DA FAQ November 2014
MoonPhoenix
ahhh at last - all singing from the same hymn sheet smile.png Thanks MoonPhoenix
Also pay attention, that now you don't need to upgrade LR to "Deathwing Vehicle" even if you take it as dedicated transport.
Unfortunately not. The rule only says that any land raider may purchase the update, regardless whether it is purchased as a dedicated transport for a deathwing unit or not. The rules making the upgrade mandatory for certain units are still in effect:
Deathwing Terminator Squads may select a Land Raider of any type as a Dedicated Transport (pg 104). This vehicle must be given the Deathwing Vehicle upgrade at additional cost.
Deathwing Knights may select a Land Raider of any type as a Dedicated Transport (pg 104). This vehicle must be given the Deathwing Vehicle upgrade at additional cost.
And they still did not address the ambiguity with the Terminator Sgt. censored.gif
That FAQ went very, very stealth... I didn't even notice a new one was up. I guess no more cool Lion's roar or PFG... It was a good run while it lasted. msn-wink.gif
Good job on the SoD. Finally the "i" is dotted and people stop using it with storm bolters.. rolleyes.gif
Bad bad job on the terminator sgt. That one needed more FAQ'ing than anything else.
Edit: Just mailed them this:
Thank you for the update.
To re-ask the biggest problem (to me) On the FAQ. Page 99 - Deathwing Terminator Squad, Options:
Rule as Written, the Deathwing Sargent cannot use a Thunder Hammer / Storm Shield or a pair of Lightning Claws because he does not have a Powerfist to exchange. Is this the designers intent?
I feel the errata should read:
"...may replace his Storm Bolter and Power fist or Storm Bolter and Power Sword with:
LCs...
TH/SS..
Thanks guys, If you could fix this up in the next year then I might get a couple boxes of Close Combat Termies...
Dean Hahn,
Dark Angel since 1992..
It seems that they wrote what they mean.
Today FAQ only update printed version of codex to digital version. In iPad codex DW sergant also doesn't have option to get TH+SS.
I hope you have more success than I did. I wrote them a similar email, about half a year ago and never got an answer besides the generic "we have received your email and will (maybe) get back to you."
I wrote letter and got answer after two or three days.
I think that you should wrote mails both to BL "contact@blacklibrary.com" and GW "Gamefaqs@gwplc.com".
Posted · Hidden by Bryan Blaire, November 21, 2014 - Third Violation of Swear Filter Dodging
mutha----ers ruined our codex again. can they make up their bloody minds about what their going to do with the pfg?? like seriously here a little consistency would be nice. so now our codex is worse again; thanks for making an already lower end codex even more terrible.
Ah, my mistake then, I guess. I only wrote to Gamefaqs@gwplc.com. And I just realized that the email went out in September, not half a year ago.
Brother Dean, did you send your email to blacklibrary? If not you may want to do that as it sounds nicer than mine. And please keep us informed if they answer.
It is a little disheartening to witness another incredibly poor attempt at rules writing; at least they produce the "Best Citadel miniatures in the world" ;)
I guess they got 3/4 ok on things that aren't really a problem, but the 1/4 PFG ruling is just bad and will continue to be bad until a new dex :devil:
For a bit there the PFG worked in vehicles again, using the Hull for measurements just like nearly every other bit of wargear in the game. Now it only protects the squad inside (WHY would they write it like that? they can't be targeted anyway, very poor choice of wording for rule makers).
Anyway, it's back to using a Libby or techie on a bike to keep DW Raiders alive a bit longer tongue.png
To me it was a far better aesthetic look to have all our critters inside our LandRaiders instead of that one dude trailing along behind to add protection. There are so many ways to abuse things in the game that a little leeway on the PFG wouldn't have broken anything... more than they are anyways msn-wink.gif
stobz
On the plus side it clarified the standard of devastation and Lion's Roar issues which I felt folks were gerrymandering to the detriment of RAI and common sense. On the down side, well, pretty much everything else. I like how in a game filled with Captain :cuss and other insane nonsense, it was the PFG from the army least fielded competitively that they went after. With leadership and vision like this, they should run for Congress...
Wait, PFG got even worse. It only works for the embark models.. it doesn't even apply to the Land Raider. censored.giffurious.gif
And considering that models embarked in an enclosed vehicle are not even in play, or subject to any in-game effects, the PFG does literally nothing in this case.
If said transport is destroyed, they are effected. They all get hit with str 4 hits right? Not sure if the PFG helps out with that though... Also what if the PFG was in a Land Speeder? The PFG could help out in a open top transport a bit....
