Malus Trux Posted March 18, 2015 Share Posted March 18, 2015 Am I reading this right? This is the entry for Sternguard weapon options: Two Veterans may each take one item from the Special Weapons or Heavy Weapons list. So does this mean BA can keep their bolter & special ammo AND get spec/heavy weapons? Link to comment Share on other sites More sharing options...
Fahlnor Posted March 18, 2015 Share Posted March 18, 2015 Does the entry for special or heavy weapons itself require the model to swap the bolter? I haven't got the Codex to hand as I'm working, but I suspect that the entry in the wargear list will say that you don't keep your bolter. Link to comment Share on other sites More sharing options...
Dolchiate Remembrancer Posted March 18, 2015 Share Posted March 18, 2015 Have you checked either of those lists if it specified that a model must replace a weapon to take one from the list? Link to comment Share on other sites More sharing options...
Stercus Posted March 18, 2015 Share Posted March 18, 2015 If it's formatted the same way as the space marines codex, it will say in the list of available weapons that they come as a substitute for the boltgun. Link to comment Share on other sites More sharing options...
casb1965 Posted March 18, 2015 Share Posted March 18, 2015 Codex says Heavy Weapons A model may replace its boltgun with one of the following: Special Weapons A model may replace its Melee weapon or boltgun with one of the following: So it's in replacement of rather than in addition to. Link to comment Share on other sites More sharing options...
Malus Trux Posted March 18, 2015 Author Share Posted March 18, 2015 Ah I see. Sorry. Just switched over from the old Codex. Thanks y'all. Link to comment Share on other sites More sharing options...
