march10k Posted July 8, 2014 Share Posted July 8, 2014 I can take two Wyverns for that, which'll do the job so much better. I can't help but feel I won't need something to move up the field that aggressively that can't already Deep Strike or won't fit in a Vendetta. True, but then there's the slots. One is Fast Attack, the other is Heavy support. I find it redundant to compare units from different slot choices, even if they perform the same task. Bringing a Valk with MRP's means bringing decent Anti-infantry weapons, with transport capacity, and mobility while still allowing me to load up on Lemans! Lemans...wouldn't those also come under the heading of anti-infantry? Other than the vanquisher, that is. Link to comment https://bolterandchainsword.com/topic/293456-valkyrie-heavy-bolters/page/2/#findComment-3740235 Share on other sites More sharing options...
Kontakt Posted July 8, 2014 Share Posted July 8, 2014 Since I play mostly MT, I'm convinced I will mostly use the rocket pods. However, thanks to march10k, I believe the standard loadout might not be a bad idea either. Link to comment https://bolterandchainsword.com/topic/293456-valkyrie-heavy-bolters/page/2/#findComment-3740247 Share on other sites More sharing options...
Seahawk Posted July 9, 2014 Share Posted July 9, 2014 If they are C:TS Valkyries, then I always include the heavy bolters at 10 pts. Use for fire support first, transport second. If they are C:AM Valkyries, then I never include the heavy bolters. Use for transport first, fire support second. Link to comment https://bolterandchainsword.com/topic/293456-valkyrie-heavy-bolters/page/2/#findComment-3740441 Share on other sites More sharing options...
march10k Posted July 9, 2014 Share Posted July 9, 2014 I like that philosophy! /edit/ It is soooo weird that the heavy bolters cost twice as much in the codex that needs them less! Link to comment https://bolterandchainsword.com/topic/293456-valkyrie-heavy-bolters/page/2/#findComment-3740488 Share on other sites More sharing options...
CoffeeGrunt Posted July 9, 2014 Share Posted July 9, 2014 True, but then there's the slots. One is Fast Attack, the other is Heavy support. I find it redundant to compare units from different slot choices, even if they perform the same task. Bringing a Valk with MRP's means bringing decent Anti-infantry weapons, with transport capacity, and mobility while still allowing me to load up on Lemans! Given you could still fit 12 Russes into a list with a Wyvern using up a slot, as well as the current madness that is CADs, I don't think you can say it doesn't matter because of the slots used. Link to comment https://bolterandchainsword.com/topic/293456-valkyrie-heavy-bolters/page/2/#findComment-3740698 Share on other sites More sharing options...
