power Fist with the Apothecary upgrade. This is especially true when you consider the "Fortress of Shields" special rule that the DW Knights get, which can give them (and a member of the inner circle in base contact) +1 T if they line up correctly on the table. I'm thinking Belial in TH/SS or LC config with the Knights is doable, as Toughness 5 is quite useful for him!
Yea, I could just take A DW squad instead or the command squad. be about the same points, only lacking the champion (which would get an extra TH/SS)
The knights are looking a lot better though. Compared to the command squad, they can put out a ridiculous amount of punch. might try them just for fun.
Anyone with the new DWK/DWC box yet? There are enough bitz to make either set. What additional parts would be needed to make both sets? Is it possible to go to one of the chop shop bitz sites and order 5 more legs and 5 more back plates from a terminator spru and put together the other 5?
Hammer of wrath is all the time, smite is once per game.
Okay, I thought about it, and decides to weigh the pro's and con's.
DW command squad:
---pros
-Can take Apothecary
-Can take tons of options for mix/max
-Has a champion w/ an awesome weapon for 5pts
-Can take a banner
-doesn't take up a slot
-Can take ranged special weapons
---Cons
-Apothecary is sucky in combat
-the Banner is short range and expensive
-Must take a relatively expensive captain/HQ to unlock.
-Champion can dish out pain, but he doesn't have a good invuln save.
-Everything can be (mostly) done with DW squad.
-fixed at five guys
DW Knights
---Pros
-Toughness 5 when in base to base and are BS5
-hammer of wrath
-mauls can subtract 1AP against traitors
-All have SS for cheap.
-great HQ escort
-can take more than 5
-can take relic
---Cons
-if one terminator dies, depending on positioning, The shield wall can be broken.
-Mauls are ap4 when not fighting chaos or in smite mode
-fixed weaponry
Both things look good, and the knights do seem to have a lot of pros. anything I missed?
Judging from the images on GW site, it should be doable. Plus, you can get some legs from DA Veterans box.
I'm not sure on the shoulder pads, but again, veteran box have some, just in case.
Ya know, I'm really pumped for a Plasma Terminator squad, but given my track record with it, I think I'd only take it as the second heavy weapon in a 10 man DW squad.
As for Knights or Command Squad... why not both? :)
6th is more of a shooting edition then close combat, and with all the options available for shooting, I just don't see a SS/TH squad being used all that much by Dark Angels. I have to caveat that statement with the fact that I don't have the codex yet. It's a tough squad, but lacks some mobility unless you give it a Land Raider. I have this vague thought forming in the back of my mind, and it's just not taking shape yet (probably not enough coffee!). Around here, I'm seeing less and less SS/TH squads. When they do come out, they get thrown into combats that just grind them out, and trap them in place until the end of the game. I dare say the time of SS/TH may be coming to an end...
The Box Set is full of good stuff (including all 4 heavy weapon options). You do just need extra legs (and I think most of us have got extras on the DA upgrade sprue) and Termie back boxes to make an extra unit (with some limit on what you take).
I don't think the DW Apoth is worth it, really - 30pts + the loss of the 25pt PF, that's not that far off adding the FnP banner, if you're not taking a different one. The plus side to the Apoth is that he's a character that can be sacrificed in a challenge, if needs be.
They should have at least tossed him a power weapon in my opinion. Maybe I'll model one with a chain sword just for kicks as it feels odd he wouldn't have some form of CC weapon. Even you standard marine has a blade fluff wise (not that it gives you any bonus).
The Narthecium does have a drill on the end pinch.gif ;).
