SCOTT_FRANCIS Posted June 23, 2014 Author Share Posted June 23, 2014 Feel free to use what you like Brother, It is really quite simple. In fact if you trimmed the plasma cannon differently, you would not need the plasticard. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3726694 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 23, 2014 Author Share Posted June 23, 2014 "Brother Marshall!" MotF Canemich bowed. "Speak Brother Canemich, What have you discovered?" "Following our successful emergence from the Warp Storm, I have run a full diagnostic of the ship systems and have communed with the vessels Machine Spirit. The augers are now working at full capacity. During the test the vessel tracked and recorded two images." "Images of what?" asked Marshall Dolourus, his interest piqued. "What and who Lord. I think you should see for yourself." "So, the renowned Commissar Yarrick is organising the retreat, and he has a Stormlord. Interesting. Why is he here?" the Marshall thought out loud. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3727056 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 23, 2014 Author Share Posted June 23, 2014 Brothers, some WIP on my ETL III Vow. The Emeperors Champion. Highlights and touch up work required, also work on the Tabard. I just wanted to let you all know that I am making progress after my late start. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3727122 Share on other sites More sharing options...
Honda Posted June 24, 2014 Share Posted June 24, 2014 Any thoughts on using fibre? Thin dental floss is thinner (for scale), so less likely to look like a leg warmer on a stick. You may need to get creative when it comes to the ends, but that should give you the look you are after. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3727910 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 24, 2014 Author Share Posted June 24, 2014 Any thoughts on using fibre? Thin dental floss is thinner (for scale), so less likely to look like a leg warmer on a stick. You may need to get creative when it comes to the ends, but that should give you the look you are after. Mine is flat, dental tape, should look like leather strap when I have finished. Great idea, thanks Honda. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3727951 Share on other sites More sharing options...
General Disarray Posted June 24, 2014 Share Posted June 24, 2014 Any thoughts on using fibre? Thin dental floss is thinner (for scale), so less likely to look like a leg warmer on a stick. You may need to get creative when it comes to the ends, but that should give you the look you are after. Mine is flat, dental tape, should look like leather strap when I have finished. Great idea, thanks Honda. If you wrap the haft of the serrated mace/axe with the dental tape I would suggest putting a little dab of glue on one end to secure to either the top or the bottom of the haft, whichever end you want to start at and then winding it around until you're happy with the placement of the dental tap and then using another drop of super glue to secure the other end to the haft. I wouldn't try to use knots because I think the size of the knot wouldn't look the proper scale although if you have really nimble fingers or use tweezers maybe you could make it look right. Also, I've found that using the end of a toothpick to hold a little drop of glue and apply to the small fiddly bits and hard to reach places works well. It reduces the amount of foul language and bits of plastic inadvertently glued to my fingers. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3728066 Share on other sites More sharing options...
Honda Posted June 24, 2014 Share Posted June 24, 2014 If you wrap the haft of the serrated mace/axe with the dental tape I would suggest putting a little dab of glue on one end to secure to either the top or the bottom of the haft, whichever end you want to start at and then winding it around until you're happy with the placement of the dental tap and then using another drop of super glue to secure the other end to the haft. I wouldn't try to use knots because I think the size of the knot wouldn't look the proper scale although if you have really nimble fingers or use tweezers maybe you could make it look right. Also, I've found that using the end of a toothpick to hold a little drop of glue and apply to the small fiddly bits and hard to reach places works well. It reduces the amount of foul language and bits of plastic inadvertently glued to my fingers. Excellent suggestions! I've probably glued half a land raider to my fingers over my hobby career. I have started using tweezers of late. :) Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3728166 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 24, 2014 Author Share Posted June 24, 2014 Excellent ideas Brothers, I think I will go with the dental tape, I will wash it first, let it dry a little, then super glue one end and wrap it around. I will add drops of super glue all the way down to stop it coming undone. I think painted a dull brown, then apply a wash, and a highlight dry brush of a lighter brown should look okay. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3728339 Share on other sites More sharing options...
Marshal Mattias Posted June 24, 2014 Share Posted June 24, 2014 Thin dental floss is thinner (for scale), so less likely to look like a leg warmer on a stick. Also, your weapon will always be minty-fresh! All the better for banishing the foul scent of witchcraft. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3728579 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 27, 2014 Author Share Posted June 27, 2014 ETL III update. The Emperors Champion is now finished, my skills will get better, I promise. The EC ride is now fully built, a few coats of paint are now required. Progress, Brothers, is slow. But steady. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3731197 Share on other sites More sharing options...
SCOTT_FRANCIS Posted June 29, 2014 Author Share Posted June 29, 2014 "My Lord Dolourus, there is an incoming transmission. Re-routing it to the Command Throne." intoned one of the unthinking servitors that manned the bridge of His glorious warship 'Lucern Imperator'. "So", thought Marshal Dolourus, "The good Commissar has deemed it worthwhile to inform us of his presence." He looked at the screen of the Command Throne, waiting for the message to scroll up. When it did, an ice cold feeling wormed its way into his gut. +++ INCOMING TRANSMISSION +++ +++ TIGHT BEAM DELIVERY +++ +++ ENCRYPTION LEVEL : VERMILLION ALPHA GAMMA +++ "Tight Beam, makes sense, but why the encryption, why Vermillion level?" Mused Dolorus. " Coms!" He demanded suddenley, " Where did this message originate? The planet?" " No, Lord Dolourus, the message originates from the vessel "His Unwavering Light", exactly five hundred and sixty thousand kilometers from our stern." reported the servitor, showing no emotion at the confusion in the Marshals voice. Marshal Dolourus returned his eyes to the screen. +++ MARSHALL DOLOURUS, BLACK TEMPLARS, HIS ADEPTUS ASTARTES +++ +++ I AM INQUISITOR JAROLD OF THE ORDO MALLEUS +++ +++ I WILL BE IN SYSTEM WITHIN THE HOUR. I REQUEST A MEETING OF MINDS +++ +++ TRANSMISSION ENDS +++ Marshall Dolourus reclined in his Command Throne, "So, the plot thickens, first, the mighty Commissar, now a member of His Holy Inquisition. What awaits us on this planet?" thought Dolourus to himself. "Command Staff to the bridge." he demanded, "We have a guest to prepare for." Quietly and without emotion, the servitor at the communication station sent the order to the Command Staff. Ordo Malleus Inquisitor 'Jarold' Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3732633 Share on other sites More sharing options...
Krikey Posted July 1, 2014 Share Posted July 1, 2014 I'm stealing your executioner turret as well. Nice job! On the dental floss -- just make sure it's not the waxed kind. Might have difficulty getting primer to stick. ~K Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3733915 Share on other sites More sharing options...
SnorriSnorrison Posted July 1, 2014 Share Posted July 1, 2014 The inquisitor looks good so far - as does the EC! The backpack is a nice touch. I'm thinking of adding and OH inquisitor...just cause...witches. Keep 'em coming, brother! Snorri Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3734501 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 2, 2014 Author Share Posted July 2, 2014 I'm stealing your executioner turret as well. Nice job! On the dental floss -- just make sure it's not the waxed kind. Might have difficulty getting primer to stick. ~K Thank you Brother, steal away, it is quite a simple conversion, a bit of cutting and filing, job done. @ Snorri - Thanks Brother, it's an old backpack I had from Anvil Industries, I thought it looked better than the standard Mk V, VI and VII backpacks. And as for the Inquisitor, he will have friends I will pull out for Deamons only, normal witches will get burnt as standard. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3734728 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 2, 2014 Author Share Posted July 2, 2014 First attempt at a free hand cross, not sure I lkie it. What say you Brothers? Lose it or keep it? And worry not, I do intend to drill the barrels. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3735103 Share on other sites More sharing options...
Honda Posted July 2, 2014 Share Posted July 2, 2014 I am in the "dig it" camp. I think that looks pretty sweet. As far as I am concerned, the only thing better than twin linked assault cannons, is twin linked assault cannons with crosses. :) Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3735381 Share on other sites More sharing options...
minigun762 Posted July 2, 2014 Share Posted July 2, 2014 Looks really good to me. Just toss on another layer or two and it would be great. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3735406 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 2, 2014 Author Share Posted July 2, 2014 Keep it. Okay then, i will finish it up. Thankyou Brothers. I may try for a larger cross somewhere on the hull, I have BT doors and ramps and 2 BT Drop Pod Icons on it already. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3735517 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 3, 2014 Author Share Posted July 3, 2014 Twin Linked Assault Cannon with cross. Thank you Brothers, I do like it. Good choice. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3735630 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 3, 2014 Author Share Posted July 3, 2014 The Templar Blade, Relic Blade of the Dolourus Crusade, wielded by Marshal Dolourus himself. Not sure about the string. Just on of a few ideas. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3735926 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 4, 2014 Author Share Posted July 4, 2014 The Inquisitor strode down the embarkation ramp of the Storm Raven, he seemed unimpressd at the ranks of Black Templars arranged in perfect lines to greet him. Marshall Dolourus cast his eyes over the Inquisitors transport, he was unimpressed at the Inquisitorial markings but what piqued his interest was the silver colour and the way the edges shone a shimmering blue. He cast his mind back, aware that he had seen the coloration before. Grey Knights. "Marshall Dolourus." the Inquisitor stated. Dolourus had noticed the Inquisitor was wearing full Tactical Dreadnought Armour and was more than slightly impressed. It took years of training for an Astartes to master the ancient suits of armour, for an un augmented human to wear the armour, was indeed impressive. "Inquisitor Jarold. Welcome to the 'Lucern Imperator'." "Thank you Marshall, I will not keep you, I am aware of your mission concerning the Necrontyr, but I must request ignore the machines and join my forces." Marshall Dolourus creased his heavy brow. "Inquisitor, my orders come from the High Marshall himself. No orders, not even Inquisitorial orders will sway me from my Crusade. If you are here to demand the forces of the Black..." "Marshall." the Inquisitor interupted. Dolourus' fists clenched involountarily, his hearts sped up, his body dumped adrenalin into his blood stream, anger flashed across his face. "I would not be as... un thinking as to demand from His most zealous and righteous Black Templars. I would simply request you aid me in a fight that will ultimately save this sector." As Marshall Dolourus calmed himself, he looked to his left, Chaplain Grimaldus had not removed his helm, as was customary. The Chaplain was facing him, he nodded imperceptibly, Dolourus turned back to the Inquisitor. "You travel in a Grey Knight transport, Inquisitor, do you keep the company of..........Witches?" he spat the words, feeling his gorge rise as he said it. "As I said, Marshal Dolourus," the Inquisitor answered, "I have requested your aid. Would I not be foolish to earn your assistance to then risk squandering it by allying you with that which you despise? No Templar, I do not consort with.....Witches." "Inquisitor?" a voice questioned, it was a commanding voice, a voice to follow, to obey. Even the Inquisitor felt it, the power, the conviction, the authority. " Under what threat do you come to sequester the aid of the Black Templars?" asked High Chaplain Grimaldus. "The threat of Incursion, Master Grimaldus." the Inquisitor answered, annoyed with himself that he had shown the slightest sign of reverence to the Hero of Helsreach. " The threat of the Deamonic." Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3736350 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 5, 2014 Author Share Posted July 5, 2014 My first attempt at the coloration of a melta barrel. I will need to wash it to dull it down a bit. It does not look so good on the pic, but there are 4 layers of color. I think my first attempt worked out okay. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3737521 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 5, 2014 Author Share Posted July 5, 2014 Brothers, I am happy. A little more work and it was finished. What do you think? With the barrels sorted, I started work on the stock and the shield/scanner. The scanner screen. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3737687 Share on other sites More sharing options...
Marshal Mattias Posted July 6, 2014 Share Posted July 6, 2014 Very cool! Nice finish on the Melta ;) Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3737738 Share on other sites More sharing options...
SCOTT_FRANCIS Posted July 6, 2014 Author Share Posted July 6, 2014 A little more work this morning, managed to get some painting done in between sorting the baby youngest Neophyte. A collection of weapons from the mighty 'Liberatus Est'. Link to comment https://bolterandchainsword.com/topic/290799-the-dolourus-crusade/page/2/#findComment-3737881 Share on other sites More sharing options...
