Wildfire Posted May 1, 2015 Share Posted May 1, 2015 Are there any IG models that come with boltguns? Also, what's the cheapest source of laspistol/ccw models? Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/ Share on other sites More sharing options...
librisrouge Posted May 1, 2015 Share Posted May 1, 2015 The command squad box (Catachan for sure but maybe also cadian) comes with one boltgun. I converted a half dozen from space marine scout weapons from back when I indulged a bit of weakness and played marines. Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4026261 Share on other sites More sharing options...
steellegionnaire85 Posted May 1, 2015 Share Posted May 1, 2015 Laspistols are in every tank kit one a piece I think two or three in the command kits. They are your best bet. Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4026281 Share on other sites More sharing options...
SW1 Posted May 1, 2015 Share Posted May 1, 2015 The old combat sprue also is worth while looking for as they have laspistol and chainsword (right size for guard too small for marines). I can have a rummage if you want some. Drop me a PM with your address/how many you need and I'll see what comes up in my next rummage. Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4026392 Share on other sites More sharing options...
our_baz Posted May 1, 2015 Share Posted May 1, 2015 @librisrouge has hit the nail on the head. Catachan command for boltgun, cadian for bolt pistol. Or easy conversion of SM scout bolter or use bolter from basic SM spure. You can get Las pistols in all cadian boxes, the best source of CCW is the cadian command for power first/sword, plasma pistol and chainsword Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4026415 Share on other sites More sharing options...
Kontakt Posted May 1, 2015 Share Posted May 1, 2015 You can also convince a marine player with scout squads to give you some arms with boltguns. The bits may also be available from somewhere on the interwebs. Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4027150 Share on other sites More sharing options...
RADU LYKAN Posted May 2, 2015 Share Posted May 2, 2015 what numbers are you talking? if you are thinking a whole squads worth then bitz sites or 3rd party companies have stuff to offer Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4027778 Share on other sites More sharing options...
Wildfire Posted May 5, 2015 Author Share Posted May 5, 2015 Yeah, I'm looking at loads of inquisitor acolyte meatshields. I was originally thinking Necromunda gangers, but apparently they're oop and outrageous on ebay. Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4031179 Share on other sites More sharing options...
SW1 Posted May 5, 2015 Share Posted May 5, 2015 Yeah, I'm looking at loads of inquisitor acolyte meatshields. I was originally thinking Necromunda gangers, but apparently they're oop and outrageous on ebay. Yeah ... They can be a little expensive. However it depends on the models in question. Which house were you interested in the look of? Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4031508 Share on other sites More sharing options...
steellegionnaire85 Posted May 7, 2015 Share Posted May 7, 2015 If your looking for enforcers, you can make some out of space marine scouts and different heads. There is a company that makes enforcer heads. Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4033143 Share on other sites More sharing options...
Wildfire Posted May 7, 2015 Author Share Posted May 7, 2015 I was thinking the Goliaths, just because I have a dozen or so already that would probably work. If I had to get them from scratch, the Delaque and Redemptionists were pretty cool looking. Link to comment https://bolterandchainsword.com/topic/306941-boltgun-ig-laspistolccw-ig/#findComment-4033671 Share on other sites More sharing options...
