DR's Projects
Dark Rage
  • 2 months later...
Stunning. I got nothing else.
One question. What do you use to make the very small rivets along the legs?
I don't really have any tools for rivets I made a simple mould from green stuff by flattening out a piece and pressing into it with a pin to make lots of holes for the rivets, then after the mould set I just press another piece of greenstuff into it with a bit of water to make sure it doesn't stick and then when that dries I just cut the rivets of and glue them in place. Takes a while, I hear mechanical lead pencils are good for pressing GS into rivets straight onto the model, may get one and see.
Really like these.
How many are you aiming to have?
The one based on Greyall's artwork is a one off I am making for Heathens which is done, added cables to the arms, few more rivets around the cod piece and back and that's about it, cant think of anything else, hope its ok.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Mark1IH.jpg
  • 3 weeks later...
Thanks Greyall.
A bit of progress on the MK1's, still got the 3 clip bolter to finish then I can start casting arms.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/WIP1.jpg
Also made a start on a command squad, Apothecary and champion in the works, apothecary got the wip bolter, hopefully finish and cast it soon.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/WIP6.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/WIP7.jpg
Added to that jetbike concept I was working on a while back.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/WIP3.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/WIP4.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/WIP2.jpg
And a chaplain in the works.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/WIP8.jpg
  • 2 weeks later...
More on the command squad, finally got some paints so I can get back to finishing half the units I started a fair while back.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10033-2.jpg
Group Shot
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10034-2.jpg
A bodyguard, think I am improving at tabards.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10035-1.jpg
Not much new for the champion, added a head and re-did the top robes.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10036.jpg
Another bodyguard
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10037-1.jpg
Apothecary, not much new since last update but added a heart symbol to the belt plate, was trying to be more RT and plan to add a few lenses to the helmet and still deciding where to mount the lights that are normally on the backpacks.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10039-1.jpg
Standard bearer.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Tech.jpg
Techmarine, I used a miscast of the legs from the mk1 I made a while back, shame I have to refill in a few of the rivets but I thought the legs really had a techmarine vibe since there segmented. Also tried to model a PFG using grey knight bits and mounted it to the shoulders. lastly I went for a dead space engineer style helmet if anyone is familiar with the game.
A little GS progress on the techmarine, also trying to decide on a weapon for the champion for the command squad at the moment I have a power lance type weapon to count as a halberd of caliban but I wanted to do something duel wielded so I'm considering casting the axe head of the halberd and giving him duel axes or perhaps making a claymore type 2 handed sword similar to Clouds buster blade from ff7.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Techwip.jpg
Added more around the head, gave a cog like trim to represent the mechanicus and some cloth to the sides of each leg, also, I took the icon of the shoulder so I can try to segment the pads slightly, will probably add chapter emblem to the belt or torso. I am thinking about making a power wrench type weapon for a melee weapon and a wrist mounted storm bolter with a target sensor for the harness weapons.
Some progress on the apothecary and also some more techmarine work, I haven't painted using layers in a while.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10035-2.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10032-1.jpg
  • 4 weeks later...
Thanks for the comments,
 So over the new year was clearing through my image galleries on photobucket and came across this walker I made a while back (yes I am a bit of a zoid fan) but always wanted GW to do a 4 legged walker like the AT-AT walkers from SW or something along those lines. Anyway I thought I would try and make a version 2 using parts from the newer GW kits like the cockpit from a storm talon and legs from the dreadknight but also more imperial like so no fangs and maybe will lose the tail as well. Posting this now since I made a start on the legs and cockpit which I will try to post tomorrow. Also finished the apothecary for the command squad which I will post tomorrow.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Dark%20angels/DSC00345.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Dark%20angels/DSC00347.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Dark%20angels/DSC00349.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Dark%20angels/DSC00354.jpg
Also decided to go with a scythe design for my champion and made a little progress on the mk2's I posted quite some time back, thanks for looking.
That one was based on the plain shield liger but when I look at it now it doesn't really look like the liger but more like a wolf.
Apothecary done.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Apoth1.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Apoth2.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Apoth3.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Apoth4.jpg
Some progress on the command squad
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10043.jpg http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10044.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Champion.jpg
And the progress on the new version walker.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Head1.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Head2.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Leg2.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/Leg1.jpg
Going to cast the whole leg section when its complete, still wondering whether to make changes to the foot as well and think I will mount a twin linked weapon where the mouth was going to be.
  • 3 weeks later...
More Mk2 progress, GS'd some legs, lowered the body to make it look similar to original.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10036-1.jpg
Size Comparison
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10038-1.jpg
Working on a canopy for the walkers head not as exposed as the first, need to try and get some clear plasticard to fill in the gaps.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10040.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10035-3.jpg
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/SDC10032-2.jpg
C&C welcome as always, thanks.
  • 1 month later...
  • 4 months later...
Hey all,
I been a little busy, not much going on just trying to use plasticard more in my projects.
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/20150706_211839.jpg
Some mk2 progress
http://i271.photobucket.com/albums/jj150/o0_Darkeh_0o/20150706_211853.jpg
Seems we may seem some FW reworks of the mark 1 eventually
http://www.belloflostsouls.net/wp-content/uploads/2015/05/blogger-image-1090197420.jpg
