ShasVa Posted September 6, 2013 Share Posted September 6, 2013 These are ideas for a highly-advanced, rogue DIY chapter I am working on. Consider it all "WIP" until further notice. I need help figuring out how to balance them against other armies of all types. Rail Bolters: High-tech weapons based on the Bolter design. They fire solid slugs propelled by magnetic force. Range: 24" / Str: 5 / AP: 5 / Rapid Fire Range: 24" / Str: 4 / AP: 4 / Rapid Fire Range: 24" / Str: 4 / AP: 5 / Rapid Fire, Bladestorm (becomes AP2 on to-wound roll of 6) * These are three profiles I am considering. Just need opinions on which would be the best one for the sake of balance. Supreme Commander Adamas Velen: The leader of the ??? chapter. Where he leads, the chapter will follow, and none will stand in their way! WS6 BS5 S5 T5 W3 I5 A3 LD10 SV2+ Unit Type: Jump Infantry (Jetpack) (Character) Wargear: - Iridium Bladesword (Melee, AP2) - Storm Shield Generator (3++ save) - Modified Chapter Battlesuit (2+ save, Jet Pack, Homing Beacon) - Null Field Matrix (4+ Deny the Witch save) Special Rules: - Independant Character - ATSKNF - Crusader Commander Mordante "The Undying": One of the ??? chapter's generals, famous for his resilience and steel willpower. <Typhus profile, but with WS6> Wargear: - Two Power Fists with inbuilt Onager Gauntlets (his S10 AP1 attack would be re-rollable) - Terminator Armour Special Rules: - Independant Character - Fearless - The Undying (Eternal Warrior, Feel No Pain, and It Will Not Die) - Patience (Mordante cannot Run or charge into close-combat - he prefers to wait for his enemies to come to him) Possible wargear options for the ??? chapter: Modified Dreadknights (no psychic options) "Rail" option for other Bolter weapons (could increase AP rate, so Heavy Bolters and Autocannons would be AP3) Tau-like Plasma weapons (same AP but lower Strength and no Gets Hot!) Tau-like Meltaguns (18" instead of 12", otherwise the same) Assortment of Tau wargear (Rail weapons, various Support Systems, etc) Assortment of "Forgeworld Horus Heresy" wargear (large-grade Volkite weapons, Accelerator Cannon, Firewasp Drone, etc) Anti-Psyker and Anti-Daemon wargear (Null Rods, gear that confers Adamantium Will, etc) Link to comment https://bolterandchainsword.com/topic/279546-diy-chapter-houserules-quite-a-few/ Share on other sites More sharing options...
