How do you distinguish your regular dudes?
ixzion
As a long time player of Space Marines of different forms and shapes I am finally starting to look at the more squishy and puny humans of the Astra Militarum. I have bought some infantry but I have yet to start painting them. I'm still deciding on the uniform and I am also running into new questions that I haven't really encountered before; how do you recognize which regular Joe belongs to which unit or even to which infantry platoon?
I am interested to hear if you have some kind of system to mark infantry squad troopers out as belonging to a specific squad, a specific platoon and a specific regiment?
Hey ixzion,
I organize my platoons by giving the model a coloured stripe on the shoulder pads, for sergeant and special weapons within the squad I put the
platoon colour on the helmet too. Then each squad is numbered.
Hope that helps.
Most of my infantry have two numbers painted in white on the underside of their bases.
For example:
1-2 is a member of the second squad of first platoon.
2-1 is a member of the first squad of second platoon.
1-p a member of the 1st platoon's command squad.
That's how I differentiate between them in an Out Of Character (to use the RPG term) way.
In Character use coloured stripes on hats, helmets, shoulders and trousers to indicate squad type (command = yellow, support = blue, line = red, assault = green. Based on old RT-era IG markings).
I intend to add numbers to shoulder pads to indicate squads and platoons (akin to the under-base markings I mentioned earlier). Company and regiment markings are saved for company command squads, banners and command tanks.
My original paint job on my metal cadians had 3 digit squad numbers on the non-aquila shoulder pad for line squads (no rhyme or reason to the numbers, a platoon might consist of squads 369, 343, and 662), two digits for platoon command squads, and a skull for company command.  When I repainted them five years ago, I left the numbers off, they just look better that way.  Anyway, numbers under the base is a good way if you care to keep them that well organized...with 223 of them, I've long since given up...cleanup consists of slotting sergeants and special weapons per squad, then filling in riflemen.
/edit/  Also, I'm probably influenced by the real world...I've never seen uniforms marked with any unit designation below regimental level!
Thank you! You are gving me great ideas how I will do my troops. I was worried that during play I would accidentally mix up which guy contained to which unit in the case of two or more infantry squads running close together. But of I add some kind of squad marking then I should probably be able to keep the squads apart.
It's not as bad as you think, I don't have any squad markings on my troopers and I have no problems identifying who belongs where. Having squad markings will help and looks cool, but it does limit you on model use which is my problem with it. None of my armies have squad markings for this reason, so I can put any model in any squad :)
For quickness and to save painting on the actual models, what about applying some kind of colour coding marks on the rear face/edge of the base?
They won't show from the model's front but you'll see them as you look down on them from behind.
Thank you fellow commanders for some xcellent ideas and suggestions. Commander Scatmandoo makes a really good point of not having squad markings as it is then possible to mix and match units. What I think I will do is to add squad markings on regular troopers but leave the special weapons and sergeants without so they can belong to any squad.
I have a colourd stripe (denoting company in fluff, but on the tabletop it it denotes weather they are BS4 or not, desreguarding the officers) then a number between 1-9 to denote platoon (again, in fluff, just to break up squads on TT) and then a secound number below that one 0-9 to denote specific squad (with 0 being an officer squad). And finaly to really show off the difference between my regular guardsmen and my veterans, the Veterans ALL have backpacks (again, disreguarding officers)
So for example a guardsman with a Yellow stripe with a 2 above a 1 would mark him as a member of 5th (veteran) company, 2nd platoon, 1st squad.
I also don't distinguish regular dudes because 1: I mostly play Catachans these days, so no place in the model to put stripes and the like, and 2: when it is their time to die they all die in the same gory way so why bother trying to recognize Bob from Tommy?
Don't worry. I have found that during a game it us not so difficult to discern who belongs where.
I use a three digit shoulder number for my squads - company,platoon,squad e.g 113 is 1st company, 1st platoon, 3rd squad. 1st, 2nd, and 3rd platoons are infantry squads, 4th platoon is veterans, 5th are special weapons and 6th are heavy weapons. That allows me to 'attach' special weapons to different squads as and when I need them, while heavy weapon teams to attach to infantry squads or be deployed as full squads, and I can still tell who belongs where! ( I'm a bit particular that way!)
No differentiation between squads here. I simply organise Guardsmen based on what equipment they're carrying, and dole them out to the ranks that way. So, say, my Platoon of two squads of ten would be assigned two Laspistol/CCW Sergeants, two Flamers, potentially a Vox Caster, and the rest just generic Lasgun-wielding Guardsmen.
I have a different paint scheme beetween vets and regular troops. But amongst the regular troops, I don't mark them. If anything, I will probably do as Kierdale and put something underneath the base, or on the "backside" like I do with my O&G.
The average guardsman lasts about 15mins
 Isn't it 15 hours like the book.
My Veterans wear Fire Warrior armour to differentiate them, but that's because I'm a filthy heretic.
OUT OF LIIIIKKKEESS.
For my khorne berzerker units I painted a bone line across a shoulder pad in one of 4 orientations for each squad and then a black line of half the length in one of eight on each member of each squad to keep them differentiated when they all rush in.
EDIT: Came back with likes to spare.
You have given me a lot to consider. Perhaps I should add that I'm planning to do Death Korps and the models look very similar to one another. But perhaps it's not as big a problem as I first had expected. I should probably start painting them and worry about unit marks and the like later :)
