Supreme Grand Master Azrael
Htogrem
Greetings Unforgiven! I've lurked on the BnC for years, and I've only recently started looking at the Dark Angels forum. While I don't play, the Dark Angels have always been my army. Funny it took me so long to come here. I started this topic in the WIP forum earlier, so you guys get the benefit of a second draft of that post. It was rushed and now I completed the way I wanted.
Despite his age, I think Azrael holds up reasonably well with the current model range. There's just a few things that need some help. First is his size, he's a little short and needs some bulk. Second, are the hands. The hands in almost all of the old range of models drive me nuts. If you could open them up everyone would have spider hands. Third, he has a dinky head. Even way back when, he had a dinky head (in my opinion).
BEHOLD!!!... my  WIP already in progress. Honestly, I never intended to post anything online (ever), so I got pretty far along before I decided to make this project log.
Azrael WIP 1
 As you can see, I chopped off his arms and head. Also, I cut off his legs just below his knees. To bring him to proper height I put in a 1/16 inch spacer and glued him back together. I'm reasonably pleased with how the re-sculpt of the robes are progressing. I work on my dudes once every five years, so my sculpting skills aren't where I'd like then to be. What better way to practice than a project that needs mass amounts of sculpting?
Azrael WIP 3
I started bulking out his back and added the backpack socket from a plastic marine. I'll be using a plastic backpack to recreate the classic one. I added armor plates to his backside to bulk out the robes on his legs. I will be re-sculpting the belt as it originally appeared. In the end, his whole back is going to be GSed.
Azrael WIP 2
I bulked up both feet, and need to add the rim of the boot sole. I may need to trim the back and reattach the backpack socket. There are still robes to sculpt, and I don't want him too bulky.
Azrael WIP 4
I'm going to add to the holster so that it looks like it holds a bolt pistol. It just needs space for the magazine. It's one of those little things I've always wondered about (like many, many others, I'm sure).
I will be using the head from the 90s Dark Angels Veteran sergeant. It's just about the the same size as the plastic marine  bare head and the face is almost identical to Azrael's. When I removed it from the sergeants body, I did a poor job and destroyed the jaw. However, it works out because the sergeant's mouth was closed and Azrael is yelling, therefore needing sculpting anyway. In addition to re-sculpting the hands, I will be lengthening the arms slightly. I'll also be doing a minor modification to the combi-bolter.
All said and done, I want to retain the look and feel of the original model. The intent of the project was to retain as much of the original model as possible with only minor changes, but as I progressed it became clear that it will be necessary to re-sculpt nearly 75% of the model. Now I'm doing my best to restore detail as close to the original as possible. I am little more than a novice sculptor, and this will tax my skills to say the least. Of course, the only interesting projects are the ambitious ones.
Comments appreciated, and thanks a lot!
https://bolterandchainsword.com/topic/285305-supreme-grand-master-azrael/
I didn't mind the Azrael model until the new codex came out.  The company master/Azrael image puts his model to shame if you ask me.  I've started working on a conversion to try and get that result using the Forge World 30K legion praetor and various DA bits I have left over.
Looking forward to seeing your result! Robe resculpt looks great, and with a metal model nonetheless!
Nice work. Always liked the Azarel model, and the others from that era (zeke especially) but they are tiny by today's standards, I have some old termis that are smaller than regular marines. Anyway, looking forward to seeing a more appropriate height.
Thanks guys!
Immersturm, I actually painted the helmet bearer a long time ago. At the least, I'll update his paint job when I paint Azrael. I might add some metal trim to the wings. Not sure yet.
SvenONE, I hope you post him when you finish, I love the Forge World stuff. When I first thought about modifying Azrael, I considered adding details to give him the look of the current DA range and art, but decided to leave him classic. I plan a similar project for Ezekiel, and I'm going to go further updating his look.
djgoldsmith, Ezekiel's body is just about the same size as the plastic dudes. He just needs height. When I get to him, I just need to snip his feet and extend the robes. His arms also need work, but it'll be some time before I get to him.
Update time! Please pardon the poor photography.
Azrael WIP 6
I lengthened the robes around his left foot. Using the DA standard bearer as a guide, I built up the robes on his backside. I like how GW updated the Brother Bethor model by bulking up his legs and giving him some modern bits. When I went looking for inspiration for this project, I was surprised to find they did that. I didn't think they would update that particular model. Good thing for me, it had exactly what I needed to see. Still needs work, that divot is a little too deep.
Azrael WIP 7
Start of the backpack. I used skulls from the WFB skeleton regiment. The cables are from something I chopped up years ago, possibly a techmarine servo arm. Need to add spikes, and fill in some cracks. I think I'm going to do some riveted iron work at the base of the skulls.
His legs are getting there, but the green stuff needs a lot of clean up. I'm going to finish the lower half before I move to the torso.
Here we go! Still working on the photography. I use a Droid, and everything looks fine there until I load them to the computer. I'll figure it out. Advice is welcome.
Azrael WIP 8
The back of the robes are pretty much done. I dread the paint job, as it will highlight all the imperfections in the green stuff. It isn't smooth in many places, blending GS to metal and GS to GS is difficult. However, to learn, one must do.
Azrael WIP 9
Here's the direction I'm going with the holster. I converted the plastic holster a long time ago, but never ended up using it. I've always assumed the holstered side arm on space marine models and kits, was intended to be a bolt pistol. It always bothered me that bolt pistol with a magazine clearly would't fit. Aesthetically, it's a nice clean look. However, it's one of those things I choose to fix on my dudes. (I really like the Legion Assault Squad from Forge World. The holsters look like they actually hold a bolt pistol.) While the plastic pistol's magazine sticks out of the holster, Azrael's holster will encompass the entire pistol.
Azrael WIP 10
More GS work to the backpack. The skulls were trimmed and glued on slightly different to each other, so I'll need to disguise that with GS.
Scout
As a matter of interest, here is a robed scout I started years ago. Sure, DA robes usually denote veteran status and the Inner Circle. However, the image struck me and I thought it would be neat to have a squad of robed scouts. He's the only one I did, though.
