Major_Gilbear Posted February 12, 2018 Share Posted February 12, 2018 So today this has had an undercoat then black from below, white from above then grey on all the surfaces. Ive now started to weather it.... this is going to be a loooooooooong process! Im using oil paints and the dot process with white, black, brown and a tiny bit of green I'll post a pic when I do the next panel Ive done the door and the level immediately above it. Its hard to photo at the moment as its still wet. It will look better post a purity seal It may be a long process, but it looks worthwhile judging from your results! ;) Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5009052 Share on other sites More sharing options...
UltraRich Posted February 28, 2018 Author Share Posted February 28, 2018 (edited) Triple update tonight! Im continuing to weather the bastion although Im getting bored with it now. I dont know if Im over weathering it as it looks like its had a real beating. Finished another heavy weapons team with two arguing guards Ive also finished the base for Sly Edited September 14, 2019 by UltraRich librisrouge, Tallarn Commander, duz_ and 6 others 9 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5022176 Share on other sites More sharing options...
Bjorn Firewalker Posted March 1, 2018 Share Posted March 1, 2018 Good job on the fortress and the heavy weapons team. I love the base you made for Marbo. UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5022521 Share on other sites More sharing options...
WarriorFish Posted March 1, 2018 Share Posted March 1, 2018 Weathering looks great, you could easily add more if you wanted :tu: UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5022632 Share on other sites More sharing options...
Feral_80 Posted March 1, 2018 Share Posted March 1, 2018 Excellent stuff - can I ask what do you use for weathering? Is it powders? Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5022652 Share on other sites More sharing options...
UltraRich Posted March 1, 2018 Author Share Posted March 1, 2018 Excellent stuff - can I ask what do you use for weathering? Is it powders? Thanks Not yet, its just oil (brown, black, white, green) pulled out with thinners. Google oil dot weathering. Ill then seal it and then hit it with some powder on some of the top areas walter h 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5022858 Share on other sites More sharing options...
Inquisitor lorr Posted March 3, 2018 Share Posted March 3, 2018 Forgive me if this has already been asked and answered - do you mind sharing your recipe for the green armour? Cheers! Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5024377 Share on other sites More sharing options...
UltraRich Posted March 4, 2018 Author Share Posted March 4, 2018 Forgive me if this has already been asked and answered - do you mind sharing your recipe for the green armour? Cheers! No worries Its basically green and brown so paint (or spray) them Steel Legion Drab Then paint the armour Castellan Green Then wash it all with a watered down Agrax earthshade For the brown then highlight from pure steel legion Drab to a mix with Tallarn sand then a mix with Karak Stone For the green then highlight with pure Castellan Green to a mix with Loren Forrext and then a mix with Straken Green I try and blend all of the armour highlights and sometimes use Vallejo glaze medium to help get a smooth transition. This does take longer though so you cant crank out minis I'll then do edge highlights with whatever colour and white Hope that helps Thanks walter h and Inquisitor lorr 2 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5024966 Share on other sites More sharing options...
Inquisitor lorr Posted March 5, 2018 Share Posted March 5, 2018 Forgive me if this has already been asked and answered - do you mind sharing your recipe for the green armour? Cheers! No worries Its basically green and brown so paint (or spray) them Steel Legion Drab Then paint the armour Castellan Green Then wash it all with a watered down Agrax earthshade For the brown then highlight from pure steel legion Drab to a mix with Tallarn sand then a mix with Karak Stone For the green then highlight with pure Castellan Green to a mix with Loren Forrext and then a mix with Straken Green I try and blend all of the armour highlights and sometimes use Vallejo glaze medium to help get a smooth transition. This does take longer though so you cant crank out minis I'll then do edge highlights with whatever colour and white Hope that helps Thanks Awesome! Muchos appreciated! UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5025704 Share on other sites More sharing options...
UltraRich Posted March 18, 2018 Author Share Posted March 18, 2018 (edited) Ive had a plan for the chaos cultist champion since I saw its release and I finally managed to snag one this week I then set about taking the head and both arms off and using a dremmel to remove the body in the coat down to the belt I then replaced this with a trimmed down guards body Ive updated the chainsword by thinning it down and making it double sided. Ive also replaced the head with a FW one. This is all just blue tacked together while I fix the arms and create the folds in the material. Im not sure what he will be now though. A commisar or field captain Edited September 14, 2019 by UltraRich Tallarn Commander, 4CIN87, duz_ and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5034951 Share on other sites More sharing options...
WarriorFish Posted March 19, 2018 Share Posted March 19, 2018 That's some great work, I think he could easily work as either :tu: UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5035159 Share on other sites More sharing options...
Res Ipsa Loquitur Posted March 19, 2018 Share Posted March 19, 2018 This is all just wonderful stuff but I think my favourite thing is that this is described as a 'small' IG force. I feel like getting carried away with things is a brilliant trait. I began a few years back with a vague idea to base a Slaanesh force very loosely on a (then) romantic partner who hailed from Sevastopol and today have a 30,000 point soup list I'm working to (and that will never, ever come close to actually existing anywhere but Excel) with very specific design cues stolen from Russian/Soviet history. UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5035487 Share on other sites More sharing options...
Colonel Cross Posted March 19, 2018 Share Posted March 19, 2018 That conversion is fantastic! UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5035789 Share on other sites More sharing options...
UltraRich Posted September 13, 2019 Author Share Posted September 13, 2019 Ok so Photobucket have nerfed all my photos and as I did a check yesterday Im 100 photos over on this thread alone!! So Ive now go the fun fun task of editing 17 pages of history to point at the B&C gallery In the meantime heres something Im working on. More pics to follow once Ive got a few rivets on it Arkaniss, WarriorFish and duz_ 3 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5387960 Share on other sites More sharing options...
WarriorFish Posted September 13, 2019 Share Posted September 13, 2019 Good to have you back Rich, this looks promising some sort of artillery piece perhaps? UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5388051 Share on other sites More sharing options...
duz_ Posted September 13, 2019 Share Posted September 13, 2019 Intriguing... When will we see moar :) Good thing the B&C gallery doesn't have that problem ;) UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5388116 Share on other sites More sharing options...
UltraRich Posted September 13, 2019 Author Share Posted September 13, 2019 This is what its going to become. It was a glue bomb when I got it off ebay so the whole back end has gone and replaced with plasticard and new exhausts. The turret is a bane blade turret cut in half and about 2 centimetres removed from the middle Hopefully get some paint on next week WarriorFish, Arkaniss, duz_ and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5388380 Share on other sites More sharing options...
Bjorn Firewalker Posted September 14, 2019 Share Posted September 14, 2019 The turret is a bane blade turret cut in half and about 2 centimetres removed from the middle This looks most promising. Will you kitbash two sponsons and sponson-mounted weapons? Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5388552 Share on other sites More sharing options...
UltraRich Posted September 14, 2019 Author Share Posted September 14, 2019 I thought about adding sponsons but it looks better for streamlining the sides than bulking it out. Might just add some stowage but it depends on my GS skills! Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5388618 Share on other sites More sharing options...
Gederas Posted September 14, 2019 Share Posted September 14, 2019 Ok so Photobucket have nerfed all my photos and as I did a check yesterday Im 100 photos over on this thread alone!! So Ive now go the fun fun task of editing 17 pages of history to point at the B&C gallery The expression of the Ogryn in your profile picture says it all :lol: in any case, the new artillery piece is looking cool! :tu: Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5388757 Share on other sites More sharing options...
ranulf the revenant Posted September 17, 2019 Share Posted September 17, 2019 Such neat guard models ☺️ UltraRich 1 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5391119 Share on other sites More sharing options...
UltraRich Posted September 25, 2019 Author Share Posted September 25, 2019 So Ive started to paint this Excuse the poor image but Im using my phone So far its had its base coat and general spray highlight. Full oil wash and rust weathering a bit of highlighting and now on to some powders! duz_, robofish7591, ranulf the revenant and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5396381 Share on other sites More sharing options...
UltraRich Posted September 27, 2019 Author Share Posted September 27, 2019 Once this is done Im thinking about building a troop dropship out of a storm raven I can sort the wings and troop areas out using plasticard but do you think the front of a SR looks IG enough if I just paint it green? or would you say change it up to re style it Think big Valkerie..... thats what Im going for Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5397252 Share on other sites More sharing options...
WarriorFish Posted September 27, 2019 Share Posted September 27, 2019 The Stormraven is a bit blockier than Guard, but not majorly so. I think some modification would be good to make something a bit more streamlined but probably be fine once you change the model enough with other bits if that's too much work? Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5397291 Share on other sites More sharing options...
duz_ Posted September 27, 2019 Share Posted September 27, 2019 What about a Coruvs Blackstar :D Link to comment https://bolterandchainsword.com/topic/303832-small-ig-and-scion-force/page/21/#findComment-5397311 Share on other sites More sharing options...
