facmanpob Posted October 22, 2013 Share Posted October 22, 2013 I'm in the planning stages of a First Legion force, based around the defence of the Diamat Forge world described in the book Fallen Angels (so Pride of the Legion RoW, Veteran Squads, some armour, not much in the way of skimmers or bikes). Until a week or two ago, I had been including a Rapier Battery in my list as it seemed sensible that the defenders of the Forge would be using 'static' emplacements. However, with the release of the Massacre book, the Tarantula Sentry Gun has been added to the mix, and I am now torn between the two. I'd like to write down some of my thoughts on the pros and cons of both options, and hopefully get everyone's thoughts as to which you would choose.... Let's start with the.... Rapier Crewed, so can move and has BS4 Basic Quad Heavy Bolter has been boosted by FAQ to Heavy 6 twin linked making it viable imo Can take up to 3 in a battery.... i.e. 3 Quad HB, gives 18 Twin linked S5 AP4 rounds per turn out to 36" Upgrade options for barrage anti-infantry and anti-tank weapons Expensive models at £30 each, would probably use the Mantic Hailstorm cannons as alternatives (3 for £30!!) but that would limit me to using the Quad HB version in game Takes up an Elite slot, which is the most contested slot in my list.... Sentry Gun Cheap to include in list (25% cheaper than Rapier) - 3 in a battery taking 2 TL rotor cannon each are under 100 points..... 24 TL S3 shots at BS3 Uses Fast Attack slot which is less congested than Elite Has upgrade options for anti-tank, anti-infantry and anti-air at reasonable cost Has ability to take Shrouded special rule (until it shoots) for reasonable cost so could end up with very good cover save on first couple of turns Static, uncrewed so fires automatically at targets giving less flexibility in target designation Expensive models at £17 each, but can use the very nice Puppetswar alternatives at £8 each with upgrade weapon options available to purchase inexpensively. So, given the options, which would you choose in a defensive force? Link to comment https://bolterandchainsword.com/topic/282295-sentry-gun-battery-or-rapier-battery/ Share on other sites More sharing options...
badgermeister Posted October 22, 2013 Share Posted October 22, 2013 more shots, higher chance of hitting and higher strength weaponry seems the better deal to me. its a lot of accurate shots that you can sit in cover and wipe out a lot of mechanicum models. also, rule of cool - the rapiers are far better looking. Link to comment https://bolterandchainsword.com/topic/282295-sentry-gun-battery-or-rapier-battery/#findComment-3503284 Share on other sites More sharing options...
Sevatar Posted October 22, 2013 Share Posted October 22, 2013 Rapiers, definitely. Higher strength, accuracy and hitting power - rotor cannons do well, nothing, except burn paint off Power Armour. Link to comment https://bolterandchainsword.com/topic/282295-sentry-gun-battery-or-rapier-battery/#findComment-3503523 Share on other sites More sharing options...
Russ Brother 92 Posted October 29, 2013 Share Posted October 29, 2013 Aye I'd use Tarantulas for anti-air but for anti-marine you want those Rapiers throwing out lots of higher S better aimed shots, plus the option for Grav cannons etc. Link to comment https://bolterandchainsword.com/topic/282295-sentry-gun-battery-or-rapier-battery/#findComment-3507571 Share on other sites More sharing options...
