Just Another Guard Player Posted December 27, 2014 Share Posted December 27, 2014 I'm currently still building my Death Korps of Krieg Army and have so far tried to stick to the fluff as best I can by buying the Earthshaker gun carriages off of Forgeworld if which I have the first two (I have six of them in my 2000 point list). They are nice models to be fair but...well I'm not in that high paying a job and the £71 per model for the gun alone is holding me back quite badly. I was just wondering what peoples feeling were if it was an accepted convention to just use the basic GW Basilisk model in such cases and shake on it between gentlemen that your using the immobile artillery rules etc. (even though it is represented on a vehicle chassis)? Is that something I would be likely to get away with playing in store or anywhere other than with my close friends? Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/ Share on other sites More sharing options...
scatmandoo Posted December 27, 2014 Share Posted December 27, 2014 If I am right in my thinking, with some careful assembly you should be able to do it so that you can leave the gun and mounting section removable from the Chimera chassis when needed. Like this on an image from google. https://www.google.co.uk/search?q=basilisk+removable&source=lnms&tbm=isch&sa=X&ei=w9qeVOT7N8SBUbz7g6gL&ved=0CAcQ_AUoAQ&biw=360&bih=592#facrc=_&imgrc=JwF8HOo_OQmJKM%253A%3BFjrPo2XWHymiZM%3Bhttp%253A%252F%252Fimages.dakkadakka.com%252Fgallery%252F2012%252F9%252F22%252F413825_sm-Basilisk%252C%252520Chaos%252C%252520Conversion%252C%252520Marauders%252C%252520Renegade%252520Militia%252C%252520Tank%252C%252520Traitor%252520Guard.JPG%3Bhttp%253A%252F%252Fwww.dakkadakka.com%252Fdakkaforum%252Fposts%252Fblog%252F300%252F432972.page%3B600%3B519 Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/#findComment-3901872 Share on other sites More sharing options...
hendrik Posted December 27, 2014 Share Posted December 27, 2014 if cost is a problem you could try to model your own earthshaker emplacements from plasticard. I've done that for 3 emplacements (even got casts made for them, but in hindsight it would have been cheaper and easier to actually just make them completly from plasticard.) to make them i got my hands on the following tubes, all fitting into eachother: 1.6mm, 1.4mm, 1.2 mm,1.0 mm, 0.8 mm. in addition you'll also need some plasticard plates (1 mm) will do to construct the carriage itself. For wheels you can get cheap lego technic wheels of ebay. even the mount if the gun can be made easy by using lego technic curved halfbeam (3x3) to make the carriage you can find patterns online for papercraft earthshaker carriages. Honestly, i think this option will be much nicer, not to mention cheaper! not to mention easier to explain to your opponents too. Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/#findComment-3901946 Share on other sites More sharing options...
WarriorFish Posted December 27, 2014 Share Posted December 27, 2014 You can definitely make up your own, or modify the Basilisk as hendrik says. £71 is pretty expensive so it'd take a while to save up for all of them! Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/#findComment-3902018 Share on other sites More sharing options...
CoffeeGrunt Posted December 27, 2014 Share Posted December 27, 2014 What I'm planning to do is magnetise the Earthshaker into the Chimera chassis it comes with, then grab a hold of the Lascannon mount from the Imperial Bastion kit, to use as a swappable mount for it as an Earthshaker Platform. FW sadly stopped doing the ol' Earthshaker Platform, it only does the carriage now, which is both more expensive and less attractive in style, IMO. Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/#findComment-3902157 Share on other sites More sharing options...
Just Another Guard Player Posted December 28, 2014 Author Share Posted December 28, 2014 Thanks for the tips guys. From what you've said I think I'll be OK to go ahead and buy the Basilisks. I'll try and my hand at keeping the weapon section and the chassis separate and see how it goes / looks. Failing that I'll just deploy the vehicle as a static installation and we'll just pretend it doesn't have a heavy bolter (or an engine). Plus you never know when you might need a full grown Basilisk for the next army, I guess. Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/#findComment-3902453 Share on other sites More sharing options...
WarriorFish Posted December 28, 2014 Share Posted December 28, 2014 Indeed! Don't forget to show us pictures :tu: Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/#findComment-3902480 Share on other sites More sharing options...
gomericus Posted January 1, 2015 Share Posted January 1, 2015 when I built my earthshakers I bought two cannon assemblies off bartertown for like 20bucks,,then added my own carriages ,just a thought.or go with something like this? http://www.toysoldiersdepot.com/store.php?seller=thedustyloft&Tsearch=cannon&pd=3130559 Link to comment https://bolterandchainsword.com/topic/301064-basilisks-v-earthshaker/#findComment-3906544 Share on other sites More sharing options...
