114th Cadian
M@verik115
So far 2 Chimeras, 1 Leman Russ and 1 Vendetta.
Still to go: 4 Guardsmen Squads, 1 Veteran Squad, 1 Kasrkin Squad, 2 Command Squads, 1 Special Weapon Squad, 2 Heavy Weapon Squads, 1 Chimera, 4 Leman Russ, 4 Sentinels, 2 Baneblades. (I believe thats it so far...)
11857554 10153052097150108 533967782 N
11850886 10153052093505108 758555419 N
11846072 10153052094000108 95518275 N
11787497 10153052094610108 2146455301 N
11165916 10152849622325108 725262653 N
11844183 10153047047945108 311110785 N (1)
10648993 10152406363680108 6540729489201909366 O
10668835 10152406363690108 1906811244889041357 O
10014149 10152406363695108 2068516593665929040 O
11185667 10152844125915108 1819102784 N
11198710 10152844126815108 1328779310 N
11130732 10152844126385108 925246923 N
11180069 10152837973310108 133784269 N
11180133 10152837972340108 1098435838 N
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4139674
Looks great so far!
Have you looked into making/buying a lightbox?  A lot of your details are obscured by shadows... and if you use a flash to cancel that out you will wash out your details.
I built a cheap little floor/3 wall tray to photograph inside.  Built it out of posterboard, cost me like $3 for a sheet.
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4140057
Yeah I will definitely have to do something. Although I rate its mostly down to me taking the pics late at night as I never tend to see daylight outside of work haha. Ive got a professional photo set at work but since the flash kits are so high, im sure they wont pick out the detail well either.
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4140070
This is my setup - the trick is to get the lighting correct. I use 2 cheap clip on lights and an overhead lamp to reduce the shadows. The blocks of wood are just to stop the clip on lamps from falling over.
I think they look ok and have some effective weathering but we really need better photos :(
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4146852
I can see the lights and weathering ok along with the transfers so the Chimera looks good, bit hard to see the detail on the infantry. Taking good pictures is greatly improved by having a decent camera of course but there is much you can do to improve them if you have the time :) Give it a go on getting us some closer shots on the troopers :tu:
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4146949
  • 2 weeks later...
Just a quick update on what I have been working on.
Firstly I promise I will post the best damn photos ever eventually laugh.png
Secondly, here are 2 autocannon teams fully complete (another 1 left to do).
11991286 10153108602415108 2003067907 O
11933554 10153108601950108 55927164 O
lastly my newly completed punisher leman russ. It is covered in a lot of oil and gun powder residue msn-wink.gif
11884190 10153108606055108 819731127 O
11984351 10153108603035108 461385006 O
11982410 10153108603525108 458661064 O
11975435 10153108606490108 1434692736 O
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4161989
Decently filthy "I been on this hellhole chasing shadows through the wastes for way too fraggin' long" paint scheme....I'm not thrilled with the shiny decals, you should either clearcoat (matte) the whole model, or use a small/fine brush to paint the color of the hull over the "clear" parts of the decal to kill the shine.  You also need to base your infantry, lol... I liked your work a lot less before I saw the bases for the heavy weapons teams...that provided context for the color palate.
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4161993
Thanks mate. Yeah the clear coat is coming on this weekend when I have time. I use matt varnish for that, but the decal still shine a bit under bright light. As for the infantry they are all mostly based, just need a bit more work on them. Should be up maybe tomorrow.
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4161997
Unfortunately decal shine can be a bit of a pain and as already stated, the use of matt varnish and base colour gap filling are 2 ways to disguise it. You may also want to consider weathering over the decal to help them blend in. Paint chips and rust/mud effects will help to break up the decal area.
https://bolterandchainsword.com/topic/312001-114th-cadian/#findComment-4162893
  • 1 year later...
