Brother Paen Posted February 28, 2014 Share Posted February 28, 2014 Okay so the new Knights are inbound. One Paladin and one Errant check, I'd like to add some of the other variants to build a household. Any ideas on how to represent a Quake Cannon, or Power Lance, or multi-barrelled autocannons ? I mean model and statwise... I think the Crusader had a Quake Cannon and Las Cannons to destroy fortifications and vehicles. Could this be a Demolisher Cannon? The Castellan also had a Quake Cannon with multi-barrelled AutoCannons for anti Infantry. Would an Aegis Auto cannon work? Could it then also have Anti Air? What about the Baron or Lancers Power Lance. It appears to be a typical GW run up and stab it Lance, but compared to a D strength Chainsword how would it be better? S+2d6 melta? Any ideas on what the Wardens came equipped with? What is that missile pod equipped with? Link to comment https://bolterandchainsword.com/topic/287375-conversion-questions-for-the-new-knights/ Share on other sites More sharing options...
Haranin Posted March 1, 2014 Share Posted March 1, 2014 Check epic or apoc, a quake cannon is a larger blast ap3.... Link to comment https://bolterandchainsword.com/topic/287375-conversion-questions-for-the-new-knights/#findComment-3606106 Share on other sites More sharing options...
MadDoc Posted March 1, 2014 Share Posted March 1, 2014 Quake cannon is... Range 24"-180", Str 9, AP 3, Primary Weapon 1, Apocalyptic Blast. In other words, very nasty. Link to comment https://bolterandchainsword.com/topic/287375-conversion-questions-for-the-new-knights/#findComment-3606159 Share on other sites More sharing options...
Brother Paen Posted March 1, 2014 Author Share Posted March 1, 2014 Okay so after some web surfing, the guys over on Apocalypse40k.com consider the quake cannon = to a Tremor Cannon from the Banehammer... that would make it 60" S8 AP3 Primary weapon 1 , Earthshock, massive blast ( 7"). @MadDoc...yours sounds much more frightening, but I think the smaller template may be more appropriate. Link to comment https://bolterandchainsword.com/topic/287375-conversion-questions-for-the-new-knights/#findComment-3606401 Share on other sites More sharing options...
Brother Xeones Posted March 3, 2014 Share Posted March 3, 2014 Regarding how to model the other weapons, you might consider using the punisher cannon from the Vengeance Weapons Battery as the start for the multi-barrel AC. I haven't seen one of these in person (or the knight model for that matter) but it seems to be a good scale to base a knight weapon on. The battle cannon that comes in that kit might also be a decent starting point for a volcano cannon too if you added a different muzzle brake to the front. Link to comment https://bolterandchainsword.com/topic/287375-conversion-questions-for-the-new-knights/#findComment-3608397 Share on other sites More sharing options...
miteyheroes Posted March 4, 2014 Share Posted March 4, 2014 I added a Lance to my knight, using plastruct and a missile and some other random bits. http://www.bolterandchainsword.com/topic/252364-knights-house-nordcote/?p=3607255 Rules-wise, I'll just be using it as the normal chainsword. It's just to make it look more like a Baron! Link to comment https://bolterandchainsword.com/topic/287375-conversion-questions-for-the-new-knights/#findComment-3609373 Share on other sites More sharing options...
MadDoc Posted March 4, 2014 Share Posted March 4, 2014 (edited) Okay so after some web surfing, the guys over on Apocalypse40k.com consider the quake cannon = to a Tremor Cannon from the Banehammer... that would make it 60" S8 AP3 Primary weapon 1 , Earthshock, massive blast ( 7"). @MadDoc...yours sounds much more frightening, but I think the smaller template may be more appropriate. Those stats were are the official GW rules from 6th Edition Apocalypse. Edit - changed tense of verb Edited March 4, 2014 by MadDoc Link to comment https://bolterandchainsword.com/topic/287375-conversion-questions-for-the-new-knights/#findComment-3609381 Share on other sites More sharing options...
