Codex space marine anti air
Axagoras
So I have had a problem recently of how to win the air war (or kill a single enemy flier) with just codex marine units not including forge world. The issue I have is that while i run 2 talons with skyhammer missiles and they cant seem to kill a single necron cresent or any av 12 flier. I was wondering if people had better results using other AA methods since the only options we have in our codex are talons, ravens, hunters/stalkers. Personally I dont like trying to use a single raven as your anti flier choice and the stalkers and hunters seem too weak/infective at doing much even vs fliers. Should I juse upgun the talons to have lascannons instead of skyhammers?
https://bolterandchainsword.com/topic/295139-codex-space-marine-anti-air/
They aren't worth it, you're still better off taking an Aegis rather than the AA tanks as being able to place cover offers a lot of tactical benefits.
The Stormraven is still one of the best AA vehicles or flyers in general in the game and that's the other great option.
I often debate whether a fully kitted out Raven is superior to two Stormtalons...
well i assume you mean talons with lascannons are great aa, and yea I look at the AA tanks and they just fall so flat, like 3 stalkers seems boss on paper, having 12 tl skyfire autocannon shots. but you do nothing to av 12 and the like...
And you are not alone on that, I tried to think it over, which would be better, sure the talons cost 80 points more but for those 80 more points you get 2x the guns and sure the av 12 and 3 hp is good but not worth 2x the offensive firepower
Well, I always field the Raven with the Hurricane Bolters.
If you get behind a Vendetta or Heldrake you have an additional 12 twin linked shots that glance on a 6...
Also it's incredibly useful late game at clearing troops off objectives as you can quickly get into Rapid Fire range. I can't think of anything better to spend 30 points on!
true I would always take that, but then its just 50 more points for 2x the anti air guns and strafing run give you a huge boost vs ground targets anyway. id only take the raven if you were going to stuff something in it like 5 ccw scouts or something like that
Vengeance batteries are BS 2 and are auto fire only if i remember correctly.  But as for the the raven vs talon,  i don't see how  2 talons can out shoot a fully loaded raven.  The raven on the first turn can fire 5 weapons at full BS one of which at a second target and the rest are snap firing for a total of potential 8 separate weapons shots 4 of which are twin linked.  The Talons have 2 weapons each for a total of 4 weapons.   I am not saying i don't like the talon (i use one with a raven) but a raven is way stronger than 2 talons.   The only advantage i see is 2 separate targets for interceptor and 4 HP but being at AV 11 makes the extra HP not much of a plus.
Vengeance batteries have 2 twin linked lascannons on each. Got to count for something?
The issue with the weapon batteries for AA is that they don't prioritize flyers the same way the Redoubt does.
That said, the Redoubt still averages 2+ hits per turn or 3 if you take the Magos upgrade.
And... like all flier matches whoever comes on first dies, but with 2 talons the raven can only kill 1 talon (potms 1 gun is not likely to do anything) then the other one fires back, and if the raven comes in first its eating 2x the fire power it has (besides the missiles)
And to talk about vengances/ firestorms... both can take quad icarus lascannons but the vengances not being able to target fliers over closer units is a huge blow to it. I should look into getting a firestorm redoubt
yea, my main issue is i only have 250 (280 at max) to get some solid AA in a list i have, so 3 talons is out of the picture, but question on a vengeance, can each gun shoot at a different target?
If you only need AA, the Redoubt is pretty good buy, especially if you have a squad you can hide inside.
As for the VWB, they're separate units so they can fire at different targets (assuming the closest target to each is different)
The AA tanks actually do rather well for their point cost, but the heavy support slots are too valuable to fill 2-3 with stalkers or hunters. If I were to play unbound I would spam heavy support stuff, but a Raven does a better job for a single slot, and TFCs are too valauble (and I love my devastator squads).
Skyhammers are pointless imo.
I wouldn't say that. Disregarding the point difference, which I believe is a significant bonus to the Skyhammer, Skyhammers will kill AV10-12 faster than TLLC will.
If you're worried about AV13+ or shooting MCs, the TLLC is a better choice but to be fair, I'd rather have the TML against most MCs or heavy armor thanks to 2 shots.
my 2 talons have yet to kill any flier... skyhammers just bounce off av 11... skyhammers just dont kill fliers or force grounded tests on FMCs
But to be fair, that's a combination of bad luck and anecdotal evidence.
1 BS4 TLLC = 0.59 Pens & 0.17 Glances for a total of 0.74 damage results
1 BS4 SHM = 0.66 Pens & 0.33 Glances for a total of 0.99 damage results
Difference = The SHM is 33% better at stripping Hull Points off AV11 than a TLLC and 10% cheaper.
I'm not arguing that the SHM is the best choice (my view is all three are viable) but it will average a higher damage result against AV11 than a TLLC will for less points.
has yet to do anything for me, i only roll 1-4 when rolling armor pen with them... doesnt change the fact that 2 talons, with 6 skyhammer shots have failed to kill a single enemy flier in any game I have used them in. only way i kill fliers is with a sicarin with the legacy that gives it skyceptor and tank hunter or a storm eagle roc pattern
For me i wouldn't even jink my raven against the sky hammer, but the las cannon i would.  Also the las has a chance to explode a vehicle.   So for me the las has a greater effect on the field with causing a jink and explode chance.  A small increased chance to take a HP is not much of a plus for the sky hammer.
