DiscipleOfCaliban Posted September 28, 2013 Share Posted September 28, 2013 So I want to take a few heavy weapons in my list, namely missile launchers and maybe a plasma cannon, but wasn't sure of how to take them. There were 2 options I wanted to choose from: Devastators, so I could put all of the weapons in one squad and save points. Tactical Squads, so I could spread the weapons out for better coverage and hold objectives better. The idea of this is to compliment a RW list with some long range heavy support. My RW struggles a bit with low model count and holding objective which is why I was leaning towards tactical squads but the extra points do cause me to drop from 4 RW Squads (6 bikes, MM AB) to 3. Also, my friend seems to think that the devastators would be better for their intended purpose because they can focus fire on a single target more easily. So there are clearly pros and cons to each. Which do you prefer? For reference the 2 configurations I was going for were either 1 squad of 10 devastators with 3 missile launchers (maybe a plasma cannon), or 3 squads of 10 tactical marines, each with a missile launcher (maybe swap one for a plasma cannon). Link to comment Share on other sites More sharing options...
MadMek83 Posted September 28, 2013 Share Posted September 28, 2013 I'd say going for Tacticals with plasma cannon supported with 5 man missile devastators from behind might be best as 10 dev squad has problem: Multiple different maximum ranges makes unit having synergy problems with itself and extra bodies costly addition as they cannot score. Why not go for 5 man Dev's with 4 missile and take 2x tactical squads with plasma's? Thus you get range, flexibility and scoring bodies to support your bikes. Link to comment Share on other sites More sharing options...
DiscipleOfCaliban Posted September 28, 2013 Author Share Posted September 28, 2013 Good point, the range thing is an issue. Especially if using flakk missiles since blasts can't even try to hit flyers. That could work. Only issue is that 5 man squads are pretty easy to take out if the enemy wants the gone. Link to comment Share on other sites More sharing options...
MadMek83 Posted September 28, 2013 Share Posted September 28, 2013 Key is placing models. Getting Aegis gives you bit fail safe's and if you know your devastators are going to be #1 priory for you enemy, you can use it for your own advantage when placing models. Link to comment Share on other sites More sharing options...
