Blackadder Posted August 15, 2013 Share Posted August 15, 2013 Blackadder's Lucius Pattern ReaverYes before anyone quips that I am crazy (but in a good way) let me acknowledge the fact.Anyway I have been posed the problem of designing (And building) armour for a FW Mars Pattern Reaver à la mode Lucius Pattern. And before you ask, "No I don't do commissions!" however if anyone is inclined to follow along with this thread and build their own armour components they are welcome and I will answer any questions as we proceed.Let me begin by stating that the Reaver is my second least favorite titan I see no need for it.My biggest fault with the Lucius pattern attempts at the Reaver is trying to duplicate the contours of the Mars Pattern with slabs of plasticard. This gives the titan a sloped shoulder hunchbacked appearance that connotes weakness to my jaundiced eye. I intend to remodel the armour in a Lucius vein much as the Lucius Warhound carapace completely departs from the Mars Pattern carapace.The first order of business is to design a new helmet shape for the FW Reaver cockpit. I think the head of the titans should be reminiscent of each other and sort of morph in shape from Warhound to Reaver to Warlord; evolve if you will.So my design will be that middle ground and be domed, not the flattish pancake head of the FW model:http://i.imgur.com/Eacq2bP.jpghttp://i.imgur.com/Eacq2bPl.jpgThere will be a short snouted appearance reminiscent of the Warhound not apparent in the front view Reaver Carapace RenovationReally bad concept art Blackadder but it does convey the intent.....http://i.imgur.com/309WL5P.jpghttp://i.imgur.com/309WL5Pl.jpgWe've all seen them beautifully rendered scratchbuilt Lucius Pattern Reavers that faithfully mimic the arms and armament of the Mars product but somehow they leave me cold. That trapezoidal carapace design, the hexagonal Apoc Rocket Pod (shades of the Armorcast original) and reminding me of that Surinam toad (No I won't include pictures of that again you can google it if you have the stomach....... :P )I propose (represented in my pitiful sketches above) an Apoc 10 rocket battery on either side of the main carapace that pop up as required and snap down to give a clean front/side view of the side armourChest and back armour roughly angular in shape but the side carapaces jutting at slightly less than 90° to the perpendicular.Naturally all the leg and waist armour will be angular copies of the Mars original and interchangeable with the FW original pieces and held in place with magnets so in effect there will be two; a Lucius and a Mars for the price of one.Priceless! Fitting the Torso Front to the Main TorsoI should have my head examined for taking this on but I couldn't resist trying to retrofit a Lucius Pattern armour scheme to an actual Reaver.First I must fit the parts together so my modifications will fit when the model is assembled.I want all the Lucius armour parts to be interchangeable with the original Mars armour and all the fasteners hidden so daunting as this task may be, its worth a go.Below are the crude tools needed to shape the rough sections so they will interlock tightly, What is amazing to me is the precision fit of this model's castings.http://i.imgur.com/hvC6xGI.jpghttp://i.imgur.com/hvC6xGIl.jpgSimply cutting and filing the flash and rough interstices allow the parts to interlock with a close tolerance.http://i.imgur.com/Zk5Rg7t.jpghttp://i.imgur.com/Zk5Rg7tl.jpgFlipping the hull upside down show the good fit achieved without need for glue or reinforcement. Magnets may be all that is required to keep this assembly together.http://i.imgur.com/miBx3lD.jpghttp://i.imgur.com/miBx3lDl.jpgThe lower breast plate armour will be the first piece to fabricate. Here you see the Mars armour in place and ready to be duplicated in styrene.http://i.imgur.com/9XidlOr.jpghttp://i.imgur.com/9XidlOrl.jpg Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/ Share on other sites More sharing options...
Teetengee Posted August 15, 2013 Share Posted August 15, 2013 So it begins... Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3424036 Share on other sites More sharing options...
deathspectersgt7 Posted August 15, 2013 Share Posted August 15, 2013 YES!!!!!! Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3424039 Share on other sites More sharing options...
Blackadder Posted August 15, 2013 Author Share Posted August 15, 2013 Breast Plate ArmourThe problem is to achieve the angularity of the Lucius armour without bulking up the rounded Mars panels. I have chosen to replace the Mars armour rather than just cover it in styrene.This will give a leaner look to the finished model. That and the innovations I shall be implementing will hopefully make for a unique Reaver style that is more battle-worthy in design.http://i.imgur.com/KXfkGa1.jpghttp://i.imgur.com/KXfkGa1l.jpg Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3424342 Share on other sites More sharing options...
Blackadder Posted August 17, 2013 Author Share Posted August 17, 2013 Reaver Breast Plate Armour 2 Here we see the two ways I intend to approach duplicating the Mars armour in the Lucius pattern. The chest plate will directly replace the original Mars armour and will be held in place with magnets and aligning lugs. The original armour will have corresponding attachments so they can be interchanged. http://i.imgur.com/a7s1aNd.jpg http://i.imgur.com/a7s1aNdl.jpg The forward side armour will duplicate the moulded in Mars armour and clip over the original and likewise be held on with hidden magnets so when removed the Mars armour will be revealed and intact. http://i.imgur.com/YNxQuBX.jpg http://i.imgur.com/YNxQuBXl.jpg So far this idea is working. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3426196 Share on other sites More sharing options...
Blackadder Posted August 18, 2013 Author Share Posted August 18, 2013 Reaver Hull Armour 3 Fortunately there is a clip on shelf to fasten the rear lower vent armour. I made the clip out of a strip of 40 X 80 styrene and started the forward depth strip in the following image. Once completed it will be a simple matter of unclipping the Lucius armour to convert to the Mars armour. http://i.imgur.com/h48uo1O.jpg http://i.imgur.com/h48uo1Ol.jpg http://i.imgur.com/pqnAkId.jpg http://i.imgur.com/pqnAkIdl.jpg http://i.imgur.com/myMMJVo.jpg http://i.imgur.com/myMMJVol.jpg Couldn't have worked better if it were planned! Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3427392 Share on other sites More sharing options...
Blackadder Posted August 19, 2013 Author Share Posted August 19, 2013 Reaver Hull Armour 4 Copying the internal contours of the Mars armour is not as simple as these images portray. The problem is to not bulk up the Lucius covers to a point were they distort the overall grace of the model. Granted the Lucius pattern armour is a crude facsimile of the elegant Mars armour but it should not overwhelm the mechanical works so as to appear ungainly. http://i.imgur.com/gPpoDsF.jpg http://i.imgur.com/gPpoDsFl.jpg Employing the gap of the filigree border of the armour I added thin strips 0,25 mm for a gluing base and added strips of 0,3, 0,5, 0,75 and 1,0 mm casing so at no area have I added more that 2,0 mm to the overall size of the panel i.e. 1,0 mm to each side. http://i.imgur.com/Y3qY1SL.jpg http://i.imgur.com/Y3qY1SLl.jpg I apologize for the fuzzy image. Shaving down the edges so the Void generator housings fit snuggly in place required no alterations in the Mars armour so the basic model is not compromised in any way other than the usual adjusting required in your typical FW project. http://i.imgur.com/qgakQUa.jpg http://i.imgur.com/qgakQUal.jpg Aside from a minor cut out around a hidden conduit cable housing the fit is pretty good. http://i.imgur.com/GT3CMOi.jpg http://i.imgur.com/GT3CMOil.jpg I intend to angle the housing around the rear facing vent on a separate piece. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3428162 Share on other sites More sharing options...
Sgt. Blank Posted August 19, 2013 Share Posted August 19, 2013 As with all your projects, this looks amazing. The text color in your posts is very difficult to read, though Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3428307 Share on other sites More sharing options...
Blackadder Posted August 22, 2013 Author Share Posted August 22, 2013 How did that happen? Thanks, Duplicating the components: Now that I have a plan to make the previously demonstrated parts I can proceed to duplicate them more quickly with out as many errors.............http://i.imgur.com/fvgDJCB.jpg http://i.imgur.com/fvgDJCBl.jpg Although my bane is my first attempt always come out best. "Repetition is not my forte." BTW you may notice tiny holes drilled in the styrene, that is where the styrene crosses over a rivet and in order to keep as close to the original size as possible (without the obvious remedy of filing off the rivet) I drilled a recess to accommodate the rivet head. This also has the added benefit of locking the Lucius armour in more tightly. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3431384 Share on other sites More sharing options...
Blackadder Posted August 29, 2013 Author Share Posted August 29, 2013 Reaver Vent Update: Before I tackle the Main Hull Carapace I think it apropos to update the very difficult to make vent covers. The problem is the thinness of the material necessary to follow the contours of the vent housing. 0.010 inch styrene is extremely susceptible to melting through when glued with ProWeld thin cement and what I had to do is leave the cap loose for an hour or two to weaken the volatiles in the glue so these thin pieces don't turn into a puddle of goo. http://i.imgur.com/zDYuv2x.jpg http://i.imgur.com/zDYuv2xl.jpgr Anyway the problem is solved and the vents are done and the few images I have show the bits of construction. http://i.imgur.com/qEN3oVM.jpg http://i.imgur.com/qEN3oVMl.jpg Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3439642 Share on other sites More sharing options...
Blackadder Posted August 30, 2013 Author Share Posted August 30, 2013 The Main Carapace http://i.imgur.com/0VW8Dea.jpg http://i.imgur.com/0VW8Deal.jpg I've given way too much thought to how to proceed with the Main Carapace. http://i.imgur.com/4PURadM.jpg http://i.imgur.com/4PURadMl.jpg The difficulty lies in the layered sculpted armour of the Mars pattern. http://i.imgur.com/Oq380yA.jpg http://i.imgur.com/Oq380yAl.jpg The thought finally hit me that the redundant armour above the head is not necessary in the Lucius version. The downfall of the Epic Lucius Reaver is attempting to incorporate the neck shield with the main carapace armour giving a pyramidal appearance to the upper hull. The whole overall perception is that of a round shouldered hunch appearance lacking in appeal and functional strength. http://i.imgur.com/uia11nsl.jpg These armour sections would look better if treated as separate components as with the Warhound. http://i.imgur.com/BeOnRcPl.jpghttp://i.imgur.com/yoAGbIWl.jpg The clue to the revision of the armour is in the underside of the main carapace. http://i.imgur.com/4qpGMln.jpg http://i.imgur.com/4qpGMlnl.jpg There is a boxlike structure on the underside that forms a ready base to start my Lucius design. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3440349 Share on other sites More sharing options...
Jolemai Posted August 30, 2013 Share Posted August 30, 2013 That's at least three projects now! Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3440370 Share on other sites More sharing options...
Blackadder Posted August 30, 2013 Author Share Posted August 30, 2013 Well to be accurate the Warlord is ostensibly done except for painting and I need a totally different mindset for painting. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3440410 Share on other sites More sharing options...
Blackadder Posted August 30, 2013 Author Share Posted August 30, 2013 Interior Carapace Basic Structure: The basic plate to build on is a simple shallow box 50 X 68 mm with a 3 mm flange around the upper surface. http://i.imgur.com/FPjmCr6.jpg http://i.imgur.com/FPjmCr6l.jpg The front flange is an attach point once I establish how much the carapace will overhang the hull front plate. http://i.imgur.com/jT15TTW.jpg http://i.imgur.com/jT15TTWl.jpg Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3440520 Share on other sites More sharing options...
Blackadder Posted August 30, 2013 Author Share Posted August 30, 2013 Reaver Interior Bracing: Carrying on the interior of the carapace why not add a bit of panache since the exterior will require significant bracing for durability. http://i.imgur.com/VD9hzHg.jpg http://i.imgur.com/VD9hzHgl.jpg This little diversion cost me about a half hour but I think it was work it. http://i.imgur.com/dwvWPR6.jpg http://i.imgur.com/dwvWPR6l.jpg Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3440812 Share on other sites More sharing options...
Blackadder Posted August 31, 2013 Author Share Posted August 31, 2013 Reaver Asymmetry The problem of designing armour for resin models is the asymmetric left and right sides of the moulded pieces none so egregious as the front hull piece at least that I have come across thus far. A simple tracing reveals the mirror curve is very different so to make a front piece in the angular Lucius pattern I shall have to model the greater arc of the curve. http://i.imgur.com/6xGeIJn.jpg http://i.imgur.com/6xGeIJnl.jpg BTW If you examine closely the sculpted front and rear ends of production autos where clay model mockups are made of the new year offerings you can discern just such subtle asymmetry. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3441679 Share on other sites More sharing options...
Blackadder Posted September 1, 2013 Author Share Posted September 1, 2013 A Tale of Three Titans In designing the three titans there appears to be great similarity regarding the carapace between the Mars Reaver and the Mars Warhound. Both are designed with the long axis fore and aft the Reaver carapace being almost exactly a scaled up version of the Warhound. The Warlord having the long axis side to side the same as the imperial titans so in essence there are only two vehicle classes in the Titan hierarchy. If the Mars Reaver/Warhound class is so similar in aspect it stands to reason the the Lucius versions should also display this similarity. Based on this premise the 'Epic' Reaver is an anomaly. I shall base my version on this rational and see where it takes me. This is the fun part of not having a plan!..................? Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3443044 Share on other sites More sharing options...
Montuhotep Posted September 1, 2013 Share Posted September 1, 2013 You're insane for even thinking of doing this; wonderfully, inventive, certifiably brave and amazingly ingenious, but absolutely, completely, wonderfully insane! Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3443254 Share on other sites More sharing options...
Blackadder Posted September 12, 2013 Author Share Posted September 12, 2013 Insane...........Granted Vacation: The Blackadder is back from vacation with a few new ideas on how to proceed with the armour but first a bit of technique training might be beneficial for budding scratch builders. While on vacation I had a chance to read some of the blogs written about the models I have built and the one point that stands out is my seeming precision of fitting seams together. Of course this is utter hogwash as my seams leave much to be desired in my estimation and only I know where the grievous mistakes lie and how many times I have had to scrap work and redo various pieces. I have a box full of failed constructions. But anyway I gave some thought on how I manage to get decent fitting pieces and it came down to sanding blocks and files. Now on various other threads I alluded to filing and sanding to fit but I never expounded on a basic tool that I use although it is present in a lot of photos I present because it also serves so well as a support when presenting a partially finished part. That tool is a common sanding block. I have used sanding blocks for many years starting when I was rather young and building balsa model aircraft. balsa is an extremely soft wood and cuts and shapes like cheese with the proper tools much the same as styrene. The basic block I make is rectangular 5/4 inch by 2 & 5/8 inch pine (29 by 68 MM). The blocks I use are 5 and 1/2 inches long 9140 MM) and almost perfectly squared sides and edges for a reason that will be clear in a moment. The reason I chose those dimensions is that I can get two full blocks of sandpaper out of a single sheet of 8 1/2 by 11 standard paper with very little waste. http://www.3m.com/product/information/Aluminum-Oxide-Sandpaper.html BTW 5/4 lumber is an industry standard finished lumber for fine woodwork such as panel doors and the like and most woodworking shops have lots of scrap available. I got mine from some panel doors I found in the trash. Anyway once I established the blocks were 'true' I covered the blocks with double-back adhesive tape: http://www.lowes.com/pd_15140-14510-1397992_4294715659__?productId=3277853&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo= used for securing carpet. I use that in lieu glue to secure the sand paper to the block so its easier to remove and replace without changing the dimensions of the block. I have had a roll for many years and nowhere near using it up so the stuff I have probably isn't even sold any more. I make(d) blocks of fine, medium and coarse but I primarily use the coarse block. I have six blocks all totaled which are older than some of you reading this...... Enough about tape. Cut your sheet of paper in half and carefully wrap it around the adhesived block so the corners and edges are straight and true and cut off what little excess there is and you will have a sanding tool that will last for years. Any questions? -- E. Blackadder Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3458864 Share on other sites More sharing options...
Blackadder Posted September 12, 2013 Author Share Posted September 12, 2013 Front Carapace and Neckshield: There is fortunately a rectangular vent protruding from the front panel onto which I can affix my front bulkhead panel so the main carapace has a decent front anchor point. http://i.imgur.com/KdCyxPW.jpg http://i.imgur.com/KdCyxPWl.jpg The front panel I intend to drill and tap so it will always be removable even when the model is completed. The reason for that is to tighten the neck joint assembly for I intend to design a flexible neck joint coupling to allow the the head to move. I already have the particulars ensconced in my brain so the actual execution is just grunt work. I'll cover this idea when we come to it in the build. http://i.imgur.com/Zps1Yu5.jpg http://i.imgur.com/Zps1Yu5l.jpg There is on the FW model a double neck hood which I may leave out because the redesigned head shape will need that extra space especially since it will be movable. I see no purpose for the extra hood anyway although it would be quite simple to replicate in a Lucius pattern. My main concern is to not too obviously replicate the Warhound armour but to make the Reaver unique in design but also relatable to the other Lucius titans. http://i.imgur.com/MakUqBK.jpg http://i.imgur.com/MakUqBKl.jpg Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3458970 Share on other sites More sharing options...
Blackadder Posted September 13, 2013 Author Share Posted September 13, 2013 Reaver Asymmetry: The asymmetry of this model is mind boggling, I suppose it's all right for the compounded curves of the Mars pattern but the Lucius requires square and true edges and panels for its faceted armour. The hull varies 1.0 to 2.0 MM between sides. http://i.imgur.com/sD58Dil.jp http://i.imgur.com/sD58Dill.jpg The inner surface of the carapace will have to be trued before the outer surface is applied. Again where there are gaps between the hull carapace and the shoulder armour on the Mars the Lucius will have continuity in that the hull and shoulders will be joined and most probably a single unit. Not a problem but an interesting exercise. Fortunately the shoulder mounts display very little Mars filigree so I should be able to get away with out replicating them in styrene. As with the Warhound the basic shoulder and legs are the same on both the Mars and Lucius. http://i.imgur.com/U7tTbOf.jpg http://i.imgur.com/U7tTbOfl.jpg It may be worthy of note the liberal use of rubber bands to hold the components together during this construction and fitting stage. Apart from the styrene work nothing is glued and all the parts are fitted to a fraction of an millimeter gap/clearance tolerance. It is worth the small added effort and time to achieve a professional looking assembly. The big failing I find with assembled (derelict) Baneblades I purchase on Ebay are the huge gaps between components usually filled with putty or glue. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3460443 Share on other sites More sharing options...
Blackadder Posted September 18, 2013 Author Share Posted September 18, 2013 Finally a Neck Armour I Can Live With: After much trial and error I have come up with a hood design that seems workable. Naturally the side angles need to be pared down but the overall concept mimics the Mars shape but also the Lucius motif. What is seen here is the underside skin of the shield; the exterior surface will give thickness to the armour. Something as simple as this design should have been obvious to me but I was working under the constraints that the armour must not appear too bulky. Also since I am eliminating the hidden neck armour (The Hull Carapace will be removable in one piece) I had to allow for the hidden neck armour side flanges. This will become more apparent once the entire interior level of the hull carapace is completed. http://i.imgur.com/yVKlSi6.jpg http://i.imgur.com/yVKlSi6l.jpg In this top view note the original measurements and the fillet pieces necessary to amend the hood to its final configuration. http://i.imgur.com/HQDwBLl.jpg http://i.imgur.com/HQDwBLll.jpg Finally, a shot of the sub-structure that will flesh out the original contours to mount the sub hood assembly components I shall be retaining. http://i.imgur.com/12izksk.jpg http://i.imgur.com/12izkskl.jpg I still haven't worked out these details. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3466788 Share on other sites More sharing options...
Blackadder Posted September 19, 2013 Author Share Posted September 19, 2013 The Hull Carapace Ad Nauseam: Once more into the breach dear friends, working the Mars carapace into a viable Lucius pattern without making it look too much like an L. Pattern Warhound takes a bit of doing. http://i.imgur.com/4bxhBgE.jpg http://i.imgur.com/4bxhBgEl.jpg http://i.imgur.com/OCWK7hm.jpg http://i.imgur.com/OCWK7hml.jpg I've decided to try some vents on either side of the centerline, that might be fun. I need something to break the line so it doesn't ape the Mars carapace too closely but isn't the truncated box on the Warhound's back. http://i.imgur.com/0XUKzhJ.jpg http://i.imgur.com/0XUKzhJl.jpg Anyway I seem to have a lot of space left above the hull compartment and the Void generators won't conflict with anything I have built thus far. http://i.imgur.com/xhzkDud.jpg http://i.imgur.com/xhzkDudl.jpg Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3468171 Share on other sites More sharing options...
Blackadder Posted September 20, 2013 Author Share Posted September 20, 2013 Reaver Carapace and Hood Extension So the Reaver has a hood the fairs into the main hull carapace and for some reason has a second hood beneath that hood. Well initially I thought to eliminate the lower hood but I found I cannot as it projects rearward beyond the main hood which seemed irreconcilable until I hit on a solution unfortunately at 02:30 AM. awakening with that epiphany I lost sleep for a good portion of the rest of the night. I shall build an partial under-hood and secure the exterior hood to the under-hood and thereby eliminating the excessive construction that would bulk up the carapace too much, simple Huh! Well it took two days for me to come up with the solution. http://i.imgur.com/K4uUXVw.jpg http://i.imgur.com/K4uUXVwl.jpg Shown here is the under-hood with the side flanges in place and cut at what I hope will be the angles and sizes but I won't know that until I build the exterior hood and carapace. http://i.imgur.com/OR84Ubk.jpg http://i.imgur.com/OR84Ubkl.jpg The only plus on this construction is that it doesn't follow the Reaver model from Dawn of War pattern but still maintains the Reaver configuration. http://i.imgur.com/HSx4HSo.jpg http://i.imgur.com/HSx4HSol.jpg The inner hood extends 45 MM from the front hull and the external will extend 60 MM the same as the Mars design. http://i.imgur.com/LZDrV7y.jpg http://i.imgur.com/LZDrV7yl.jpg So far it's working. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3469797 Share on other sites More sharing options...
WarSpirit Posted September 21, 2013 Share Posted September 21, 2013 And so far it's looking great ! Can't wait to see more. Link to comment https://bolterandchainsword.com/topic/278478-blackadders-lucius-pattern-reaver-conversion-kit/#findComment-3470321 Share on other sites More sharing options...
