scatmandoo Posted September 5, 2014 Share Posted September 5, 2014 Love it, looks really good. steellegionnaire85 and walter h 2 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3801415 Share on other sites More sharing options...
Nicodemus Doloroso Posted September 5, 2014 Share Posted September 5, 2014 Impressive ... Most impressive. That is one fantastic looking Valkyrie. How did you do the weathering? I especially like that and want to try it on my own Valk if I can. Bravo! walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3801469 Share on other sites More sharing options...
Kierdale Posted September 5, 2014 Share Posted September 5, 2014 Great work! The door gunners stay in via magnets? walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3801509 Share on other sites More sharing options...
JaM_TW Posted September 6, 2014 Share Posted September 6, 2014 I dont post a lot here nowadays, but do read/follow some threads. Like this one. Really nice! If I'd ever buy and paint a Valk and it would turn out half as good as this, I'd be as happy as a Guardsman with a cup of recaf and a lho-stick in the morning. Allright, back to lurking... walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3801736 Share on other sites More sharing options...
WarriorFish Posted September 6, 2014 Share Posted September 6, 2014 Excellent work, there's really nothing else to say except well done! :D Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3801849 Share on other sites More sharing options...
elmo Posted September 6, 2014 Author Share Posted September 6, 2014 @scatmandoo: Thanks very much :) @Nicodemus Dolorosus: Can also be used for tanks by changing the direction of the brush to simulate the paint damage and oil stain. Drybrush matt black starting from the wing edge and drawing it in one smooth motion in the direction you want (ie towards the rear to simulate flight wear). Repeat with slightly less boltgun metal then again with less chainmail. For the dirt I use burnt umber oil paint. Use a normal brush to paint a line of umber along a hinge or armour joint. Allow to dry off for about an hour then, using a drybrush, again draw the brush in the direction you want the dirt to flow. The oil paint takes a lot longer to dry and mine has been known to still be wet after a couple of days but using a hairdryer can speed it up. @ Kierdale: They are not magnetised at the moment. The bolters are glued to the torso then they simply slot into the swivel on the mount. I may magnetise the mount later if this does not work out so well. @Flint&Steel: Thanks, now get back to your lurking but make mine a double recaf with extra foam @WarriorFish: Next up is another Leman Russ BT and a Chimera. Both magnetised (of course ;)) Kierdale, WarriorFish and walter h 3 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3801918 Share on other sites More sharing options...
elmo Posted September 8, 2014 Author Share Posted September 8, 2014 Apologies to whoever it was who asked on another thread but I just can't find it so I will post it here... I use Rico Design Bérgamo Burnt Umber (no. 7021.200) in a 60ml tube. New on the painting desk... The work so far on the magnetised Leman Russ Battle Tank and Magnetised Chimera http://i814.photobucket.com/albums/zz66/jonbrooks_photo/IMAG0565_zps312262b8.jpg WarriorFish and walter h 2 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3803968 Share on other sites More sharing options...
CoffeeGrunt Posted September 8, 2014 Share Posted September 8, 2014 Apologies to whoever it was who asked on another thread but I just can't find it so I will post it here... I use Rico Design Bérgamo Burnt Umber (no. 7021.200) in a 60ml tube. Lucky I religiously check this thread! How do you find oil paints, what are their strengths and weaknesses in your opinion? Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3803988 Share on other sites More sharing options...
elmo Posted September 8, 2014 Author Share Posted September 8, 2014 I can only speak from experience of using devlan mud and Agrax Earthshade prior to switching to oil paint. To quote from Imperial Armour, Model Masterclass, Volume one, Page 9 Oil Paint A traditional form of paint used by artists. For model painting it is primarily used with white spirit to make washes. A characteristic of this type of wash is that it can be manipulated, removed (with more white spirit) and blended because it takes a few hours to dry. It adds richness and depth to shading. Advantages of oil: Far cheaper by volume (60ml oil 4-5€, 12ml GW 2.50-3€) slow drying so easy to work with Can be mixed with weathering powders for additional effects Disadvantages: You ideally need separate brushes Slow drying so you have to be patient (can take up to a week to be fully dry) Technique from IA Using oil paint A thinned mixture of oil paint was painted in and around all rivets and details. The thinner in the oil paint was left to evaporate, this took about an hour. A hair dryer can reduce this time to less than a minute.The remaining oil paint was then softened and blended into the vehicle's surface with a small dry brush, a small amount of clean white spirit was used to dampen the brush. Extra thinner is not usually needed because of the gloss surface allows the oil paint to be easily manipulated until the paint has fully cured. The oil paint was dragged and blended downwards recreating the effect of rain streaking. I would recommend giving it at least a try. It has vastly improved my models. Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3804008 Share on other sites More sharing options...
CoffeeGrunt Posted September 8, 2014 Share Posted September 8, 2014 I'll hit up an arts and crafts store some time, thanks a tonne for the advice! My store owner has a couple of shop copies of the ol' Modelling Masterclass books that he's let me sit and look through lately, and I've been debating buying them for myself. Can't deny that they've taught me some cool techniques and helped my skills a tonne, and with some time to sit at home and digest it all, I think it would have some great effects on my skill. Anyway, this is your thread, so I'll stop hijacking it. Keep up the good work Elmo, that Valkyrie has set a high bar for this challenge! :) elmo and walter h 2 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3804113 Share on other sites More sharing options...
elmo Posted September 10, 2014 Author Share Posted September 10, 2014 I always try something different, whether the oil paint, making my own rivets from the grains in a water filter or the latest thing - sponges ;) I am thinking about converting one of my russes into a Destroyer/Thunderer using a little plasti-card but that is for a later project...http://www.forgeworld.co.uk/Warhammer-40000/Imperial_Guard/Imperial_Guard_Tanks/DESTROYER-TANK-HUNTER-COMPLETE-KIT.html Back to the work in progress. Sometimes I hate magnets.. I spent last night painting all the weapons options for the chimera but at least that is done. Tonight I will mainly be sponging :) WarriorFish 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805387 Share on other sites More sharing options...
WarriorFish Posted September 10, 2014 Share Posted September 10, 2014 Like most things, the more effort you put in the better the result is so it's worth it :) That's what I tell myself anyway :P elmo 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805434 Share on other sites More sharing options...
CoffeeGrunt Posted September 10, 2014 Share Posted September 10, 2014 (edited) I am thinking about converting one of my russes into a Destroyer/Thunderer using a little plasti-card but that is for a later project...http://www.forgeworld.co.uk/Warhammer-40000/Imperial_Guard/Imperial_Guard_Tanks/DESTROYER-TANK-HUNTER-COMPLETE-KIT.html Nice! Let me know how it goes, I've got a Russ I plan to do this to as well. Edited September 10, 2014 by CoffeeGrunt Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805470 Share on other sites More sharing options...
elmo Posted September 10, 2014 Author Share Posted September 10, 2014 Will do, but it may take a while to get around to as there are so many tanks to paint first.... I was thinking about turning the left over turret into one of these http://dow.wikia.com/wiki/File:Rt_ig_catachans_02.jpg CoffeeGrunt and WarriorFish 2 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805479 Share on other sites More sharing options...
WarriorFish Posted September 10, 2014 Share Posted September 10, 2014 Turret emplacements are cool, go for it! :D walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805569 Share on other sites More sharing options...
elmo Posted September 10, 2014 Author Share Posted September 10, 2014 Have they got rules or have I just gone blind and can't find them? Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805577 Share on other sites More sharing options...
Jolemai Posted September 10, 2014 Share Posted September 10, 2014 I'm sure you could knock one up and use the Sabre or Rapier rules? Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805599 Share on other sites More sharing options...
elmo Posted September 10, 2014 Author Share Posted September 10, 2014 (edited) http://warhammer40k.wikia.com/wiki/Turret_Emplacement. I have just found this which gives references to IA books. Has anyone got the books and can check up for me? I only have IA3 :( Imperial Armour Volume One - Imperial Guard and Imperial Navy, pp. 198-202 Imperial Armour Volume Five - The Siege of Vraks - Part One, pg. 166 Imperial Armour Volume Six - The Siege of Vraks - Part Two, pp. 144, 189 Imperial Armour Volume Seven - The Siege of Vraks - Part Three, pg. 187 http://m.ebay.co.uk/itm/151398074917?nav=SEARCH Found a base on eBay :) Edited September 10, 2014 by Elmo9141 Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805603 Share on other sites More sharing options...
Cod Posted September 10, 2014 Share Posted September 10, 2014 Yes, I can confirm IA V1 pg202 and IA V5 p166 have the rules for turret emplacements! walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805637 Share on other sites More sharing options...
Jolemai Posted September 10, 2014 Share Posted September 10, 2014 http://warhammer40k.wikia.com/wiki/Turret_Emplacement. I have just found this which gives references to IA books. Has anyone got the books and can check up for me? I only have IA3 Imperial Armour Volume One - Imperial Guard and Imperial Navy, pp. 198-202 Imperial Armour Volume Five - The Siege of Vraks - Part One, pg. 166 Imperial Armour Volume Six - The Siege of Vraks - Part Two, pp. 144, 189 Imperial Armour Volume Seven - The Siege of Vraks - Part Three, pg. 187 http://m.ebay.co.uk/itm/151398074917?nav=SEARCH Found a base on eBay IAv1 is out of print. IAv1SE has no mention of turret emplacements and neither does IA: Apocalypse. The other three do have them but they are only listed for renegade lists... I don't recall seeing any bases, etc in the 2014 catalogue either. Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805656 Share on other sites More sharing options...
elmo Posted September 10, 2014 Author Share Posted September 10, 2014 The bases are OOP so I guess that they have been removed from IA1 version 2 and will soon be out of the other IAs. Shame really, maybe I will just end up with a spare turret which I could swap around with a Demolisher turret as the situation dictated. walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805663 Share on other sites More sharing options...
Cod Posted September 10, 2014 Share Posted September 10, 2014 or use it as a counts as vengeance weapon battery! Kierdale, elmo and WarriorFish 3 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805674 Share on other sites More sharing options...
WarriorFish Posted September 10, 2014 Share Posted September 10, 2014 I was wondering why they'd been removed and then cod answered... a good idea :) Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3805735 Share on other sites More sharing options...
elmo Posted September 12, 2014 Author Share Posted September 12, 2014 (edited) Time for the usual Friday afternoon update... Work continues on the Chimera and it now boasts a factory finish paint job. It just needs decals and then some weathering so it should be finished by the middle of next week and then I can work on the half built Leman Russ The Chimera is magnetised so it can have any of the weapon options in the box along with a removable dozer blade. After all, what else did you expect??? Edit: WF just pointed out that the MM seems to have been aquired from another kit - investigations are continuing but just goes to show how good it is to use magnets. I am now ready for MM on Chimeras in the next codex I did steal the Heavy Stubber for my first Leman Russ, hence why the Chimera has not got one. http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120009_zps91bfb27a.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120008_zpsfe5e466d.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120007_zps95ca0eda.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120006_zps357bcbeb.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120005_zpsb9ee1522.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120004_zpsbb8855bd.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120003_zps068e4933.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120002_zpsbd834ddd.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/P9120001_zpse4afa0a7.jpg Edited September 12, 2014 by Elmo9141 Dr_Ruminahui, WarriorFish and CoffeeGrunt 3 Back to top Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3807447 Share on other sites More sharing options...
WarriorFish Posted September 12, 2014 Share Posted September 12, 2014 Looks great as always :D Though that MM is from the Hellhound kit right, as Chimeras can't have them? Link to comment https://bolterandchainsword.com/topic/269375-wip-thread-711th-ccab-chocochip-rats/page/9/#findComment-3807460 Share on other sites More sharing options...
