1750pt tournament list
bluffster
Hi all,
I am due to attend a tournament in April and have begun
trying to assemble a list that I can take. Please can you have a look and give
me your thoughts.
HQ
Rune Priest
Runic Armour
Divination spell
Sits with Grey Hunters in Storm Eagle
Elites
5 x Wolf guard in TA
1 x double WC
3 x TH/SS
1 x C/P CML PF
1 x C/P PF
Drop Pod
Troops
10 x Grey hunters
Plasma
Melta
Wolf standard
MoW
Drop pod
10 x Grey hunters
Plasma
Melta
Wolf standard
MoW
Drop pod
10 x Grey hunters
Plasma
Melta
Wolf standard
MoW
10 x Grey hunters
Plasma
Plasma
Wolf standard
MoW
Inside Storm Eagle
Fast Attack
Storm Eagle attack gunship
Twin linked multi-melta
two twin linked las cannons
Vengence launchers
Heavy Support
5 x Long Fangs
4 x Missile Launchers
1 x Squad leader
5 x Long Fangs
1 x Squad leader
That all totals to 1750pts
The idea is to have two drop pods come down on turn one to
harass/secure objectives.
the terminators will drop in where needed.
Foot slogging grey hunters can provide back of the board
support/sit on an objective or help support the drop pods if required.
Long Fangs to do what they do.
Storm eagle comes on and positions for the grey hunters and
rune priest to attack the opponents weakest point or help out the rest of the
army. whilst providing both anti-air and anti-surface fire using las-cannons
and multi-meltas. against armour 4 the vengeance launchers will clean up
somewhat, or soften the enemy for assault against lower armour saves.
Like I said, please comment, its always worth hearing more
experienced peoples opinions.
https://bolterandchainsword.com/topic/270877-1750pt-tournament-list/
I think your TDA WG are over equipped. THSS is very points inefficient for wolves I wouldn't use these.
Also I don't like the mix of plasma and melta in your hunter packs. They have problems with different effective range and targets. Melta is for heavy armour and plasma likes to be shot at MEQ, TEQ or light armour.
I would live to field a flyer in space wolves colours tho.
You'll get much more milage out of doubling up special weapons (2 plasmaguns in one squad, 2 meltagus in the other).
Also, your terminators are... problematic. TH/SS is far too expensive to use (63 points on a 1 wound non-character is a disaster waiting to happen)- If you take the storm shield, stick with a power axe. Also, because specialist weapons now work together regardless of what the weapons actually are, Powefist+Wolf claw is the same price as 2x Wolf Claw, but you still get the +1 attack with the first setup. Finally, I think the two random combi-plasmas are out of place there. You should probably go all assault build, or all combi-weapon+Power weapon. Also, I count 6 Wolf Guard- Is one a pack leader?
Thanks for the replies guys.
I was thinking of taking one plasma and melta in each grey hunter group to allow me the choice dependent upon the army and situation i was facing. But I have been losing out on shots when out of range for the melta so maybe 2 plasma in all but one and 2 melta in the last so they can deal with things if needs be.
I looked into TH/SS as most of the terminators i come up against are loaded with such weapons. My thought was to try and plasma them to death, which would mean i needed more firepower, or tool up and then at least level the playing field.
Ill look into power axes and storm shield costs, then decide on all assault or all ranged.
There was only meant to be 5, i think i went crazy and added another!
Brother,
  are you sure it's 1750 there?  I think you're closer to 1,850
Also, you have 6 Terminators in your Drop Pod (you say five up front, but you list 6).
Priest 130
WG Pack 350ish
GH Drop Pod 235ish
GH Drop Pod 235ish
GH 190ish
GH 190ish
Storm Eagle 250
Long Fang1 145
Long Fang2 145
                            That's 1870...ish.
