Abhuman Insanity
I don't know who all remembers them but at one time there were abhuman beastmen that were considered part of the imperium. While you can still score some of these every know and then the models are old and metal.  So I was thinking about doing a guard or Inquisition detachment blob made up of these guys.  I would mix Catachan bodies with parts from the fantasy beastmen arms and heads with weapon swaps.  What are your thoughts on this?  Of course this army would increase by adding Ogres, Ratlings, and Squats.
https://bolterandchainsword.com/topic/291416-abhuman-insanity/
Well if the bodies on regular guard are too small I may hack the torso's off the beastmen and just use guard legs with the torsos from Ungors since they are smaller than Gors.  Bray Shamans would be the psychers or priests.  I would just need to remove all Chaos symbols and use imperial eagles etc.
you could achieve this by mixing and matching plastic IG bits with fantasy ungors to achieve the same thing...maybe some ogryn parts on gors for sergeants? That would give you far more models along the same theme. That's actually my plan for cultists if I ever do a chaos army...
I thoroughly recommend the Ungor kit. Lots of bitz, and arms easily converted to hold lasguns (getting together enough lasguns is another issue...).
I used them myself for my penal legion and intend to get more so they can be used as conscripts.
Photos here if you want to see them:
http://www.bolterandchainsword.com/topic/269424-shrineworld-garrison-priest-completed-49/?do=findComment&comment=3281493
Surgically implanted spinal bombs optional :)
I like the ungors as cultists, myself, but I can totally see the variatus angle...I mean, the US Army segregated discriminated-against minorities into pure(ly impure?) regiments in the early 20th century, so entire units of mutants, why not?  Why wouldn't a crafty backwater planetary governor be able to get away with filling his entire tithe with abhumans?  They'd probably all be dead before a particularly conservative inquisitor found out!
