Argun Posted June 29, 2013 Share Posted June 29, 2013 I promised Warriorfish some pics of this beauty my dad put together, so here they are. Still gotta paint some of it, but essentially it's done. Obligatory round-view pics. All the parts of the tank. The superstructure. What makes this all go together so nicely. The two large magnets are where the metal flaps connect. The connections are strong enough that you can pick the tank up by the superstructure, but I'd advise against it. Even though they are strong magnets, they will fail with enough jostling around mid-air. The front/back panel. The small (barely distingushable) circles are magnets. Shows how the panel attatches to the superstructure. In the second pic, I kinda had to hold it up. Not sure why that side is weaker than the other. Where the panel goes in front/back. There are supports (large in rear, small in front) that hold the panel up so it doesn't fall in while using it in battle. Back panel needs no magnets. It just push-fits just fine. Vulcan Mega-bolter. In it's rear is a large magnet that connects to one in the superstructure. Just showing the other guns. Aside from magnets in the base of the gun, the barrel and tip need no magnets. Thankfully the designers were smart enough to make these connections push-fit! These last pictures show the side panels/guns. You can make out the magnets used within the recesses of the hull. Also: not pictured, but the side heavy bolters are magnetized as well. Well, there's the tank in a nutshell. Hopefully those attempting to undertake such a task as making a hexblade find this helpful! Link to comment https://bolterandchainsword.com/topic/277469-hexblade/ Share on other sites More sharing options...
WarriorFish Posted June 30, 2013 Share Posted June 30, 2013 Most impressive... It doesn't look like an overly difficult task, as the larger a model is generally speaking the easier it is to modify. - but it looks like it took quite a bit of time and effort! Ok, that's decided it then. Emperor help me but when I start work on the kit I'm going to try and build it to work as every variant! Thanks for taking the time to post the pictures up Argun, they're very useful and I will be back to view them when I start work :) Link to comment https://bolterandchainsword.com/topic/277469-hexblade/#findComment-3403984 Share on other sites More sharing options...
Argun Posted June 30, 2013 Author Share Posted June 30, 2013 Most impressive... It doesn't look like an overly difficult task, as the larger a model is generally speaking the easier it is to modify. - but it looks like it took quite a bit of time and effort! Ok, that's decided it then. Emperor help me but when I start work on the kit I'm going to try and build it to work as every variant! Thanks for taking the time to post the pictures up Argun, they're very useful and I will be back to view them when I start work I look forward to seeing your progress on your own superheavy WarriorFish! Oh yeah, I'd also suggest getting those engine upgrade kits from http://stores.ebay.com/Blood-and-Skulls-Industry The engine and fuel tank upgrade kits are way better than the stock versions. Link to comment https://bolterandchainsword.com/topic/277469-hexblade/#findComment-3404292 Share on other sites More sharing options...
Kierdale Posted June 30, 2013 Share Posted June 30, 2013 Thanks from me too, Argun. It'll be a long time before I do get myself the kit, but these photos will be most useful. Since they're putting the 'Sword and 'Blade in one box now it only makes sense to try to make all options doable. Link to comment https://bolterandchainsword.com/topic/277469-hexblade/#findComment-3404347 Share on other sites More sharing options...
Argun Posted July 1, 2013 Author Share Posted July 1, 2013 Thanks from me too, Argun. It'll be a long time before I do get myself the kit, but these photos will be most useful. Since they're putting the 'Sword and 'Blade in one box now it only makes sense to try to make all options doable. Waitaminute... they're doing wha!? Well, that'll be a whole 'nother can of worms, seeing as how the Baneblade and the Shadowsword kit both have differing front plates,superstructures. Hopefully magnetizing the baneblade parts won't be all that hard, but I think I'll let someone else handle that. Link to comment https://bolterandchainsword.com/topic/277469-hexblade/#findComment-3404360 Share on other sites More sharing options...
WarriorFish Posted July 1, 2013 Share Posted July 1, 2013 Indeed, as expected the new Baneblade kit is a combination of all with a price increase to match. As I already have an original Baneblade box I was quick to grab the current box to save some money while I still could. Even more so when I get to work on it as a Hexblade As you said I'm not sure how it'll work with the superstructure being quite different but I'm guessing it's probably a case of different facing plates and such? If it's the merging of more than one kit at the very basic level it'd be all the sprues from each, shared ones aside. I suppose we'll find out when the kit is released and somebody starts the first build! Link to comment https://bolterandchainsword.com/topic/277469-hexblade/#findComment-3404523 Share on other sites More sharing options...
