Little Feathers?
Pretty straightforward question- where, if at all, can I find little feathers for conversion purposes, akin to those you find on Dark Angels. And yes, that means I am aware of Dark Angels already msn-wink.gif
I think there are some on the Kroot sprue, too...
Plastic, resin, or pewter are all okay, but preference follows that order from highest to lowest.
I've managed to make a couple with GS, but it is a royal pain, and some of them come out looking like leaves or weird little aquatic invertebrates more than feathers tongue.png
https://bolterandchainsword.com/topic/274720-little-feathers/
I was going to say sculpting them is easy, but if you don't like to do that you can always make a pressmould and produce them that way.
If you heat a bit of sprue and press it into the GS mould you can just cut them off the sprues end a second later. Should be able to produce them pretty fast, just be careful with the fumes.
Cutting plastic card in diamond shaped form and scoring them lightly with a knife should look good enough as well once painted.
You can find some feathers on WFB Empire figures - especially on their hats!
I have seen etched brass foliage kits where leaves/stems have been used as feathers - this might help?:
https://www.google.co.uk/search?sourceid=navclient&aq=&oq=etched+brass+f&ie=UTF-8&rlz=1T4ADRA_enGB343GB344&q=etched+brass+foliage&gs_l=hp..1.0l4j41.0.0.1.9843...........0.NomTb-ank9w&pbx=1
Or get your own made:
http://www.bolterandchainsword.com/topic/249362-custom-brass-etches/
