Brother Amarel Posted May 28, 2015 Share Posted May 28, 2015 One thing I've found problematic with my AdMech is the correct carrying solution. There are a lot of different sizes to contend with and some very delicate pieces, that stick out quite a distance. The closest I've found to suit my needs is the old black plastic GW carry case (with red foam), but even that has issues with various models. So, what's everyone using? Any great pieces of advice / early wisdom to share? Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/ Share on other sites More sharing options...
Leman Russ SW Posted May 28, 2015 Share Posted May 28, 2015 The new cases GW do are really good for awkward shape models and hold loads. Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4061621 Share on other sites More sharing options...
Battybattybats Posted May 28, 2015 Share Posted May 28, 2015 Yeah but how would you use the new cases in a way that won't snag and snap all the aerials and rad-censors? Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4061722 Share on other sites More sharing options...
Leman Russ SW Posted May 28, 2015 Share Posted May 28, 2015 Any models I have with aerials etc i lay on their front. Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4061775 Share on other sites More sharing options...
Brother Amarel Posted May 28, 2015 Author Share Posted May 28, 2015 I have a friend with one of the new cases, so I'll take a few models round to his place this weekend and see how well it works (and then report back :)). I'm already an Infiltrator aerial down, don't fancy losing more :). Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4061803 Share on other sites More sharing options...
ronin_cse Posted May 28, 2015 Share Posted May 28, 2015 I have a friend with one of the new cases, so I'll take a few models round to his place this weekend and see how well it works (and then report back ). I'm already an Infiltrator aerial down, don't fancy losing more . I lost like 3 of those damn things just building them :(. I'm really curious how hard it will be to fit a Lance Dragoon and the Onagers in those. Especially if the Onager is glued together Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4061825 Share on other sites More sharing options...
Battybattybats Posted May 28, 2015 Share Posted May 28, 2015 I magnetised my dragoons lance-arm for transport, but i still worry about the aerials. Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4061836 Share on other sites More sharing options...
Frater Cornelius Posted May 29, 2015 Share Posted May 29, 2015 I have not attached the Onager upper body to the legs. The legs are movable. The weapons are interchangeable and the model is not attached to the base. Very modular and easily transported. Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4062954 Share on other sites More sharing options...
pompeyladbfp Posted May 31, 2015 Share Posted May 31, 2015 have the double size KR cases, and have the onager upside down in pull/pluck, means the base holds it in place and the aerials dont get squashed... the dunestriders go in on there backs facing up. they had a recent bogof deal so got a few cases for £50 each double case can hold 400 infantry, and you choose the foam lay outs google kaiser rushforth Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4065076 Share on other sites More sharing options...
raziel69r Posted May 31, 2015 Share Posted May 31, 2015 GW crusader case works for me, 30 vanguard/Rangers, 4 Onagers, 10 ruststalkers, 2 Dragoons, 6 Kataphrons, 4 Robots 2 datapriest, 2 Tech priest dominus and an imperial knight. Still has a bit of space left for a few more small models. Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4065225 Share on other sites More sharing options...
Frater Cornelius Posted May 31, 2015 Share Posted May 31, 2015 GW crusader case works for me, 30 vanguard/Rangers, 4 Onagers, 10 ruststalkers, 2 Dragoons, 6 Kataphrons, 4 Robots 2 datapriest, 2 Tech priest dominus and an imperial knight. Still has a bit of space left for a few more small models. Mind taking a few pics of that? Cheers ;) Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4065239 Share on other sites More sharing options...
Battybattybats Posted May 31, 2015 Share Posted May 31, 2015 GW crusader case works for me, 30 vanguard/Rangers, 4 Onagers, 10 ruststalkers, 2 Dragoons, 6 Kataphrons, 4 Robots 2 datapriest, 2 Tech priest dominus and an imperial knight. Still has a bit of space left for a few more small models. Mind taking a few pics of that? Cheers I second this request! Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4065274 Share on other sites More sharing options...
Vel'Cona Posted May 31, 2015 Share Posted May 31, 2015 It seems Battlefoam has AdMech trays (finally). For those of you with reasonable disposable income, these really are the hot ticket. http://us.battlefoam.com/foam-3/ Link to comment https://bolterandchainsword.com/topic/308333-carrying-admech-case-conundrums/#findComment-4065462 Share on other sites More sharing options...
