I4 or I1?
bleedcrimson
I'm currently looking at building my own Honour Guard squad from bits from ebay. While pondering my load outs, i got to wondering whether to use power swords for more attacks at I4 or do i use power axes and strike at I1. With only having 1 wound i feel nervous striking last.
What are you thoughts?
Any feedback is welcome!
https://bolterandchainsword.com/topic/297788-i4-or-i1/
It's fine as long as you're not taking only axes. With a 2+ save most enemies that will be going through it will be striking at I1 too, and if they're not you won't be sending your Honour Guard against them ;) HG as best slicing through heavy infantry so the axe should be a backup just in case and for a bit of extra strength - something like 1 axe per 3/4 other weapon works well. A mace or two is worth considering if you have a larger squad but generally it's best to take swords for utility I think so you can strike at initiative and go through MEQs.
https://bolterandchainsword.com/topic/297788-i4-or-i1/#findComment-3829548
