Commander Dawnstar Posted December 23, 2014 Share Posted December 23, 2014 I have something of a bad history when it comes to building metal and plastic vehicles - the 3rd Edition Baal Class Predator scarred me for life - and now I've finally reached the point where I'm looking to acquire my Exorcists I'm feeling a similar sort of trepidation. I certainly like the model, but I've heard a number of horror stories about warped metal casts and general difficulty in putting the thing together. Truth be told, I've actually been courting the idea of converting Whirlwinds both to spare myself the trouble and save some money (Perhaps as much as £12 per tank) but obviously that just wouldn't be the same as using the real kit. So like the title says, just how horrible a business is building the Exorcist? Any tips or horror stories from your own experience? Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/ Share on other sites More sharing options...
Duke Danse Macabre Posted December 23, 2014 Share Posted December 23, 2014 In truth, not that bad, needs a odd pin to make sure the amo loader will never come off, aside from that fill the gaps in the organ pipes with green stuff and your good. In all honesty there is a dozen gw metal lots which are much worse and that's to say nothing of forge world. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898182 Share on other sites More sharing options...
Dread Posted December 23, 2014 Share Posted December 23, 2014 When the kit first came out I just flat refused to get one, thought it was, well, ugly. After doing a whirlwind conversion that was okay, it felt to space marine so I got one. After test fitting each piece a lot of filing on the pipes and tweaking the top piece and test fitting again they get to where they fit as good as they can then use filling putty to fix openings. It's not too difficult, I had 3 up until a few months ago I had to sell my sisters and now the guy that bought them has so much fun wiping me off the table with them and the exorcist is his fav. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898187 Share on other sites More sharing options...
Commander Dawnstar Posted December 23, 2014 Author Share Posted December 23, 2014 Fair enough. I think a big part of my concern comes from the fact that I'm someone who has no experience working with green stuff or pinning, so fixing up any of the more obvious problems, or making sure pieces stay stuck fast, feels a little outside my comfort zone. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898193 Share on other sites More sharing options...
BitsHammer Posted December 23, 2014 Share Posted December 23, 2014 It's time consuming more than it's actively horrible. Pin and gap fill everything and you'll be fine. The Penitent Engine on the other hand is the worst thing ever. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898265 Share on other sites More sharing options...
Grgobart Posted December 23, 2014 Share Posted December 23, 2014 For my second Exorcist, I actually bent the warped metal part, the organ sits on, back straight, to see if it could be fit without filling any gaps. The result was, it does, but only after I cut back the underlying Immolator-plastic-top-part in a few places. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898268 Share on other sites More sharing options...
Duke Danse Macabre Posted December 23, 2014 Share Posted December 23, 2014 To be honest with resin becoming used more and more you will need to learn how to pin and green stuff, its startin to become hobby basics but its not hard, remember your filling gaps and smoothing it over, nothing too taxing. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898428 Share on other sites More sharing options...
WarriorFish Posted December 23, 2014 Share Posted December 23, 2014 As a comparison, have you built a Thunderfire Cannon in metal? :lol: It's not the worst kit no, more of a labour of love as mentioned. Just stick at it and it'll not be too much work plus after such an act of devotion the Emperor will no doubt bless it! Using a SoB-ified Whirlwind is always a good option if you don't want to get the Exo though :) Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898529 Share on other sites More sharing options...
Thoqqu Posted December 23, 2014 Share Posted December 23, 2014 The hands... the horror... I should probably try gale force 9 glue and hardener (or what ever it's called). People say it sticks under second and stays put. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898530 Share on other sites More sharing options...
*Furyou Miko Posted December 23, 2014 Share Posted December 23, 2014 I've had some luck with jeweller's paste on other models in the past. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898601 Share on other sites More sharing options...
WarriorFish Posted December 23, 2014 Share Posted December 23, 2014 Gel super glue is a life saver for me, a lot easier to work with and connect poorly joining bits as well as work as a bit of a filler :) Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898617 Share on other sites More sharing options...
Naminé Posted December 23, 2014 Share Posted December 23, 2014 I used a tiny amount of Greenstuff and plenty of super glue on mine. Was fairly straightforward to be honest and went together fine, though I may have been lucky with that particular model. I have another one yet to build but I'm in not too worried about it. I don't think its a model you need to pin (the thought occurs that I am not using GW glue, which I have heard is not very good). Compared to Penitent Engines the Exorcist is a walk in the park :p Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898657 Share on other sites More sharing options...
Spacefrisian Posted December 23, 2014 Share Posted December 23, 2014 Its a piece of cake compared to the PP leviathan. If you dont know what that is than i advise you to get it and try to put it together without getting the urge to curse and throw the model into some random corner of your room (and that was the nice version of my feelings) Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3898805 Share on other sites More sharing options...
Goonbandito Posted December 26, 2014 Share Posted December 26, 2014 If you want an alternative to the Organ Pipe Exorcist, get an Immolator kit and find some Typhoon Missile Launcher bitz (they are in the Space Marine Landspeeder kit, or ebay etc). Mount the two typhoon missile launchers on the back of the Immolator turret, and mount the turret itself at the rear of the vehicle. I bought my sisters collection second hand, and that's how my Exorcists were done. I think it looks quite good if you want a more 'military vehicle' feel as opposed to 'space gothic'; far less Space Mariney than a Forgeworld/Whirlwind conversion too. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3901385 Share on other sites More sharing options...
MrFlutterPie Posted December 27, 2014 Share Posted December 27, 2014 I use a Whirlwind for my exo's but I added a Forgeworld front plate and doors to make it a bit more "sobish". As for pinning and filling in gaps with greenstuff it's not too hard and you will pick it up quick with a bit of practice. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3901619 Share on other sites More sharing options...
Frater Cornelius Posted December 27, 2014 Share Posted December 27, 2014 Build a few Heldrakes before you take a stab at the Exorcist. You will be amazed how good it feels not to have your fingers punctured :D Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3901649 Share on other sites More sharing options...
Commander Dawnstar Posted December 31, 2014 Author Share Posted December 31, 2014 I now have two Exorcists to build. Wish me luck, friends. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3905378 Share on other sites More sharing options...
grendal1989 Posted December 31, 2014 Share Posted December 31, 2014 Good luck. I hated that stupid warped plate the pipes sat on. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3905411 Share on other sites More sharing options...
Duke Danse Macabre Posted December 31, 2014 Share Posted December 31, 2014 Don't forget the groon stuff!... Also put the driver and loader in after painted... Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3905413 Share on other sites More sharing options...
WarriorFish Posted December 31, 2014 Share Posted December 31, 2014 I look forward to seeing them! Don't forget that the more blood, sweat and tears that goes into something the better it performs. Especially if it's literal blood, sweat and tears :lol: Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3905415 Share on other sites More sharing options...
*Furyou Miko Posted December 31, 2014 Share Posted December 31, 2014 All the blood sacrifices in the world can't stave off New Model Syndrome though. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3905461 Share on other sites More sharing options...
WarriorFish Posted December 31, 2014 Share Posted December 31, 2014 My models tend to perform well on their first outing, I must be lucky! Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3905522 Share on other sites More sharing options...
FashaTheDog Posted December 31, 2014 Share Posted December 31, 2014 If you really have trouble keeping the model together, which is unlikely, you can use two part epoxy, you will not need to fill gaps or worry about the joints breaking. Ever. Don't get me wrong, it may break, just not where you glued it . Also, use epoxy outside in a well ventilated area. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3905759 Share on other sites More sharing options...
Malovence Posted January 8, 2015 Share Posted January 8, 2015 My first Exorcist wasn't that bad, not going to lie, I was on those pipes for over an hour before they wouldn't fall off. Haven't pinned them though, just copious amounts of Super Glue. Though my advice would be ignore GW Super Glue, i swear because of the few Sisters players and how few Exorcists and Penitent Engines they probably sell per year they made their glue weaker, because I refuse to believe anyone has ever successfully built either with just GW glue since it's incredibly weak. But all in all my Exorcist was a good experience, not a horror show, but did require abit of calm. Though it could be I got lucky with mine since I have read some horror stories about them. Only need two more then I have my 3, I think any I have after that I'll probably convert from Immolator and Whirlwind/Land Speeders. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3914453 Share on other sites More sharing options...
*Furyou Miko Posted January 9, 2015 Share Posted January 9, 2015 Ugh, found out yesterday that GW clippers "aren't designed for metal" any more when I tried to get a replacement set after a single use destroyed the edge. They're pretty. But the metal is so soft that I'd be shocked if they even cut through plastic thicker than a flash tag. Fortunately the manager likes me so he let me buy a £20 voucher off him for £2 and the broken clippers. Link to comment https://bolterandchainsword.com/topic/300879-just-how-unpleasant-is-building-the-exorcist/#findComment-3914759 Share on other sites More sharing options...
