So I accidentally made a Land Raider Helios tonight....
Casual Heresy
Still not too sure how I managed it but yeah as the title says I now have a Land Raider Helios built out of an unpainted raider I have and a rummage through the bitzbox. This was completely unintentional but I now have a model that will be used in my fists.
Has anyone suffered from this possession by inspiration and ended up with a model they weren't expecting?
Curses! Wrong forum! Could a moderator move this to amicus please?
Naw I was wanting to use Helios to combine a template weapon with a chassis which won't crumble as much in my local meta. It a land raider and a whirlwind in one heavy slot! Plus I've built it in such a way that the launcher and scanner comes off, the heavy bolter goes back on and it a normal raider again.
The small transport capacity is a problem but it would be fine for a small squad of sternguard or a close combat captain and his command squad. Or even just a techmarine to keep it going.
  • 3 weeks later...
Once out of pure boredom I built a Techmarine Dreadnought model out of one of those old metal Dark Angels dreadnought. The thing was beaten and had some messed up parts. So I made it work by covering those places up with enhanced augmetics and a larger servo harness on the back. In the front he has a techpriest hood drooping over the carcophogi and a load of mechadendrites hanging out of the bottom of the carcophogi. He also carries a makeshift axe made of plasticard and some old gundam pieces (DeathScythes Scythe was put to great use here) It turned out really great and I field it as an IronClad dreadnought in my Iron Snakes army.
