first 2k list (want fairly comp)
hi all,
my first 30k list msn-wink.gif thinking of going world eaters, but not sure at the minute anyhow here it is help is very much appreciated
list will mainly be fronting up to 40k lists with no more that 1 flyer in an army
HQ
Praetor with cataphracti armour, volkite charger, paragon blade and digital lasers (orbital assault tacs)
Primus medicae with cataphracti armour & volkite charger
both guys to go in the term squad for deepstriking goodness
Elites
10x cataphracti terms
2x p/blaster, 8 volkite chargers, 2x c/fist, gren harness and p/axes on rest
2x apothercaries with augury scanners
1 in each tac squad
3x laser destroyer batteries
for a/tank duties
1x comptemptor dread with 2x kheres a/cannons
for AA snap shooting & supporting tac squads mid-field
Troops
20 x tac marines
19x c/axe, nuncio vox, vexilla, serg with p/axe, articifer and m/bombs
20 x tac marines
to sit in mid-field and work way into rapid fire range then assaulting fun
FA
2x landspeeders with MM
for a/tank duties may go in reserve
https://bolterandchainsword.com/topic/281691-first-2k-list-want-fairly-comp/
double checked the RoW states 'that may take' pods, etc so is optional not mandatory .....phew
what do you think legion tacs wise is world eaters best (feel as though should have some rampagers in there but could not fit in the pts without losing anti-tank
Uhm if they use the orbital drop rule they need to use the drop pods, and squads that can take rhinos may take drop pods as dedicated transports.
I think in the second part of the rules it says all units must use drop pods to deploy unless they already have the deep strike rule, then they can deploy normally
double checked I must be blind you are totally right will re-work into tac squads in pods
