Jamafore Posted September 28, 2014 Share Posted September 28, 2014 Have a FW Apothecary that I need to strip sp I bought some Simple Green. It's in the "Bleach type" gallon jug but I saw it said it was concentrated. So I was wondering if I need to cut it at all or just use it straight. Thank you. Link to comment https://bolterandchainsword.com/topic/297315-stripping-fw-with-simple-green-question/ Share on other sites More sharing options...
Subtle Discord Posted September 28, 2014 Share Posted September 28, 2014 Nope, don't cut it down, the concentrate is what you want. Give your object a good 24+ hour soak and scrub it with a firm plastic brush. Repeat if necessary. Simple Green should remove all but the most stubborn of paints and leave only stains on the surface in a few nook-and-crannies. Don't worry about the stains, they vanish under the primer. Link to comment https://bolterandchainsword.com/topic/297315-stripping-fw-with-simple-green-question/#findComment-3820147 Share on other sites More sharing options...
Jamafore Posted September 28, 2014 Author Share Posted September 28, 2014 Ok thank you Link to comment https://bolterandchainsword.com/topic/297315-stripping-fw-with-simple-green-question/#findComment-3820215 Share on other sites More sharing options...
Ovidius Incertus Posted September 28, 2014 Share Posted September 28, 2014 I dilute a little when I'm doing a mass batch, simply to help take up some volume in my tupperware container (rather than pouring half or three quarters of a bottle away in a go). I soak for at least a day, then go at them with a toothbrush, rinse, inspect and soak again, if necessary. Link to comment https://bolterandchainsword.com/topic/297315-stripping-fw-with-simple-green-question/#findComment-3820264 Share on other sites More sharing options...
