Stormfang Gunship Conversion
Provocation
he should just sand the wings so the flaps can't be seen then cut the wings with a saw from the other side making to insertions, then score the top and bottom using a ruler so the flaps are now on the correct side.
i love the wings on the way you did it, GW has no clue about aerodynamics.
Interesting. I like it. However, there's 2 problems I see:
a.) the costs to create this are pretty darn high, especially if you are going for multiples
b.) it can not be used in official tourneys because of great modelling advantage given the new gun placement
Other than that, very well done ;)
How is the gun being higher up give a gameplay advantage? If anything it would limit line of fire as you only get 45 degree depression.
The las cannons have a much better field of view. The Helfrost cannon is higher, thus can draw better line of sight. The MM up front should be sponsons. Totally fine in friendly games, relax ;)
This conversion was definitely more for the 'rule of cool'. After doing a stormtalon conversion I wanted another one and the cool box set came out with a stormraven and 2 talons, which meant I had a 'spare' talon to muck around with. Which then lead to this stormfang conversion. It's a slippery slope biggrin.png.
With my conversions it tends to be frantic clipping and chopping when I get a light bulb moment so I don't have pics with a step by step. But I'll try and explain it as best I can and let me know if I can add any pics from the finished one if it helps, here goes: The basic rectangular fuselage stays the same. The major bit of the conversion was bringing the wings that usually fit on the back forward. This required some serious glueing and pinning (two on each wing) to stabalize them. I also wedged one of the directional thrusters from the stormtalon into the underside V of the wing to give it another contact point to pin/ glue it to, but you could use any bit that can fit in the space. Just up from the wing add the stormtalon engines where the doors/ hurricane bolters would usually go. Add the stormtalon wings to the back engines. Instead of adding the tail section to the rear end of the stormraven, I've put it between the rear engines. I cut a tail piece and added the top of the tail (as spotted) back to front. The helfrost destructor was just taking the four or five pieces that make it up and scraping and cutting until it fitted. I also had to cut a piece here or there on the roof to make a snug fit.
Hope this helps
Here's the pic from the back. I've left the area where the tail usually attaches open (it's an afterburner or something suitably insane that the Wolves would use to go faster), but it would be pretty straight forward to cover up.
http://i1118.photobucket.com/albums/k614/Provocation88/IMG_5458.jpg
