DIY board-suggestions/tips?
Work let half the staff go home early and then it got busy. Seems our resource an planning team don't know how to factor in football matches into demand requirements. :(
Managed some very rough sketches which give a feel for at sort of shapes that work. If I'd realised work was going to be numpties I would have done more of the basic shapes rather than having fun tryin to remember the Arbites symbol.
http://www.bolterandchainsword.com/gallery/image/164983-image/
http://www.bolterandchainsword.com/gallery/image/164984-image/
Heres some of my old foamboard buildings (last post on the link for the piccie) from back in the early days I'll try to dig out some of the newer bits and do some pics if you'd like?
http://z11.invisionfree.com/Work_In_Progress/index.php?showtopic=243&hl=
some good stuff by other posters in there for inspiration as well
Foamboard cubes with some wooden kerbs not the prettiest city but the idea was early colony with pre fab buildings so no major architectural works yet (or in other words i was feeling lazy) but the basic buildings were very easy to make 8" (x 8") x 4" tall with a inner parapet height of an inch or so and around 2" of floor/ceiling on the inside of the upper level supported everything from metal dreads through to gretchin hordes while still letting you get in the building to move models
Couple of tips
Save your offcuts from door ways, windows etc even if you're not going to make doors the bits will be usefull for bracing floors / walls / corners
Keep a scale figure nearby throughout I use an imperial guardsman called Bob
Remember to leave plenty of room to get your hands in to move your models around during the game, I had to junk my second biggest building (2 levels 16" wide by 8" deep by 7" tall) for this very reason
Couple of tips
Treadhead is spot on with these tips. I've got a bag of offcuts I dive into when I need to brace something. Remember a small triangle hidden under the floor helps keep things square/rigid.
I've also been trying to find a guide to joining boards together. Finally found it ...
http://oinksterrain.blogspot.co.uk/2011/12/working-with-foamboard-joining-basics.html?m=1
Give it a good read and for basic builds I'd recommend using this type of joint to save having to do much work hiding joints on the corners!!!
@SW1- thanks for the sketches and the joining guide, any idea how to make the Arbites symbol?
@treadhead- now I have an idea of what a finished building should look like, also thanks for the tips. I'd like to see the new pics too if thats possible
It's a mailed fist holding a set of scales with a stylised I sign.
Yeah I know (saw it in your sketch) but how do you actually make one?
You need to break down the shape to an outline. Cut out this outline in card. Then add an extra layer on where you want to build up more.
Nice set of ruins there already look much better than my early stuff.
Onto some piccies
I'd like to introduce Bob
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0655.jpg
He's been around for years dodging paint, shards of plastic and various forms of foam
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0654.jpg
Here he is showing the offcut bracing method
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0653.jpg
And the newer stuff
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0638.jpg
pump house and pipeline
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0643.jpg
Bob managed to doge this shot
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0648.jpg
Foam board with a thin(ish) card layer and some pvc plumbing pipe and some more card for the collars
with an extra layer of card for detail on top of the collar
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0645.jpg
And the cod tavern
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0665.jpg
http://i21.photobucket.com/albums/b264/treadhead2/DSCF0662.jpg
Here is an example of the floors, with a renegade enforcer for scale purposes:
IMG 20150903 185727925
Here is the board layout so far, obviously very WIP, vindicator for scale:
IMG 20150903 185647917
My idea is to have the WB's and cultists coming on from the left in a quarter-circle around the bottom left corner building, with cultist sharpshooters in the other 2 buildings
