Forgeworld Night Lord colours
Hellrender
After looking at the FW night lord blue, i have been thinking on how to apply this to bigger surfaces. Do you think it would work?
here is the tutorial for it:
NIGHT LORDS COLOUR SCHEME
1. The models were undercoated with GW Black Spray
2. The models were dry brushed with Rub and Buff Pewter, bringing the black undercoat upto a silver colour.
3. Tamaiya Clear Blue and Clear Red were mixed together to make a clear purple which was applied over the whole model in 3-4 very thin coats.
4. Once the model had dried, the whole thing was airbrushed with a layer of Auto Air colour Transparent Blue.
5. The Lightning strikes were painted on with Administratum Grey as a base coat. Then were the lightning strikes meet, it was highlighted with white.
6. Once the model had dried, it was protected with a coating of GW Purity Seal.
Step 2, could that be done with a simple 2 layer (dark and lighter) normal metal drybrush?
https://bolterandchainsword.com/topic/308577-forgeworld-night-lord-colours/
If you want to avoid the Rub n Buff (which is actually quite nice) I would advocate a regular airbrush coat of metallic paint - skip drybrushing altogether. Not for Night Lords but another metallic Legion color, I used a base color of Ironbreaker (GW) and a zenithal highlight of Chrome (Vallejo).
I have the same feeling about large surfaces and rub n buff. I don't doubt I could get it on but the quality of coating is in question. I'm switching up to Tamiya Gun Metal & maybe a highlight of Tamiya Flat Aluminum for anything larger than a Rapier.
It works quite well, but I can't vouch for very large surfaces. I could try it for you, if you like. I don't have a model to test but I could use the smooth surface of a box or something.
That being said, it is probably easier for large surfaces to use an airbrush.
