wulfgar hammerfist Posted June 25, 2015 Share Posted June 25, 2015 This is what I am thinking of to base an army around. It absolutely bludgeons the fluff player in me but in my local meta, fluff has already been beaten, stabbed, shot and hung out on display. Anyhow, take a look at this. I welcome your thoughts and opinions. The list uses three sources as that is what is allowed in the ITC events that I play in. AM/SM/INQ Priest 30 Guardsmen, 3 lascannons Librarius Conclave Tigurius 4 ML2 Librarians Inquisition Coteaz 890 points This group forms a single psychic death star. The librarians roll on telepathy until they get invisibility and then switch to malefic to use as a summoning battery. The summoning would initially be used to produce pink horrors for additional warp charges and then switch to daemonettes to swamp the board with. This gives me 12 warp charge base and I could add in an astropath or maybe a primaris or two for extra charges. This unit also has decent interceptor ability as anyone landing from reserves is going to be welcomed by Coteaz's special ability. This leaves me with 960 pts to support it with. How can I best support this psychic death star? The biggest threat I see is a culexus dropping in and ruining my ability to generate warp charge. Perhaps a 50 man conscript blob to push out the bubble that the culexus could influence? Thoughts: Skyshield landing pad to provide a 4++ invul save. Giving one or two librarians terminator armor to tank. Maybe a wyvern or two because...well they're wyverns. I'm open to suggestions. +edited to correct points cost+ Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/ Share on other sites More sharing options...
Ulrik_Ironfist Posted June 25, 2015 Share Posted June 25, 2015 HERESY!!!! SPAWNING DAEMONS!!!!! I don't see any real problems other than having all of your stuff denied by a more powerful psychic force, like eldar or daemons or grey knights. Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4101748 Share on other sites More sharing options...
WarriorFish Posted June 25, 2015 Share Posted June 25, 2015 You'll need a PCS, unbound doesn't let you pick elements from a unit choice as far as I'm aware (the wording is a bit woolly though if I remember right). I'd check with your opponent first to be sure on that. I don't really like gimmick lists, as a one trick pony usually only lasts for one game as surprise is often one of the factors of success. I think it could do well though, but again you're relying on certain rolls and for things to work out which makes the plan more fragile. What happens if an opponent turns up with a Culexus assassin for example? You should give the Inquisitor psychic powers too, get some more dice going as you may as well go all in right? :P Perhaps the real question is if you have the models to do this, as that could be a lot of daemons to place on the table... Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102022 Share on other sites More sharing options...
CyderPirate Posted June 25, 2015 Share Posted June 25, 2015 Ewwwww....deamons.... Yeah, looks like you're missing some of the basic stuff from the IG bit. If you're going all-in on the psykers, you might as well throw in a pair of primarises for another 4 dice. Wyverns would be a good call, some acolytes or vets with plasma guns for Coteaz's interceptor? You're also lacking aa or any serious anti-armour stuff. Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102031 Share on other sites More sharing options...
hendrik Posted June 25, 2015 Share Posted June 25, 2015 Isn't including some deamons from the start a better way of summoning some deamons? Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102089 Share on other sites More sharing options...
Emicus Posted June 25, 2015 Share Posted June 25, 2015 Heresy. Wouldn’t it be easier to just run Daemons? If you want Summonstar just run Summonstar. Ally in IG if you still want to be “imperial”… thought you’ve already crossed the line. Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102137 Share on other sites More sharing options...
Interrogator-Chaplain Ezra Posted June 25, 2015 Share Posted June 25, 2015 Isn't including some deamons from the start a better way of summoning some deamons? Yeah. Less risk of Librarians being eaten alive. Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102143 Share on other sites More sharing options...
SW1 Posted June 25, 2015 Share Posted June 25, 2015 *slides bolt pistol from holster* I think we need a word ... ;) Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102146 Share on other sites More sharing options...
Lukash_ Posted June 25, 2015 Share Posted June 25, 2015 You could run a Renegades and Heretics army, which is what I'd do. Rules are in one of the Siege of Vraks books. Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102164 Share on other sites More sharing options...
wulfgar hammerfist Posted June 25, 2015 Author Share Posted June 25, 2015 Some valid points have been brought up but I'll share my thought process to address those concerns: Unbound: The list will not be unbound. The points above include the cost of a PCS; I just didn't list the PCS because it isn't in the blob specifically. Apologies that it wasn't clear. I still need to add a HQ and another troop. Culexus: This is indeed a valid point and I think use of conscripts or some other buffer would be needed to push out the bubble of his influence. Coteaz: He is already an ML2 psyker so that further buffs my warp charge giving me 13 dice as the base. Initially I am considering putting him with the blob as it puts out an impressive amount of shots at close range. Getting the right powers: Summoning is the primaris power for Malefic. Guaranteed to get it. Invisibility is a nice to have but not a necessity with this list. Why not just play daemons?: I think you get more efficient casting power with the Conclave. You're casting powers on a 2+. You can reliably throw 3 dice at it and succeed. If you use Tigurius you can re-roll failed psychic tests. Being out-classed: That is a possibility but I have more efficient casting power and a ML3 dude doing the heavy work so I don't think it as cut and dry as it seems. I'll need to play test it. Heresy: Fluff is dead in competitive play. Sadly, it's all about powerful combos. This list is still very much in the concept phase. I am trying to figure out what to support it with. Anti-tank is a must. Anti-air is important. So, really, I'm building about a 1000pt list to support the psychic battery. It may very well be garbage but I'll have to play test it to see whether or not it is viable. Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102349 Share on other sites More sharing options...
*Furyou Miko Posted June 25, 2015 Share Posted June 25, 2015 Can you include a Vulture? PuniVulture will take care of your anti-air and anti-tank issues. Link to comment https://bolterandchainsword.com/topic/310012-a-heretical-idea/#findComment-4102478 Share on other sites More sharing options...
