march10k Posted February 28, 2015 Share Posted February 28, 2015 http://www.geitmeise.com/images/warhammer/sororitas/2.jpg This is actually perfect. It has less to do with not obstructing the hatch and more to do with focusing on clearing a path for the tracks. Clearing the space between them isn't useless, but it's far less critical. This: http://www.ricko.ca/images/deathwingcrusader2.jpg Is worse than useless. It doesn't clear anything from the path of the tracks...in fact, it will pile stuff up in front of the blade that will then be spilling over the sides into the tracks...hope none of the debris is explosive... Yes, ideally, you would have a blade that pushes everything to the side, running across the entire front of the tank...but the priority is to protect the tracks, so the first example is about a 90% solution...so long as you're driving through debris, not an antitank minefield! Take it from a real-world tanker... Link to comment https://bolterandchainsword.com/topic/295449-order-of-the-faith-unshaken/page/3/#findComment-3964662 Share on other sites More sharing options...
geitmeise Posted March 4, 2015 Author Share Posted March 4, 2015 This is actually perfect. It has less to do with not obstructing the hatch and more to do with focusing on clearing a path for the tracks. Clearing the space between them isn't useless, but it's far less critical. This: Is worse than useless. It doesn't clear anything from the path of the tracks...in fact, it will pile stuff up in front of the blade that will then be spilling over the sides into the tracks...hope none of the debris is explosive... Yes, ideally, you would have a blade that pushes everything to the side, running across the entire front of the tank...but the priority is to protect the tracks, so the first example is about a 90% solution...so long as you're driving through debris, not an antitank minefield! Take it from a real-world tanker... Much appriciated! For someone who skipped the military like myself, this is quite useful and interesting to read :) Link to comment https://bolterandchainsword.com/topic/295449-order-of-the-faith-unshaken/page/3/#findComment-3967869 Share on other sites More sharing options...
Duke Danse Macabre Posted March 9, 2015 Share Posted March 9, 2015 Yeh... all this is doing is making me want to make a sisters land raider for my force... :( Link to comment https://bolterandchainsword.com/topic/295449-order-of-the-faith-unshaken/page/3/#findComment-3972194 Share on other sites More sharing options...
*Furyou Miko Posted March 9, 2015 Share Posted March 9, 2015 Go for it! Link to comment https://bolterandchainsword.com/topic/295449-order-of-the-faith-unshaken/page/3/#findComment-3972201 Share on other sites More sharing options...
Duke Danse Macabre Posted March 9, 2015 Share Posted March 9, 2015 Go for it! Have you seen my project room?... Yes its a room now. :P To be honest I would be unsure if i would go the way of a moving Church, an even bigger Exorcist or Inquistoring it up. Link to comment https://bolterandchainsword.com/topic/295449-order-of-the-faith-unshaken/page/3/#findComment-3972229 Share on other sites More sharing options...
