Twisty Posted March 12, 2015 Share Posted March 12, 2015 So I want to have a mortis dred or two in my heresy era Salamanders army and with FW prices and shipping being a bit more than my budget can handle right now I´ve decided to re-purpose some old dreds with third party bits. The bits I have in mind are these: http://puppetswar.eu/product.php?id_product=224 Have anyone here tried using them on a drednought and how do they look? Are there any other third party bits that would look cool as missile launchers on a dred? Also, from a gaming standpoint, what do you prefer on a anti-air dred: Autocannons, Missiles or lascannons? Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/ Share on other sites More sharing options...
Carlson793 Posted March 12, 2015 Share Posted March 12, 2015 I'm assuming you'll be arm mounting them as opposed to carapace mounting? For some reason, I think it will look a good bit like the Battletech Longbow/Robotech Whatever (which wouldn't be such a bad thing)... http://www.sarna.net/wiki/images/7/74/Longbow_LGB-0W_SLSB.jpg ...which on a Salamanders Contemptor would look something like (roughly to scale for the Puppet Wars missile launchers)... Carapace mounted. one might fit on the torso - would be kinda tight, though. Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975299 Share on other sites More sharing options...
Twisty Posted March 12, 2015 Author Share Posted March 12, 2015 Huh, didn´t think they where that big I was planning on mounting them on a normal plastic dred though, in about the same position as the normal missile launchers, at the shoulder pivot. The lunchers would probably look pretty good on a contemptor dred, but I´m worried they will clash with the boxy look of the standard dred. Any ideas? Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975313 Share on other sites More sharing options...
Carlson793 Posted March 12, 2015 Share Posted March 12, 2015 They're 35mm long according to the PW store page. My scaling is a bit off (too big), but not by terribly much (the arm on the right arm is pretty close; on the left I forgot to account for the angle). For a Mk IV/V Dread, I'd go with Kromlech's Zephyr Missile Launcher Mk 2. While both the base Zephyr and the Mk 2 are one piece launchers, the Mk 2 looks like it could be split down the middle to produce two launchers. Not sure on the scale, though - at a guess, it looks like Whirlwind sized. (Zephyr on left; Zephyr Mk 2 on right) http://bitsofwar.com/222-thickbox_bosky/zephyr-missile-launcher.jpg http://bitsofwar.com/259-large_bosky/zephyr-missile-launcher-mk2-.jpg Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975342 Share on other sites More sharing options...
Twisty Posted March 12, 2015 Author Share Posted March 12, 2015 I did a bit of searching and found the measurments for the Zephyr Mk 2 launcher, but I couldn´t find any measurments of the dreadnough missile arms to compare with. I don´t have my dreds nearby at the moment, you don´t happen to know the size of the arm section do you? I was thinking I could maybe stack two modified Zephyr launchers on either side, might look real good with some plasticard magic added http://bitsofwar.com/255-thickbox_bosky/zephyr-missile-launcher-mk2-.jpg Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975404 Share on other sites More sharing options...
Bjorn Firewalker Posted March 12, 2015 Share Posted March 12, 2015 Personally, I think the missile launcher should be mounted overhead, in the same position as a Terminator's Cyclone missile launcher. The Dreadnought's free arm should bear a close combat weapon. Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975425 Share on other sites More sharing options...
Carlson793 Posted March 12, 2015 Share Posted March 12, 2015 Okay, Twisty, measuring my handy dandy why-haven't-you-asssembled-me-yet-father-I've-been-a-good-dreadnought Salamanders Contemptor, a carapace mounted one can fit if it's slightly forward of center - otherwise, you might be hitting the dread's exhaust. Arm mounted, I think it might work best without the usual shoulder cap - just attach the Zephyr's mounting base directly to the dread's shoulder joint. Rules-wise, making a Contemptor's arms missile launchers means you'd have to run it counts-as a Mark V Mortis - Contemptors can only take a single carapace-mounted missile launcher. EDIT: Oh, and while I'm compiling my list of bits sellers... Also check out Secret Weapon Miniatures. Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975475 Share on other sites More sharing options...
Twisty Posted March 13, 2015 Author Share Posted March 13, 2015 Well the thing is that i´m not talking about mounting them on a contemtor dred, just a standard castaferum plastic gw drednought. I was thinking about doing something along the lines of this: http://i.imgur.com/TWmeNJo.jpg But I think they are to small for that, so maybe I could stack them like this: http://i.imgur.com/AAFzPv5.jpg The secret weapon ones are also nice, but think they are even smaller. But on the other hand their design will look better if I decide to stack a bunch of launchers. Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975766 Share on other sites More sharing options...
Stoic Raptor Posted March 13, 2015 Share Posted March 13, 2015 I've got one of those Mk2 Launchers - it's sized to be used as a Cyclone if that helps give you an idea of the scale. Link to comment https://bolterandchainsword.com/topic/304540-puppetswar-missile-launchers-for-a-mortis-dred/#findComment-3975819 Share on other sites More sharing options...
